0 Replies Latest reply on Jul 21, 2012 12:18 AM by 999philip wa.
    Sites using Flash crash unless IE9 is run as administrator on Win7
    999philip wa. Level 1
      "suddenly" my IE9 (32-bit edition on Win7 Prof. 64 bit) was hanging (page tab freezes) on several web pages. Some hours later I found out that when I deactivated the Flash Player ActiveX Add-On, everything was fine again. This is reproducable.
      When I right-click IE9 and run it as administrator, the Flash Player and websites will work.
      I've tried kind of everything to fix this, otherwise I wouldn't post here.
      - I reset m IE9 to default settings, erased all caches etc.
      - I've run the Adobe Flash Player uninstaller, cleaned some directories according to various manuals and so on. I've even thried a registry cleanup batch provided by Adobe.
      - But then, when I try to re-install the plug-in (e.g. via http://get.adobe.com/de/flashplayer/), the installer won't even execute unless I download it manually and run the install as administrator.
      - My UAC on Windows is unchanged and set to defaults. MS Security Essentials is not the problem either, and I don't run any additional bloatware.
      - The plug-in for FF doesn't work either.
      What can I do?
