4 Replies Latest reply: Jul 18, 2012 9:17 PM by Pijetro RSS
    Encore balloons  project size
    Pijetro Community Member
      Okay, so i've got 3.5 hrs of footage that came off of a JVC Everio HDD, and it's 720x480 SD.
      Encore accepts the footage as "Do not Transcode" for DVD settings.
      Realizing bitrate vs. quality, i've decided instead to create a BluRay with SD footage.
      Unfortunately, Encore CS4.0 requires transcoding when it comes to BluRay. Although it shouldn't, i've always had Encore re-encode totally compliant Mpeg2 footage.
      But this isn't my dilemna.
      My issue is, even within Encore's project settings, regardless of maximum bitrate, and with Encore doing a re-encode, the output size balloons out to 50gig.
      I've got 25 gig BD-R image selected.
      The original SD material is only 18gig in size!!!
      Any help would be appreciated. I've always had issues with Encore's Mpeg2 for BluRay compliance. But this is definately a curve ball..
      I might be forced to go to h264 on this one.
        • 1. Re: Encore balloons  project size
          Stan Jones CommunityMVP
          What are your settings for the BD transcode?
          There is a difference in the MPEG2-DVD and MPEG2-BD preset. Drawing a blank at the moment....
          • 2. Re: Encore balloons  project size
            Okay, so after many hours of toiling, i've realized that there's a bug in Encore, in where there's extra padding in the output size.
            I've transcoded to correct bitrates, and all's well. I verify filesizes within the Sources>Transcode folders.
            All assets that will be assembled into a Bluray are correct in size to the bitrates.
            I check out the build folder, and everything seems fine.
            But for some reason, Encore keeps padding the final output size. I don't know where it's coming from.
            I'm not sure about linking to outside sources, but somebody had the same issue in the Cow forums 2 years ago...
            I'll keep plugging away...
            • 3. Re: Encore balloons  project size
              Encore pads it by re-transcoding?
              Even though Encore shows it as needing transcoding, can you set it to "do not transcode"?
              If you set the build to build to a folder, does it still pad so much?
              I think that was true, but your excess sounds almost double.
              • 4. Re: Encore balloons  project size
                Here's the rundown...
                Clips that are ingested, are transcoded, as per bitrate calculator. I verified this by the size of transcode.
                Transcoded clips equal roughly same size as ingested clips...This is verified by the source>transcode folder...
                Since Encore uses this folder to build a BluRay folder, the output size should equal the transcode folder size (give or take a few megs)..
                So what starts off as a build folder of 12 gig, ends up outputting to a folder size of 33gig...
                edit:
                I've since renamed my .mod files to .mpeg, and it's looking more promising.
                However, my audio is lost.
                Gonna reboot, and get back..
