Hi people. I will try and explain as simply as possible on this one...
i have the following AS2 script:
ManualPlay.onRelease = function(){
myXML.load("../../config/settings/page_list.xml");
_global.xmlVersion = assets;
trace(xmlVersion);
AutoPlay.onRelease = function(){
myXML.load("../../config/settings/page_list_auto.xml");
_global.xmlVersion = assets_auto;
trace(xmlVersion);
i then have another script that detects if the xmlVersion is assets_auto and if true stop the timeline else continue playing:
stop();
if (_global.xmlVerson == assets_auto)
trace("auto mode");
_root.gotoAndPlay(2);
else
trace("manual mode");
play();
All the traces seem to come back correct but the actions dont seem to take affect. it always goes to manual mode and the timeline continues to play.
i think i need to convert the assets_auto etc value to a string or something but i dont really understand what i need to do.
any help will be amazing thank you
If you do not have quotations around your "assets" and "assets_auto" everywhere they appear, then you probably need to, unless those are names of variables that have other values assigned somewhere else.
i tried with the "" but no luck.
They are just used do determine where to look for SWF files eg:
loadMovie("config/"+ xmlVersion +"/"+nextslide, slidePlayer);
however in my timeline there is a section i dont want to play if xmlVersion == assets_auto.
however it just keeps ignoreing this bit of script.
You should trace the value of _global.xmlVersion just before the conditional to see what it is...
stop();
trace(_global.xmlVersion)
if (_global.xmlVerson == "assets_auto")
and if you are still missing the quotes which I show above, they need to be there (the forum does remove quotes at times)
