1 Reply Latest reply on Feb 15, 2008 12:43 PM by Gregory Lafrance
    Setting Up Flex
    ayuso_15
      I'm getting started with Flex and I want to know how can you publish your project in the web. Instead of using Index.html you need to use .mxml (main) or you have to add it as a component in the HTML file.
        • 1. Re: Setting Up Flex
          Gregory Lafrance Level 6
          You can't just put mxml files on the web unless you are using LifeCycle Data Services (formerly Flex DS), which allows you compile when the app is requested. So if you aren't using LSDS, you need to compile the MXML to a SWF and either wrap it in an HTML file, or access the SWF directly (not the preferable way).
