7 Replies Latest reply on Jul 12, 2012 6:48 PM by Jim_Simon
    Need to convert to FLV with specific audio options
    GMiddlemiss
      Hi all,
      I'm struggling with a video conversion that I need to do.
      We have a short 3 minute video that we've produced, but when played back on our Corporate intranet over most user's PCs - almost all the speech in the file is inaudible, just the background music.  We've tested the video over stereo headsets, speakers etc and all is fine.  However, lots of users in our business use mono USB Plantronics headsets, and it's these users who are struggling. I've tried many different formats and still have this issue.
      We are requested by our IT dept to use FLV format for video wherever possible.
      I've run a video I know works fine against our own video using iMedia HUD app on my Mac to compare the codecs etc, and these are the results:
      WORKING VIDEO
      quad1.flv
      Format        : Flash Video
      File size        : 62.5 MiB
      Duration        : 3mn 45s
      Overall bit rate                                                  : 2 324 Kbps
      Writing application                                                  : Lavf52.84.0
      Video
      Format        : Sorenson Spark
      Codec ID        : 2
      Duration        : 3mn 45s
      Bit rate        : 195 Kbps
      Width        : 450 pixels
      Height        : 300 pixels
      Display aspect ratio                                        : 3:2
      Frame rate mode                                                  : Constant
      Frame rate                                                            : 25.000 fps
      Bit depth        : 8 bits
      Bits/(Pixel*Frame)                                                  : 0.058
      Stream size                                                            : 5.25 MiB (8%)
      Audio
      Format        : MPEG Audio
      Format version                                                  : Version 1
      Format profile                                                            : Layer 3
      Mode        : Joint stereo
      Mode extension                                                  : MS Stereo
      Codec ID        : 2
      Codec ID/Hint                                                            : MP3
      Duration        : 3mn 45s
      Bit rate mode                                                            : Constant
      Bit rate        : 128 Kbps
      Channel(s)                                                            : 2 channels
      Sampling rate                                                            : 44.1 KHz
      Compression mode                                        : Lossy
      Stream size                                                            : 3.44 MiB (6%)
      Writing library                                                            : LAME3.98.4
      NEW VIDEO (Non-Working)
      Virgin_Kon_v8.mp4
      Format        : MPEG-4
      Format profile                                                            : Base Media / Version 2
      Codec ID        : mp42
      File size        : 34.9 MiB
      Duration        : 2mn 20s
      Overall bit rate                                                  : 2 078 Kbps
      Encoded date                                                            : UTC 2012-07-09 15:38:42
      Tagged date                                                            : UTC 2012-07-12 07:25:56
      Video
      Format        : AVC
      Format/Info                                                            : Advanced Video Codec
      Format profile                                                            : Baseline@L3.0
      Format settings, CABAC                                        : No
      Format settings, ReFrames                              : 2 frames
      Codec ID        : avc1
      Codec ID/Info                                                            : Advanced Video Coding
      Duration        : 2mn 20s
      Bit rate        : 1 915 Kbps
      Width        : 640 pixels
      Height        : 360 pixels
      Display aspect ratio                                        : 16:9
      Color space                                                            : YUV
      Chroma subsampling                                        : 4:2:0
      Bit depth        : 8 bits
      Scan type        : Progressive
      Bits/(Pixel*Frame)                                                  : 0.332
      Stream size                                                            : 32.1 MiB (92%)
      Language                                                            : English
      Tagged date                                                            : UTC 2012-07-09 15:38:44
      Color primaries                                                  : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
      Transfer characteristics                                        : BT.709-5, BT.1361
      Matrix coefficients                                                  : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
      Audio
      Format        : AAC
      Format/Info                                                            : Advanced Audio Codec
      Format profile                                                            : LC
      Codec ID        : 40
      Duration        : 2mn 20s
      Bit rate        : 160 Kbps
      Channel positions                                                  : Front: L R
      Sampling rate                                                            : 48.0 KHz
      Stream size                                                            : 2.69 MiB (8%)
      Language                                                            : English
      Can anyone offer any advice - I would like to convert it to match but I'm not sure of how to get these settings.
      Just for clarity - the video plays perfectly well, it's just the audio we are having issue with.  It's played via FlowPlayer on our SharePoint intranet.  This is the first video we have had this issue with.
