This content has been marked as final.
Show 4 replies
1. Re: Best way to animate a line with a dot leading along a path
Ned Murphy Jul 17, 2012 10:15 AM (in response to kim shep)1 person found this helpfulYou could do a frame by frame animation. The easiest way to do it is to work the animation backwards along the timeline, removing a piece of the line (and moving the dot) in each frame and then reversing the frames when you are done.
2. Re: Best way to animate a line with a dot leading along a path
chris georgenes Jul 17, 2012 10:31 AM (in response to Ned Murphy)In addition to Kglad's suggestion, I would separate the dot from the line on to its own layer. Convert the dot to a symbol and motion tween it. As for the line, use the frame by frame method Kglad mentioned or an animated mask.
3. Re: Best way to animate a line with a dot leading along a path
Ned Murphy Jul 17, 2012 11:55 AM (in response to chris georgenes)pssst... I'm not kGlad
4. Re: Best way to animate a line with a dot leading along a path
chris georgenes Jul 17, 2012 12:47 PM (in response to Ned Murphy)Oops! I swear it showed you as Kglad when I first posted that - ok, i'm old, chaulk it up to tired eyes. Sorry Ned!!!
