1. Re: CS5 prints too light using new Mac, perfect from older Mac?
gator soup Jul 22, 2012 7:37 PM (in response to *Rich*)you don't mention your workflow settings, see
after that you will likely need to post your own series of screenshots
2. Re: CS5 prints too light using new Mac, perfect from older Mac?
gator soup Jul 22, 2012 7:39 PM (in response to gator soup)sorry, i thought you were ok on cs5 but bad on cs6, here is cs5
3. Re: CS5 prints too light using new Mac, perfect from older Mac?
*Rich* Jul 22, 2012 7:47 PM (in response to gator soup)Thanks gator soup, but does workflow steps really matter since the settings are exactly the same between the two computers. The only difference is the older Mac has PS v12.03, which works fine, and the newer Mac is running PS v. 12.1.
4. Re: CS5 prints too light using new Mac, perfect from older Mac?
gator soup Jul 22, 2012 8:50 PM (in response to *Rich*)Ps update is 12.0.4 and 12.1, but you are probably missing something, by posting screenshots someone may be able to spot the problem
are you sure which one is actually wrong
do they display identical in both OSes
are both versions of Ps using the same embedded profile, did you confirm that
5. Re: CS5 prints too light using new Mac, perfect from older Mac?
*Rich* Jul 22, 2012 8:53 PM (in response to gator soup)The older Mac running PS 12.0.3 is the color calibrated system that I have been using for two years w/o issue. The new system, running PS 12.1 is printing the same files too light -- all settings the same, and printer drivers the same. Thanks, your link is great resource for review.
