3 Replies Latest reply on Jul 13, 2012 3:52 AM by Peter Spier
    Table not converted using Adobe InDesign Tagged Text
    gopaljay78 Level 1
      Can any one help me to sort the table conversion problem.
      I have one InDesign  tagged text file, where it has two one-Row table. When I flow the tagged text into the InDesign document, the table are not converted properly.
      For example, the below tagged text contains two One-Row table. When I place the below content into the InDesign document, Only one table is imported into the InDesign document. And that too comes at end of the document. Can anyone help to sort out this problem.
      My InDesign tagged text are below.
      <ASCII-MAC>
      <Version:7><FeatureSet:InDesign-Roman><ColorTable:=<Black:COLOR:CMYK:Process:0,0,0,1><Pape r:COLOR:CMYK:Process:0,0,0,0>>
      <DefineParaStyle:TXT=<Nextstyle:TXT><cColor:C\=0 M\=100 Y\=0 K\=0>>
      <DefineParaStyle:TBL=<BasedOn:TXT><Nextstyle:TBL>>
      <DefineParaStyle:NormalParagraphStyle=<Nextstyle:NormalParagraphStyle>>
      <DefineTableStyle:\[Basic Table\]=>
      <ParaStyle:TXT>It, si volorrorem. Ovidi optatia tiundit hitate nempor acest exerumq uiaeped quis ...
      <ParaStyle:TBL><TableStyle:\[Basic Table\]><TableStart:1,2:1:0<tCellDefaultCellType:Text>><ColStart:<tColAttrWidth:261.13779 52755>><ColStart:<tColAttrWidth:261.1377952755>><RowStart:<tRowAttrHeight:16.723876953125> ><CellStyle:\[None\]><StylePriority:0><CellStart:1,1><ParaStyle:NormalParagraphStyle>sampl e table 1<CellEnd:><CellStyle:\[None\]><StylePriority:0><CellStart:1,1><ParaStyle:NormalParagraph Style>sample text<CellEnd:><RowEnd:><TableEnd:>
      <ParaStyle:TBL><TableStyle:\[Basic Table\]><TableStart:1,2:1:0<tCellDefaultCellType:Text>><ColStart:<tColAttrWidth:261.13779 52755>><ColStart:<tColAttrWidth:261.1377952755>><RowStart:<tRowAttrHeight:16.723876953125> ><CellStyle:\[None\]><StylePriority:0><CellStart:1,1><ParaStyle:NormalParagraphStyle>sampl e text<CellEnd:><CellStyle:\[None\]><StylePriority:0><CellStart:1,1><ParaStyle:NormalParagr aphStyle>sample table 2<CellEnd:><RowEnd:><TableEnd:>
      <ParaStyle:TXT>Imus et aruptat urepere nonsendaepel ide nonsed quasi utempos....
      Gopal
        • 1. Re: Table not converted using Adobe InDesign Tagged Text
          How did you generate that text file? I can't get it import as tagged text at all.
          • 2. Re: Table not converted using Adobe InDesign Tagged Text
            gopaljay78 Level 1
            Hi Peter,
            In the earlier tagged code space is added between "R owStart". That is why it can not able to import.
            Below is the corrected one. Please help me on this.
            <ASCII-MAC>
            <Version:7><FeatureSet:InDesign-Roman><ColorTable:=<Black:COLOR:CMYK:P rocess:0,0,0,1><Paper:COLOR:CMYK:Process:0,0,0,0>>
            <DefineParaStyle:NormalParagraphStyle=<Nextstyle:NormalParagraphStyle> >
            <ParaStyle:TBL><TableStyle:\[Basic Table\]><TableStart:1,2:1:0<tCellDefaultCellType:Text>><ColStart:<tColAttrWidth:261.1377952755>><ColStart:<tColAttrWidth:261.1377952755>><RowStart:<tRowAttrHeight:16.723876953125>><CellStyle:\[None\]><StylePriority:0><CellStart:1,1><ParaStyle:NormalParagraphStyle>sample table 1<CellEnd:><CellStyle:\[None\]><StylePriority:0><CellStart:1,1><ParaStyle:NormalParagraphStyle>sample text<CellEnd:><RowEnd:><TableEnd:>
            Gopal
            • 3. Re: Table not converted using Adobe InDesign Tagged Text
              Still won't import....
              Take another look at these two lines:
              There's an extra space in the first one between the >> at the end, but I think the real problem may be the > at the end of the second line. I don't know enough about tagged text to say.
