1 Reply Latest reply on Jul 13, 2012 6:27 AM by jxyiliu@yahoo.ca
    converting string to bytearray very very slow on iOS
    jxyiliu@yahoo.ca
      Dear Members,
      I want to convert image string value read from xml file to bytearray for an iOS Application,
      By asking Google, I found out that there is an existing Base64 class written by Subhero for AS3.
      I attached the code below for your references
      However, during the testing, I found that the _decodeSring(str); function call is really really slow. It took hundreds mini-seconds to execute. My image string length is around 90k.
      Has anyone else tried with this piece code and what is the performance.
      Is there any other way to do the same converting with better performance?
      *  A Base64 encoder/decoder implementation in Actionscript 3
      *  This work is made available under http://creativecommons.org/licenses/by-nc-sa/2.0/de/deed.en
      *  @author subhero@gmail.com
      *  @version 0.5
      package formatter {
      // import ->
      import flash.utils.ByteArray;
      import flash.errors.EOFError;
      // <- import
      // Base64 ->
      *   A class used for transforming a ByteArray to a Base64-encoded string and vice versa.
      *   Since the "built-in" class (mx.utils.Base64Encoder) is not documented yet, this class can be
      *   used for Base64 encoding/decoding in the meantime.
      *   The class will be deprecated as soon as Macromedia/Adobe decides to fully release the
      *   "native" AS3 Base64 class (Flex2 full release respectively).
      *   Its implementation is based upon a HowTo {@link http://www.kbcafe.com/articles/HowTo.Base64.pdf},
      *   a Java implementation {@link http://ostermiller.org/utils/Base64.java.html} and an
      *   AS2-implementation by Jason Nussbaum {@link http://blog.jasonnussbaum.com/?p=108}
      public class Base64 {
      // mx.utils.StringUtil
      public static function isWhitespace(char:String):Boolean{
      switch (char){
      case " ":
      case "\t":
      case "\r":
      case "\n":
      case "\f":
      return true;
      default:
      return false;
      // the Base64 "alphabet"
      private static var _b64Chars:Array=new Array(
      'A','B','C','D','E','F','G','H',
      'I','J','K','L','M','N','O','P',
      'Q','R','S','T','U','V','W','X',
      'Y','Z','a','b','c','d','e','f',
      'g','h','i','j','k','l','m','n',
      'o','p','q','r','s','t','u','v',
      'w','x','y','z','0','1','2','3',
      '4','5','6','7','8','9','+','/'
      // the reverse-lookup object used for decoding
      private static var _b64Lookup:Object=_buildB64Lookup();
      // the boolean to insert linebreaks after 76 chars into the Base64 encoded string
      private static var _linebreaks:Boolean;
          *   The class method for encoding an array of bytes to a Base64 encoded string.
          *   @param bArr A ByteArray containing values to encode
          *   @param linebreaks A boolean to insert a linebreak after 76 Base64-chars
          *   @return The Base64 encoded string
      public static function Encode(bArr:ByteArray, linebreaks:Boolean=false):String
              _linebreaks
      = linebreaks;
      return _encodeBytes(bArr);
          *   The class method for decoding a Base64 encoded string to an array of bytes.
          *   @param str A Base64 encoded string
          *   @return An array of bytes
      public static function Decode(str:String):ByteArray
      return _decodeSring(str);
          *   The private helper class method to build an object used for reverse B64 char lookup.
          *   @return An object with each B64 char as a property containing the corresponding value
      private static function _buildB64Lookup():Object
      var obj:Object=new Object();
      for (var i:Number=0; i < _b64Chars.length; i++)
                  obj
      [_b64Chars[i]]=i;
      return obj;
          *   The private helper class method to determine whether a given char is B64 compliant.
          *   @param char A character as string (length=1)
          *   @return A boolean indicating the given char *is* in the B64 alphabet
      private static function _isBase64(char:String):Boolean
      return _b64Lookup[char] != undefined;
          *   The private class method for encoding an array of bytes into a B64 encoded string.
