1. Re: How to know which channel is selected for the current document
MOMIR ZECEVIC Jul 18, 2012 4:20 AM (in response to Royt2011)Every channel that is selected will have keyVisible true.
Trouble is if you want to see which is selected from visible ones. I dont know for channels but it works for a layers so i suppose that it will work there too.
When you perform action or get property on a layer if you use "enumTarget" for adressing are done using currently active or selected or as implied by name default targer layer.
Now. if you want to know what is a current channel just get its name.
Here is an example how to hide current layer and any layer using index.
Unfortunately i have no time at the moment to writte exact cod that you need, but if this do not help post here and i will try to do when i can.
N
Hope this helps.
Momir Zecevic
Example
// HideCurrentLayer
SPErr AMAutoPlugin::HideCurrentLayer(void)
SPErr error = kSPNoError;
PIActionDescriptor result = NULL;
PIActionDescriptor tempDescriptor = NULL;
PIActionList tempList = NULL;
PIActionReference tempReference = NULL;
error = sPSActionDescriptor->Make(&tempDescriptor);
if (error) goto returnError;
error = sPSActionList->Make(&tempList);
error = sPSActionReference->Make(&tempReference);
error = sPSActionReference->PutEnumerated(tempReference, classLayer, typeOrdinal, enumTarget); //enumTarget - currently
if (error) goto returnError; //active -selected
error = sPSActionList->PutReference(tempList, tempReference);
error = sPSActionDescriptor->PutList(tempDescriptor, keyNull, tempList);
error = sPSActionControl->Play(&result, eventHide, tempDescriptor, plugInDialogSilent);
returnError:
if (result != NULL) sPSActionDescriptor->Free(result);
if (tempDescriptor != NULL) sPSActionDescriptor->Free(tempDescriptor);
if (tempList != NULL) sPSActionList->Free(tempList);
if (tempReference != NULL) sPSActionReference->Free(tempReference);
return error;
// HideLayerByIndex
SPErr AMAutoPlugin::HideLayerByIndex(int32 index)
error = sPSActionReference->PutIndex(tempReference, classLayer, index);
returnError:
return error;
2. Re: How to know which channel is selected for the current document
Royt2011 Jul 19, 2012 12:19 AM (in response to MOMIR ZECEVIC)Thank you.
The 'enumTarget' means currently selected things (layer, channel, etc.), so I tried the code below. And then I could get the seleted channel's index through keyword 'keyItemIndex'. If there are multi channels selected the 'Get' method won't be executed successfully.
I just write similar code applying to layers, if mult layers selected, the 'Get' method can run successfuly, but only one value(a selected layer's index) can be fetched. Is there any other keyword corresponding to a list or array that contains all selected indexes?
SPErr NestD::GetSelectedChannels(int32 *channelIndex)
PIActionReference ref = NULL;
Boolean hasKey;
error = sPSActionReference->Make(&ref);
error = sPSActionReference->PutProperty(ref, classProperty, keyItemIndex);
error = sPSActionReference->PutEnumerated(ref, classChannel, typeOrdinal, enumTarget);
error = sPSActionControl->Get(&result, ref);
error = sPSActionDescriptor->HasKey(result, keyItemIndex, &hasKey);
if (error || !hasKey) goto returnError;
error = sPSActionDescriptor->GetInteger(result, keyItemIndex, channelIndex);
returnError:
if (result) sPSActionDescriptor->Free(result);
if (ref) sPSActionReference->Free(ref);
return error;
