4 Replies Latest reply on Feb 15, 2008 11:01 AM by Newsgroup_User
    Is it possible to send a text message using the UDP protocol?
    Level 7
      Support doc
      http://www.adobe.com/support/director/multiuser/using_udp/using_udp02.html
      says to use the following format with connectToNetServer:
      errCode = gMultiuserInstance.connectToNetServer([#remoteAddress:
      "chatServer.myCompany.com", #logonInfo: [#userID: "Bob", #password:
      "MySecret", #movieID: "Tech Chat"], #mode: #smus, #localUDPPort: 1627,
      #localAddress: "123.45.67.89", #remoteTCPPort: 1626])
      But if I change the mode to #text, it still sends out messages as smus.
      In fact, if I leave out the UDP parameters altogether but still use the
      list parameters for connectToNetServer, it still always sends as smus.
      Sends as smus:
      "MySecret", #movieID: "Tech Chat"], #mode: #text, #localUDPPort: 1627,
      Sends as smus:
      "MySecret", #movieID: "Tech Chat"], #mode: #text])
      Only the string parameter method can be made to send text messages.
      Sends as text:
      errCode = gMultiuserInstance.connectToNetServer("Bob", "MySecret",
      "chatServer.myCompany.com", 1626, "Tech Chat", 1)
      Am I missing something? Is this a known issue? Anyone have a work around?
      -Jeremy
        • 1. Re: Is it possible to send a text message using the UDP protocol?
          Level 7
          And the question is?
          "Jeremy Aker" <jeremy@uthd.com> wrote in message
          news:fp212i$f9r$1@forums.macromedia.com...
          > Support doc
          > But if I change the mode to #text, it still sends out messages as smus. In
          > fact, if I leave out the UDP parameters altogether but still use the list
          > Sends as smus:
          > Sends as smus:
          > Sends as text:
          > -Jeremy
          • 2. Re: Is it possible to send a text message using the UDP protocol?
            Level 7
            I'm really sorry that I wasn't clear enough. I'll repeat the questions
            more concisely.
            Is it possible to send a text message using the UDP protocol? If so, how?
            Is the bug I described in my original message (see below) really a bug
            or am I doing something wrong?
            If it's a bug, does anyone have a work around?
            >> Support doc
            >> Sends as smus:
            >> Sends as smus:
            >> Sends as text:
            >> -Jeremy
            • 3. Re: Is it possible to send a text message using the UDP protocol?
              Level 7
              The multiuserXtra supports either tcp text or tcp smus connections.
              The ability to send udp messages was an expansion to the original mus
              protocol/xtra and is valid only for muXtra instances already connected in
              smus mode.
              So, if you are asking if you can create a udp instance and use it at will
              (exchange udp messages with some remote udp socket), then the answer is no.
              news:fp49oj$16f$1@forums.macromedia.com...
              > more concisely.
              > Is the bug I described in my original message (see below) really a bug or
              >>> Support doc
              >>> Sends as smus:
              >>> Sends as smus:
              >>> Sends as text:
              >>> around?
              >>> -Jeremy
              • 4. Re: Is it possible to send a text message using the UDP protocol?
                Level 7
                Drat!
                Thanks for the answer though.
                > smus mode.
                >> more concisely.
                >>>> Support doc
                >>>> Sends as smus:
                >>>> Sends as smus:
                >>>> Sends as text:
                >>>> around?
                >>>> -Jeremy
