3 Replies Latest reply on Jul 13, 2012 1:39 PM by RjL190365
    Building video editing PC
    Ulbuld
      Hi
      I'm building a video editing PC for my dad.
      He will most likely be Adobe Premiere.
      Please share your thoughts on this configuration:
      Mobo:                       Intel Desktop Board DH77KC (LGA1155 and intel H77 chipset)
      CPU:                         Intel Core i7-3770 ivy bridge 3.4 hgz
      Memory:                   Corsair Vengeance 4 x 4 GB - 1.35 V - XMP
      Graphics:                 Inno3D GeForce GTX 570
      SSD:                        Kingston HyperX 3K 240 GB (boot drive)
      Storages drives:      2 x 1 TB 7200 rpm in Raid 0
      PSU:                        Corsair HX750W
      CPU cooling:           Cooler master Hyper 212 Evo
      Case:                      Antec Three Hundred Two
      Fans:                       3 x SilverStone FN121
      Will it there be any advantage in converting AVCHD with Cineform Neoscene ?
      Will this configuration be sufficient for running Adobe Premiere CS6?
      Alot of folks recommend I7 3930K LGA2011, but thats a little over budget.
        • 1. Re: Building video editing PC
          RjL190365 Level 4
          Wrong choice of CPU and motherboard because not only is the i7-3770 a non-K model, but also because the H77 chipset does not allow you to overclock by even 1 Hz at all (outside of the limited Turbo Boost feature that's either on AUTO or Disabled). And based on what I saw on the PPBM5 tests, a stock i7-3770 on an H77 mobo would have performed slower than some i5 systems, let alone an overclocked i7 system. In fact, a stock i7-3770 on an H77 mobo would have performed slower than some systems based on now-obsolete first-generation i7 quad-core CPUs and first-generation Nehalem chipsets. In other words, this planned configuration is a case of "penny-wise, pound-foolish"--a waste of money, IMHO. And any system that's based on a relatively expensive third-generation i7 CPU that underperforms a system based on an obsolete first-generation i7 CPU is no bargain.
          • 2. Re: Building video editing PC
            Ulbuld Level 1
            Hmm.. choose the non-K and H77 because i didnt plan on overclocking, as ive never tried overclocking.. Would you recommend 3770K and Z77 chipset if I overclocked ?
            • 3. Re: Building video editing PC
              RjL190365 Level 4
              Yes (at a minimum).
