0 Replies Latest reply on Mar 31, 2008 12:32 PM by SGEnterprises
    Adobe CS3 Flash Programmer Needed
    SGEnterprises
      I’m using Camtasia 5.0.2 to create a Flash .flv video. Camtasia 5.0.2 produces the following 9 files to be played in an Internet browser (example is a 2.5 min video with file name, Test 001 single FLV w PIP and TOC 02 21 2008):
      FlashTemplate.css 1 KB
      ProductionInfo.xml 16 KB
      Test 001 single FLV w PIP and TOC 02 21 2008.flv 4,969 KB
      Test 001 single FLV w PIP and TOC 02 21 2008.html 2 KB
      Test 001 single FLV w PIP and TOC 02 21 2008.js 1 KB
      Test 001 single FLV w PIP and TOC 02 21 2008_config.xml 9 KB
      Test 001 single FLV w PIP and TOC 02 21 2008_controller.swf 185 KB
      Test 001 single FLV w PIP and TOC 02 21 2008_nofp_bg.gif 11 KB
      Test 001 single FLV w PIP and TOC 02 21 2008_preload.swf 14 KB
      I want to produce a data DVD that does not open an Internet browser and require the Flash player plug-in but instead autostarts an .exe and is truly standalone. This allows a full 1024 X 768 video to be displayed on most monitors. The Internet browser is unnecessary and in fact confusing to the user.
      I’m searching for a CS3 Flash programmer to take the Flash files created by Camtasia and create the standalone player that also supports a Table of Contents (TOC) and a Picture-in-Picture (PIP). An example of an acceptable player and TOC is demonstrated at: http://video.techsmith.com/camtasia/5/edu/quickstart/enu/default.html
      Click: TechSmith ExpressShow
      An example of an acceptable player with PIP is demonstrated at:
      Click: Modify a Picture-In-Picture Clip
      Can you be able to help me?
