7 Replies Latest reply on Jul 23, 2012 11:13 PM by c.pfaffenbichler
    script for "save for web" with multiple versions/resolutions?
    ItsGregHere Level 1
      Would anyone have a script (javascript would be nice, else applescript) that helps automate "save to web".   What I need is the following, but even something close that would give me a leg up re scripting would be good:
      * saves 3 versions of the open PSD file to a defined (in the script) directory based on 3 different resolutions
      * the 3 resolutions could be hard coded in the script (or else percentages hardcoded)
      * ability in the script to put in the basic save to web parameters (e.g. PNG-24, etc)
      * the filename the files would get saved as to be:
      * if file already exists then overwrite this
      thanks
        • 1. Re: script for "save for web" with multiple versions/resolutions?
          ItsGregHere Level 1
          I have it working here BUT I'm having to change the image size itself prior to doing the "save for web" and then "undo" after this.  Any way to avoid doing this?  I can't see in "save for web" that you can specify the sizes?
          What I current have:
          // Setup
          doc = app.activeDocument;
          function saveForWeb(width, height, fileSuffix) {
                    // Start point for single history item - so can undo whole script (to remove resizing)
                    savedState = doc.activeHistoryState
                    // Resize   (work around as can't see how to do this in the ExportOptionsSaveForWeb option below?)
                    doc.resizeImage(UnitValue(width,"px"),UnitValue(height,"px"),null,ResampleMethod.BIC UBIC);
                    // Save as Web
                    var options = new ExportOptionsSaveForWeb();   // ISSUE: No Resolution/SizeOption here?
                    options.format = SaveDocumentType.PNG;
                    options.optimized = true;
                    options.PNG8 = false;
                    doc.exportDocument(File(doc.path+'/'+doc.name + fileSuffix + '.png'),  ExportType.SAVEFORWEB,  options);
                    // Undo
                    doc.activeHistoryState = savedState
          saveForWeb(512,  352,  ""  )
          saveForWeb(1024, 704,  "_2")
          saveForWeb(2048, 1408, "_3")
          • 2. Re: script for "save for web" with multiple versions/resolutions?
            c.pfaffenbichler Level 9
            You may want to familiarize yourself with using »ScriptingListener.plugin« to get non-DOM-code.
            This should also convert to sRGB, but you can try to correct it or record the code yourself.
            #target photoshop
            // Setup
            var originalRulerUnits = app.preferences.rulerUnits;
            app.preferences.rulerUnits = Units.PIXELS;
            var basename = doc.name.match(/(.*)\.[^\.]+$/)[1];
            var thePercentage = width / doc.width * 100;
            var theFile = basename + fileSuffix + ".png";
            var idExpr = charIDToTypeID( "Expr" );
                var desc2 = new ActionDescriptor();
                var idUsng = charIDToTypeID( "Usng" );
                    var desc3 = new ActionDescriptor();
                    var idOp = charIDToTypeID( "Op  " );
                    var idSWOp = charIDToTypeID( "SWOp" );
                    var idOpSa = charIDToTypeID( "OpSa" );
                    desc3.putEnumerated( idOp, idSWOp, idOpSa );
                    var idDIDr = charIDToTypeID( "DIDr" );
                    desc3.putBoolean( idDIDr, true );
                    var idIn = charIDToTypeID( "In  " );
                    desc3.putPath( idIn, new File( doc.path ) );
                    var idovFN = charIDToTypeID( "ovFN" );
                    desc3.putString( idovFN, theFile );
                    var idFmt = charIDToTypeID( "Fmt " );
                    var idIRFm = charIDToTypeID( "IRFm" );
                    var idPNtwofour = charIDToTypeID( "PN24" );
                    desc3.putEnumerated( idFmt, idIRFm, idPNtwofour );
                    var idIntr = charIDToTypeID( "Intr" );
