4 Replies Latest reply on Jul 17, 2012 2:05 AM by Peter Kahrel
    Tracking
    Cenchen Level 2
                my input    is IP.jpg, and expected output is OP.jpg in an indesign cs5.5 without any tracking...
        • 1. Re: Tracking
          Peter Kahrel Adobe Community Professional & MVP
          And your question is. . .
          • 2. Re: Tracking
            Bo LeBeau Level 4
            Why not use a font that actually has that glyph? This will avoid any issues with tracking
            Open the Glyph panel (Type menu, Glyphs) and select a font that has extended features, a font with Pro in the name is usually more likely to have these glyphs.
            In the example, the top text is Myriad Pro and the bottom text is Adobe Garamond Pro
            Select the glyph you want in the Glyph panel. Glyphs with a small right arrow at the bottom means that there is more than one similar glyph. click and hold to select.
            • 3. Re: Tracking
              Cenchen Level 2
                        Those kind of glyphs values are found in "openType" fonts(like,Myriad Pro and Adobe Garamond Pro), but the same glyphs value are not found in "Type 1" fonts(like Minion and Optima)...
                        So what will do for type 1 fonts???
              • 4. Re: Tracking
                Minion and Optima are available as OTF fonts, too. But anyway, for letter+accent combinations not present in Type 1 fonts (and OTF fonts too, for that matter), you can use http://www.kahrel.plus.com/indesign/compose.html
                Peter