          *   @param bs An array of bytes
          *   @return The B64 encoded string
          *   @see formatter.Base64.Encode()
      private static function _encodeBytes(bs:ByteArray):String
      var b64EncStr:String = "";
      var bufferSize:uint;
      var col:uint=0;
              bs
      .position=0;
      while (bs.position < bs.length)
                  bufferSize
      = bs.bytesAvailable >= 3 ? 3 : bs.bytesAvailable;
      var byteBuffer:ByteArray=new ByteArray();
                  bs
      .readBytes(byteBuffer, 0, bufferSize);
                  b64EncStr
      += _b64EncodeBuffer(byteBuffer);
                  col
      +=4;
      if (_linebreaks && col%76 == 0) {
                      b64EncStr
      += "\n";
                      col
      =0;
      return b64EncStr.toString();
          *   The private class method for encoding a buffer of 3 bytes (24bit) to 4 B64-chars
          *   (representing 6bit each => 24bit).
          *   @param buffer An array of bytes (1 <= length <= 3)
          *   @return The byte buffer encoded to 4 B64 chars as string
          *   @see formatter.Base64._encodeBytes()
      private static function _b64EncodeBuffer(buffer:ByteArray):String
      var bufferEncStr:String = "";
              bufferEncStr
      += _b64Chars[buffer[0] >> 2];
      switch (buffer.length)
      case 1 :
                      bufferEncStr
      += _b64Chars[((buffer[0] << 4) & 0x30)];
                      bufferEncStr
      break;
      case 2 :
                      bufferEncStr
      += _b64Chars[(buffer[0] << 4) & 0x30 | buffer[1] >> 4];
                      bufferEncStr
      += _b64Chars[(buffer[1] << 2) & 0x3c];
                      bufferEncStr
      break;
      case 3 :
                      bufferEncStr
                      bufferEncStr
      += _b64Chars[(buffer[1] << 2) & 0x3c | buffer[2] >> 6];
                      bufferEncStr
      += _b64Chars[buffer[2] & 0x3F];
      break;
      default :   trace("Base64 byteBuffer outOfRange");
      return bufferEncStr.toString();
          *   The private class method for decoding a string containing B64 chars to an array of bytes
          *   @param s The B64 encoded string
          *   @return A decoded array of bytes
          *   @see formatter.Base64.Decode()
      private static function _decodeSring(s:String):ByteArray
      var b64EncString:String="" + s;
      var b64DecBytes:ByteArray=new ByteArray();
      var stringBuffer:String="";
      var lgth:uint=b64EncString.length;
      for (var i:uint=0; i < lgth; i++)
      var char:String=b64EncString.charAt(i);
      if (!isWhitespace(char) && (_isBase64(char) || char == "=")) {
                      stringBuffer
      += char;
      if (stringBuffer.length == 4) {
                          b64DecBytes
      .writeBytes( _b64DecodeBuffer(stringBuffer) );
                          stringBuffer
              b64DecBytes
      .position=0;
      return b64DecBytes;
          *   The private class method for decoding a string buffer of 4 B64 chars
          *   (each representing 6bit) to an array of 3 bytes.
          *   @param buffer A string containing B64 chars (length = 4)
          *   @return An array of bytes containing the decoded values
          *   @see formatter.Base64._decodeBytes()
      private static function _b64DecodeBuffer(buffer:String):ByteArray
      var bufferEncBytes:ByteArray=new ByteArray();
      var charValue1:uint=_b64Lookup[buffer.charAt(0)];
      var charValue2:uint=_b64Lookup[buffer.charAt(1)];
      var charValue3:uint=_b64Lookup[buffer.charAt(2)];
      var charValue4:uint=_b64Lookup[buffer.charAt(3)];
              bufferEncBytes
      .writeByte(charValue1 << 2 | charValue2 >> 4);
      if (buffer.charAt(2) != "=") bufferEncBytes.writeByte(charValue2 << 4 | charValue3 >> 2);
      if (buffer.charAt(3) != "=") bufferEncBytes.writeByte(charValue3 << 6 | charValue4);
      return bufferEncBytes;
      // <- Base64
