2 Replies Latest reply on Feb 15, 2008 5:20 AM by andyulrika_is_back
    Playing Quicktime with Multiple Start End Points
    andyulrika_is_back
      Hello
      I posted a message a few days which I received help on regarding starting and ending a Quicktime movie from various points in the movie. Now I have a new problem which I cannot fix at all..
      Here is the problem:
      I have a Quicktime movie on stage and 10 various buttons that contain a generic script which allows input of start and end points for each button to trigger the movie. Initially just doing this with one button is successful.
      However, multiple buttons all with the same generic code make the movie freeze up completely. My guess is that they are all fighting each other for control. Maybe I need something in the code which allows the button that is being used to play the movie to keep control.
      Here is the code I use for each button, the movie is on frame 15.
      property pQT,pStart,pEnd,pFrame, pVolume
      on beginSprite me
      sprite(me.spriteNum).color=rgb (255,255,255)
      cursor 0
      if integer(pQT).ilk=#integer then pQT=integer(pQT)
      end
      on mouseUp me
      sound(3).volume=sprite(15).volume
      sprite(15).volume=pVolume
      sprite(pQT).movieTime=pStart
      sprite(pQT).movieRate=1
      cursor 0
      end
      on mouseEnter me
      sprite(me.spriteNum).color=rgb (173,24,41)
      sprite(me.spriteNum).cursor=280
      end
      on mouseLeave me
      sprite(me.spriteNum).color=rgb(255,255,255)
      sprite(me.spriteNum).cursor=0
      end
      on mouseDown me
      sprite(me.spriteNum).cursor=290
      end
      on enterFrame me
      if sprite(pQT).movieTime>=pEnd then
      sprite(pQT).movieRate=0
      end if
      end
      on getPropertyDescriptionList me
      if not the currentSpriteNum then exit
      vPDList=[:]
      setaProp vPDList, #pQT, [#comment: "Which QT sprite", #format: #integer, #default: 0]
      setaProp vPDList, #pStart, [#comment: "Range start", #format: #integer, #default: 0]
      setaProp vPDList, #pEnd, [#comment: "Range end", #format: #integer, #default: 0]
      setaProp vPDList, #pVolume, [#comment: "Volume", #format: #integer, #default: 0]
      return vPDList
      end getPropertyDescriptionList
      Any help is much appreciated. (not a lingo expert)
      Andy
        • 1. Re: Playing Quicktime with Multiple Start End Points
          Level 7
          You need for each button to know if it was pushed or not. And only
          monitor the current time of the QT movie if it was the button pushed...
          like this (once again, look out for inadvertent line breaks... there
          should be exactly 66 lines of code here):
          property pQT,pStart,pEnd,pFrame, pVolume,pMyControl
          on beginSprite me
          cursor 0
          pMyControl=0
          end
          on mouseUp me
          sound(3).volume=sprite(pQT).volume
          sprite(pQT).volume=pVolume
          pMyControl=1
          cursor 0
          end
          on mouseEnter me
          end
          on mouseLeave me
          end
          on mouseDown me
          end
          on enterFrame me
          if pMyControl then
          pMyControl=0
          go 1
          end if
          end if
          end
          vPDList=[:]
          setaProp vPDList, #pQT, [#comment:"Which QT sprite", #format:#string,
          #default:0]
          setaProp vPDList, #pStart, [#comment:"Range start", #format:#integer,
          #default:0]
          setaProp vPDList, #pEnd, [#comment:"Range end", #format:#integer,
          #default:0]
          setaProp vPDList, #pVolume, [#comment:"Volume", #format:#integer,
          #default:0]
          return vPDList
          • 2. Re: Playing Quicktime with Multiple Start End Points
            andyulrika_is_back Level 1
            Many thanks Mike
            Works fantastically.
            I just thought I would post the finished code - well, tweaked ever so slightly from Mike's orginal for anybody wanting a nice little behaviour for controlling a Quicktime movie.
            (watch out for page breaks etc - should be 68 lines)
            property pQT,pStart,pEnd,pFrame, pVolume,pMyControl,pReturnMarker
            on beginSprite me
            cursor 0
            pMyControl=0
            end
            on mouseUp me
            pMyControl=1
            cursor 0
            end
            on mouseEnter me
            end
            on mouseLeave me
            end
            on mouseDown me
            end
            on enterFrame me
            if pMyControl then
            pMyControl=0
            go pReturnMarker
            end if
            end if
            end
            vPDList=[:]
            setaProp vPDList, #pQT, [#comment:"Which QT sprite", #format:#string, #default:0]
            setaProp vPDList, #pStart, [#comment:"Range start", #format:#integer, #default:0]
            setaProp vPDList, #pEnd, [#comment:"Range end", #format:#integer, #default:0]
            setaProp vPDList, #pVolume, [#comment:"Volume", #format:#volume, #default:0]
            setaProp vPDList, #pReturnMarker, [#comment:"Return to Marker", #format:#marker, #default:0]
            return vPDList
