1 Reply Latest reply: Jul 21, 2012 6:14 AM by Alain Mazy RSS
    Real MultiThreading by Concurrency Workers Tutorial
    Alain Mazy Community Member
      Here, found a tutoriel for using Worker(s)
      (in french)
      http://www.covergraph.com/blog/
        • 1. Re: Real MultiThreading by Concurrency Workers Tutorial
          Hi, i tested shared byteArray in worker but with use High Premium feature (with fastMem Azoth) it's don't work! .. I dont no why, but probably beacause memory mecanism in shareable is incompatible..
          Other, if créeate worker in main code (not a external SWF) the function "bpm" is not invoqued! when if is in private or public declaration.. :S it's logic ! it's too dinamic.
          private function workerMessageHandler(e:Event):void
                         this[inChannel.receive()]; // receiveData contain: "getBpm"
          public function getBpm():void
                         var bpm:int = BPM.get(sharedMem);
                         outChannel.send(String(bpm));
          The worker is not verry simple ..
          should be an instruction to tell the player that foncion or property must be in worker. Like:
          public worker function (..) {...}
          Actual system necessary call each method in a switch case based on receive() value in workerInputHandler. or making a swf for worker..
