3 Replies Latest reply on Jul 20, 2012 1:22 PM by Ned Murphy
    go to specific location
    alaStickman Level 1
      hello,
      if i have a movie clip with those X,Y cordinate (100,100) and i want him to go to (300,200) but i want to see him "walking" till he reach the location with a constant speed .
      how can i do it ?
      thank you
        • 1. Re: go to specific location
          There are a couple ways you can move an object using actionscript.
          One is to use the Tween class or a third party tweening class such as Tweenlite.
          Another is to use enterFrame processing to have the object's _X and _y coordinates gradually increase to the final values at constant increments (in the sample code below "yourMC would be replaced with the instance name of your movieclip).
          var stepsize = 2; // adjust as desired for speed
          this.onEnterFrame = function(){
               if(yourMC._x >= 300){
                     delete this.onEnterFrame;
               } else {
                     yourMC._x += 2*stepsize;
                     yourMC._y += stepsize;
          As far as the walking goes, you would need to have the movieclip do the animation of the stepping.
          • 2. Re: go to specific location
            alaStickman Level 1
            thank you it's exactly what i need
            about this :
            " delete this.onEnterFrame;"
            it mean that if the condition is correct then stop running the function ??
            thank you again
            • 3. Re: go to specific location
              Yes, in this case if the value of x is equal or greater than the final value (300) then that line of code will stop the enterframe function from working.