                    desc3.putBoolean( idIntr, false );
                    var idTrns = charIDToTypeID( "Trns" );
                    desc3.putBoolean( idTrns, true );
                    var idMtt = charIDToTypeID( "Mtt " );
                    desc3.putBoolean( idMtt, false );
                    var idMttR = charIDToTypeID( "MttR" );
                    desc3.putInteger( idMttR, 255 );
                    var idMttG = charIDToTypeID( "MttG" );
                    desc3.putInteger( idMttG, 255 );
                    var idMttB = charIDToTypeID( "MttB" );
                    desc3.putInteger( idMttB, 255 );
                    var idHScl = charIDToTypeID( "HScl" );
                    var idPrc = charIDToTypeID( "#Prc" );
                    desc3.putUnitDouble( idHScl, idPrc, thePercentage );
                    var idVScl = charIDToTypeID( "VScl" );
                    desc3.putUnitDouble( idVScl, idPrc, thePercentage );
                    var idSHTM = charIDToTypeID( "SHTM" );
                    desc3.putBoolean( idSHTM, false );
                    var idSImg = charIDToTypeID( "SImg" );
                    desc3.putBoolean( idSImg, true );
                    var idSWsl = charIDToTypeID( "SWsl" );
                    var idSTsl = charIDToTypeID( "STsl" );
                    var idSLAl = charIDToTypeID( "SLAl" );
                    desc3.putEnumerated( idSWsl, idSTsl, idSLAl );
                    var idSWch = charIDToTypeID( "SWch" );
                    var idSTch = charIDToTypeID( "STch" );
                    var idCHsR = charIDToTypeID( "CHsR" );
                    desc3.putEnumerated( idSWch, idSTch, idCHsR );
                    var idSWmd = charIDToTypeID( "SWmd" );
                    var idSTmd = charIDToTypeID( "STmd" );
                    var idMDCC = charIDToTypeID( "MDCC" );
                    desc3.putEnumerated( idSWmd, idSTmd, idMDCC );
                    var idohXH = charIDToTypeID( "ohXH" );
                    desc3.putBoolean( idohXH, false );
                    var idohIC = charIDToTypeID( "ohIC" );
                    desc3.putBoolean( idohIC, true );
                    var idohAA = charIDToTypeID( "ohAA" );
                    desc3.putBoolean( idohAA, true );
                    var idohQA = charIDToTypeID( "ohQA" );
                    desc3.putBoolean( idohQA, true );
                    var idohCA = charIDToTypeID( "ohCA" );
                    desc3.putBoolean( idohCA, false );
                    var idohIZ = charIDToTypeID( "ohIZ" );
                    desc3.putBoolean( idohIZ, true );
                    var idohTC = charIDToTypeID( "ohTC" );
                    var idSToc = charIDToTypeID( "SToc" );
                    var idOCzerothree = charIDToTypeID( "OC03" );
                    desc3.putEnumerated( idohTC, idSToc, idOCzerothree );
                    var idohAC = charIDToTypeID( "ohAC" );
                    desc3.putEnumerated( idohAC, idSToc, idOCzerothree );
                    var idohIn = charIDToTypeID( "ohIn" );
                    desc3.putInteger( idohIn, -1 );
                    var idohLE = charIDToTypeID( "ohLE" );
                    var idSTle = charIDToTypeID( "STle" );
                    var idLEzerothree = charIDToTypeID( "LE03" );
                    desc3.putEnumerated( idohLE, idSTle, idLEzerothree );
                    var idohEn = charIDToTypeID( "ohEn" );
                    var idSTen = charIDToTypeID( "STen" );
                    var idENzerozero = charIDToTypeID( "EN00" );
                    desc3.putEnumerated( idohEn, idSTen, idENzerozero );
                    var idolCS = charIDToTypeID( "olCS" );
                    desc3.putBoolean( idolCS, false );
                    var idolEC = charIDToTypeID( "olEC" );
                    var idSTst = charIDToTypeID( "STst" );
                    var idSTzerozero = charIDToTypeID( "ST00" );
                    desc3.putEnumerated( idolEC, idSTst, idSTzerozero );
                    var idolWH = charIDToTypeID( "olWH" );
                    var idSTwh = charIDToTypeID( "STwh" );
