4 Replies Latest reply on Jul 17, 2012 7:30 PM by maxr2012
    Help with script to make PDFs
    maxr2012
      Hi
      I have an Applescript that will pdf an indesign file but I want to improve it.
      I want it to be a droplet that can process multiple files.
      Here is the script and thanks in advance to anyone who can help.
          tell application "Adobe InDesign CS5.5"
              set user interaction level of script preferences to never interact
              activate
              set My_Pdf_Presets to name of every PDF export preset
              set MyPdfPreset to choose from list My_Pdf_Presets with prompt "Choose a preset"
              if MyPdfPreset is false then
                  display dialog "User Cancelled!" buttons "OK" giving up after 60
                  error number -128
              end if
              set properties of PDF export preferences to properties of PDF export preset (item 1 of MyPdfPreset)
              set page range of PDF export preferences to all pages
              set MyFolder to file path of active document
              tell application "Finder"
                  if (exists folder "PDFs" of folder MyFolder) is false then
                      make new folder at MyFolder with properties {name:"PDFs"}
                  end if
              end tell
              set MyDocName to name of active document
              set OrigDelims to text item delimiters of AppleScript
              set text item delimiters of AppleScript to {"."}
              set MyShortName to text item 1 of MyDocName
              set text item delimiters of AppleScript to OrigDelims
              set MyFilePath to MyFolder & "PDFs" & ":" & MyShortName & ".pdf" as string
              tell active document
                  export format PDF type to MyFilePath without showing options
                  close saving no
              end tell
              set user interaction level of script preferences to interact with all
              activate
              display dialog "Your PDFs are ready" with icon 1 buttons {"OK"} default button "OK"
          end tell
        • 2. Re: Help with script to make PDFs
          maxr2012 Level 1
          Hi Hans,
          I have plugged it in but it isn't working.
          I know very little about Applescript can you tell me what I am doing wrong?
          property type_list : {} -- eg: {"PICT", "JPEG", "TIFF", "GIFf"}
          property extension_list : {"indd", "idml", "inx"}
          property typeIDs_list : {} -- eg: {"public.jpeg", "public.tiff", "public.png"}
          -- This droplet processes files dropped onto the applet
          on open these_items
              repeat with i from 1 to the count of these_items
                  set this_item to item i of these_items
                  set the item_info to info for this_item
                  try
                      set this_extension to the name extension of this_info
                  on error
                      set this_extension to ""
                  end try
                  try
                      set this_filetype to the file type of this_info
                  on error
                      set this_filetype to ""
                  end try
                  try
                      set this_typeID to the type identifier of this_info
                  on error
                      set this_typeID to ""
                  end try
                  if (folder of the item_info is false) and (alias of the item_info is false) and ((this_filetype is in the type_list) or (this_extension is in the extension_list) or (this_typeID is in typeIDs_list)) then
                      process_item(this_item)
                  end if
              end repeat
          end open
          -- this sub-routine processes files
          on process_item(this_item)
                  activate
                      error number -128
                  end if
                      end if
                  end tell
                      close saving no
                  end tell
                  activate
              end tell
          end process_item
          • 3. Re: Help with script to make PDFs
            -hans- Level 4
            Third day raining nonstopp ;-)
            So, try this:
            (*Has to be saved as programm …
            Works with folders and files dropped onto
            Tested with ID CS 5.5; OSX 10.7.4
            property pdfPreset : ""
            property counter : 0
            property errorsOccurred : 0
            on open these_items
            set counter to 0
            set errorsOccurred to 0
                --get pdf export preset
                set pdfPreset to getExportPreset()
                if pdfPreset is false then
                    activate
                    display alert "No PDF-Preset selected."
                else
                    --loop
                        set this_item to (item i of these_items)
            --'info for' should be replaced in future but for now it's easy to use ...
                        if folder of the item_info is true then
                            process_folder(this_item)
                        else
                            set {fileContainer, shortName} to my getContainer(this_item)
                            process_item(this_item as text, fileContainer, shortName, pdfPreset)
                        end if
                    end repeat
                    activate
                    display dialog "Finished. | " & counter & " files have been exported. | " & errorsOccurred & " Errors occurred."
                end if
            end open
            on process_folder(this_folder)
                set these_items to list folder this_folder without invisibles
                    set this_item to alias ((this_folder as text) & (item i of these_items))
                    else
                    end if
                end repeat
            end process_folder
            --get folder and short filename (without possible extension)
            on getContainer(this_item)
                set TID to AppleScript's text item delimiters
                set AppleScript's text item delimiters to {":"}
                set folderPath to ((text items 1 thru -2 of (this_item as string)) as text) & ":"
                set trimmedName to text item -1 of (this_item as string)
                if trimmedName contains "." then
                    set AppleScript's text item delimiters to {"."}
                    set trimmedName to text 1 thru text item -2 of trimmedName
                end if
                set AppleScript's text item delimiters to TID
                return {folderPath, trimmedName}
            end getContainer
            on getExportPreset()
                    set MyPdfPreset to (choose from list My_Pdf_Presets with prompt "Choose a preset to process the dropped files" without multiple selections allowed)
                        return false
                    else
                        return item 1 of MyPdfPreset
                    end if
                end tell
            end getExportPreset
            on process_item(this_item, fileContainer, shortName, pdfPreset)
                do shell script "mkdir -p " & quoted form of POSIX path of (fileContainer & "PDFs")
                try
                        set myDoc to open alias this_item
                        set pdfFilePath to fileContainer & "PDFs" & ":" & shortName & ".pdf" as string
                        set chosedPdfPreset to PDF export preset pdfPreset
                        export myDoc format PDF type to pdfFilePath using chosedPdfPreset without showing options
                        close myDoc saving no
                        set counter to counter + 1
                    end tell
                on error e
                    set errorsOccurred to errorsOccurred + 1
                    display dialog "My problem: " & e giving up after 3
                end try
            end process_item
            • 4. Re: Help with script to make PDFs
              maxr2012 Level 1
              Thankyou Hans that works a treat.
