• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
ERROR 1034
Participant ,
Jul 16, 2012 Jul 16, 2012
HELLO ALL, I HAVE A QUESTION PLEASE HELP ME, I HAVE AN APPLICATION WHERE I HAVE A SPRITE CONTAINER WHERE I ADDCHILD MOVIE CLIPS WITH AN XML INFORMATION DATA LOADED, AND A SCROLLING MOUSE FUNCTION WITH A TWEEN EFFECTS. BUT WHEN I TESTED IT TURNS IN THE OUT THE NEXT ERROR "
Forced conversion error 1034, can not convert flash display :: Loader @ 29e80041 flash display.MovieClip
THANKS IN ADVANCE.
REGARDS
JOSELYN
TOPICS
ActionScript
Views
1.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
click file>publish settings>swf and tick "permit debugging".  retest.
copy and paste the error message and copy the problematic line of code mentioned in the error message.
Votes
Translate
Translate
Report
Report
Participant ,
Jul 17, 2012 Jul 17, 2012
Hello Kglad
I send to you what you asking for, I click file>publish settings>swf and click "permit debugging".  and tested
it gave this error.
TypeError: Error #1034: Error de conversión forzada: no se puede convertir flash.display::Stage@edd3b51 en flash.display.MovieClip.
at prueba_fla::MainTimeline/frame1()[prueba_fla.MainTimeline::frame1:65]
THIS IS PART OF THE CODE
import com.greensock.TweenLite;
// CREATING NEWS ENTRIES
// news container for easier scrolling
var newsContainer:Sprite = new Sprite;
newsContainer.y = -newsContainer.height-stage.stageHeight/2;
addChild(newsContainer);
// storing references into array for later access
var newsArray:Array = new Array( );
// XML //
var MC2:MovieClip = MovieClip(this.parent); //
var newsHeight:Number=0;
// creating instances of NewsItem movieclips that will later be determined by XML
for(var k:Number=0;k<MC2.newsNum;k++) {
var newsItem:NewsItem = new NewsItem;
// XML INPUT
newsItem.title.text = MC2.newsTitle[MC2.newsNum-1-k];
newsItem.content.htmlText = MC2.newsContent[MC2.newsNum-1-k];
newsItem.info.text = MC2.newsInfo[MC2.newsNum-1-k];
newsItem.positionRule();
trace(newsItem.content.textHeight);
// positioning NewsItems moveiclips
// will later be determined by XML data
if(k>0) {
  newsItem.y = newsHeight;
newsArray.push(newsItem);
// adding newsItems as children to newsContainer
newsContainer.addChild(newsItem);
newsHeight += newsItem.content.textHeight+100;
trace(k + " " + newsHeight);
// VERTICLE MOUSE_MOVE SCROLLING
stage.addEventListener(MouseEvent.MOUSE_MOVE, scrollNews);
function scrollNews(evt:MouseEvent):void {
TweenLite.to(newsContainer, 0.3, { y:-(stage.mouseY/stage.stageHeight)*newsContainer.height+ newsHeight/2});
trace(-(stage.mouseY/stage.stageHeight)*newsContainer.height);
Thanks very much kglad
Regards
Joselyn
Votes
Translate
Translate
Report
Report
Community Expert ,
which is line 65?
and
should be
var newsItem:NewsItem = new NewsItem();
Votes
Translate
Translate
Report
Report
Participant ,
Jul 20, 2012 Jul 20, 2012
Hi Kglad, Thank you for your answer, sincerelly this is  a part of a Example that I saw in the web, it loads a xml with a document class and a urlLoader class too in a mainContainer, it has a navigation of 4 buttons, I tried to separated this section because it likes to me, I was trying to do many intents to change the parameters but it doesn't works. I would like if you could tell me, if there is something wrong in the line 65 says "var MC2:MovieClip = MovieClip(this.parent);" .
I send to you the complete code,
THANKS AGAIN !! in advance for your great full.
import flash.display.StageDisplayState;
// XML LISTS //
var newsTitle:XMLList;
var newsInfo:XMLList;
var newsContent:XMLList;
var newsTitleArray:Array;
var newsInfoArray:Array;
var newsContentArray:Array;
// number of items
var newsNum:Number;
// LOAD XML //
var xml:XMLLoader = new XMLLoader(this,"data.xml");
// function called when XML is loaded
function getXML(xmlData:XML):void {
newsTitle = xmlData.news.article.title;
newsInfo = xmlData.news.article.info;
newsContent = xmlData.news.article.content;
newsNum = newsTitle.length();
//trace(projectInfo);
newsTitleArray = xmlData.news.article.title.text().toXMLString().split("\n") ;
newsTitleArray.reverse();
newsInfoArray = xmlData.news.article.info.text().toXMLString().split("\n") ;
newsInfoArray.reverse();
newsContentArray = xmlData.news.article.content.text().toXMLString().split("\n") ;
newsContentArray.reverse();
// XML //
// XML INPUT
if(k>0) {
Votes
Translate
Translate
Report
Report
Community Expert ,
this.parent is the stage, not a movieclip.  use:
// XML LISTS //
// number of items
var newsNum:Number;
// LOAD XML //
// XML //
var MC2:MovieClip = MovieClip(this);
// XML INPUT
if(k>0) {
p.s.  please mark helpful/correct responses.
Votes
Translate
Translate
Report
Report
Participant ,
Jul 23, 2012 Jul 23, 2012
LATEST
Hello kglad:
Thank you very much, i was trying to tested with this code and don't happening nothing,
now it doesn't gave me an error just appear a number 0 serveral times.
Do you believe that I can do it without this classes, load the xml in the movie clip created in
the library, and make the effects in the function "scrollNews",
I appreciate if you can gave me your advice.
Thanks again.
Joselyn
Votes
Translate
Translate
Report
Report