                    var idWHzeroone = charIDToTypeID( "WH01" );
                    desc3.putEnumerated( idolWH, idSTwh, idWHzeroone );
                    var idolSV = charIDToTypeID( "olSV" );
                    var idSTsp = charIDToTypeID( "STsp" );
                    var idSPzerofour = charIDToTypeID( "SP04" );
                    desc3.putEnumerated( idolSV, idSTsp, idSPzerofour );
                    var idolSH = charIDToTypeID( "olSH" );
                    desc3.putEnumerated( idolSH, idSTsp, idSPzerofour );
                    var idolNC = charIDToTypeID( "olNC" );
                        var list1 = new ActionList();
                            var desc4 = new ActionDescriptor();
                            var idncTp = charIDToTypeID( "ncTp" );
                            var idSTnc = charIDToTypeID( "STnc" );
                            var idNCzerozero = charIDToTypeID( "NC00" );
                            desc4.putEnumerated( idncTp, idSTnc, idNCzerozero );
                        var idSCnc = charIDToTypeID( "SCnc" );
                        list1.putObject( idSCnc, desc4 );
                            var desc5 = new ActionDescriptor();
                            var idNConenine = charIDToTypeID( "NC19" );
                            desc5.putEnumerated( idncTp, idSTnc, idNConenine );
                        list1.putObject( idSCnc, desc5 );
                            var desc6 = new ActionDescriptor();
                            var idNCtwoeight = charIDToTypeID( "NC28" );
                            desc6.putEnumerated( idncTp, idSTnc, idNCtwoeight );
                        list1.putObject( idSCnc, desc6 );
                            var desc7 = new ActionDescriptor();
                            var idNCtwofour = charIDToTypeID( "NC24" );
                            desc7.putEnumerated( idncTp, idSTnc, idNCtwofour );
                        list1.putObject( idSCnc, desc7 );
                            var desc8 = new ActionDescriptor();
                            desc8.putEnumerated( idncTp, idSTnc, idNCtwofour );
                        list1.putObject( idSCnc, desc8 );
                            var desc9 = new ActionDescriptor();
                            desc9.putEnumerated( idncTp, idSTnc, idNCtwofour );
                        list1.putObject( idSCnc, desc9 );
                    desc3.putList( idolNC, list1 );
                    var idobIA = charIDToTypeID( "obIA" );
                    desc3.putBoolean( idobIA, false );
                    var idobIP = charIDToTypeID( "obIP" );
                    desc3.putString( idobIP, "\"\"\"\"" );
                    var idobCS = charIDToTypeID( "obCS" );
                    var idSTcs = charIDToTypeID( "STcs" );
                    var idCSzeroone = charIDToTypeID( "CS01" );
                    desc3.putEnumerated( idobCS, idSTcs, idCSzeroone );
                    var idovNC = charIDToTypeID( "ovNC" );
                        var list2 = new ActionList();
                            var desc10 = new ActionDescriptor();
                            var idNCzeroone = charIDToTypeID( "NC01" );
                            desc10.putEnumerated( idncTp, idSTnc, idNCzeroone );
                        list2.putObject( idSCnc, desc10 );
                            var desc11 = new ActionDescriptor();
                            var idNCtwozero = charIDToTypeID( "NC20" );
                            desc11.putEnumerated( idncTp, idSTnc, idNCtwozero );
                        list2.putObject( idSCnc, desc11 );
                            var desc12 = new ActionDescriptor();
                            var idNCzerotwo = charIDToTypeID( "NC02" );
                            desc12.putEnumerated( idncTp, idSTnc, idNCzerotwo );
                        list2.putObject( idSCnc, desc12 );
                            var desc13 = new ActionDescriptor();
                            desc13.putEnumerated( idncTp, idSTnc, idNConenine );
                        list2.putObject( idSCnc, desc13 );
                            var desc14 = new ActionDescriptor();
                            var idNCzerosix = charIDToTypeID( "NC06" );
                            desc14.putEnumerated( idncTp, idSTnc, idNCzerosix );
                        list2.putObject( idSCnc, desc14 );
                            var desc15 = new ActionDescriptor();
                            desc15.putEnumerated( idncTp, idSTnc, idNCtwofour );
                        list2.putObject( idSCnc, desc15 );
                            var desc16 = new ActionDescriptor();
                            desc16.putEnumerated( idncTp, idSTnc, idNCtwofour );
                        list2.putObject( idSCnc, desc16 );
                            var desc17 = new ActionDescriptor();
                            desc17.putEnumerated( idncTp, idSTnc, idNCtwofour );
                        list2.putObject( idSCnc, desc17 );
                            var desc18 = new ActionDescriptor();
                            var idNCtwotwo = charIDToTypeID( "NC22" );
                            desc18.putEnumerated( idncTp, idSTnc, idNCtwotwo );
                        list2.putObject( idSCnc, desc18 );
                    desc3.putList( idovNC, list2 );
                    var idovCM = charIDToTypeID( "ovCM" );
                    desc3.putBoolean( idovCM, false );
                    var idovCW = charIDToTypeID( "ovCW" );
                    desc3.putBoolean( idovCW, false );
                    var idovCU = charIDToTypeID( "ovCU" );
                    desc3.putBoolean( idovCU, true );
                    var idovSF = charIDToTypeID( "ovSF" );
                    desc3.putBoolean( idovSF, true );
                    var idovCB = charIDToTypeID( "ovCB" );
                    desc3.putBoolean( idovCB, true );
                    var idovSN = charIDToTypeID( "ovSN" );
                    desc3.putString( idovSN, """images""" );
                var idSaveForWeb = stringIDToTypeID( "SaveForWeb" );
                desc2.putObject( idUsng, idSaveForWeb, desc3 );
            executeAction( idExpr, desc2, DialogModes.NO );
            app.preferences.rulerUnits = originalRulerUnits;
            • 3. Re: script for "save for web" with multiple versions/resolutions?
              ItsGregHere Level 1
              thanks c.pfaffenbichler,
              how does this approach (which seems to use executeAction) compare to the one I'm using from the API's i.e. exportDocument?  would the executeAction approach be able to export for web without having to manually resize the image before hand?   which is what I was finding I was having to do based on using "exportDocument...
              • 4. Re: script for "save for web" with multiple versions/resolutions?
                Have you tested the code?
                • 5. Re: script for "save for web" with multiple versions/resolutions?
                  Your Script uses the Document Object Model while the sfw-part in the one I posted uses ActionDescriptor code that was recorded with ScriptingListener.plugin.
                  This way some features can be addressed that are beyond the DOM directly.
                  • 6. Re: script for "save for web" with multiple versions/resolutions?
                    ItsGregHere Level 1
                    (oh - the thread alert email for this got stuck in spam somehow)
                    thanks - so it kind of seems like there are two levels of programming, the DOM (which seems more like the formal API level) and this ActionDescriptor code (which kind of seems like it working more at the GUI level of the app rather than the underlying API).  I'll keep this in mind and try when I get a chance.  Re the DOM method then I'm guessing there is no way to avoid the "change the image size itself prior to doing the "save for web"" then.
                    • 7. Re: script for "save for web" with multiple versions/resolutions?
                      The Object Model Viewer in ExtendScript Toolkit seems to list no properties for resizing for ExportOptionsSaveForWeb, so as far as I can tell using the DOM would indeed necessitate resizing the image before exporting.
