4 Replies Latest reply on Jul 30, 2012 7:38 AM by grace-glory
    How to resize original image that received from server
    grace-glory
      Hi Helper's,
      I'm getting error on time of resizing image such as "Error #2030: End of file was encountered". I want to resize as per specified size. Code is written in Flash builder 4.5. Please find my code below and help me to correct.
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
                     initialize="initNew()" xmlns:local="*">
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  import mx.controls.Alert;
                  import mx.graphics.codec.JPEGEncoder;
                  private const image_path:String = "sample.jpeg";
                  private var loader:Loader;
                  private var request:URLRequest;
                  private var loadBD:BitmapData;
                  private var cropBD:BitmapData;
                  private var squareW: int = 75;
                  private var squareH: int = 100;
                  private function initNew():void
                      loader=new Loader();
                      request=new URLRequest(image_path);
                      loader.contentLoaderInfo.addEventListener(
                          Event.COMPLETE,onComplete);
                      loader.load(request);
                  private function onComplete(event:Event):void {
                      try
                          loadBD = Bitmap(event.currentTarget.content).bitmapData;
                          var bitmapData:BitmapData = new BitmapData(squareW, squareH, true, 0);
                          bitmapData.draw(loadBD);
      //Getting error in this line
                          var ba:ByteArray = (new JPEGEncoder()).encodeByteArray(bitmapData.getPixels(new Rectangle(0, 0, squareH, squareH)), squareH, squareH, true);
                          ba.position = 0;
                          imgResized.source = ba;
                      catch(e:Error)
                          Alert.show(e.message);
          </fx:Script>
          <s:BorderContainer id="bcImage" width="75" height="100" maxWidth="59" borderWeight="1" borderColor="red">
              <s:Image id="imgResized" width="100%" height="100%"/>
          </s:BorderContainer>
      </s:Application>
      If anyone faced similar kind of problem?
        • 1. Re: How to resize original image that received from server
          drkstr_1 Level 4
          Is there a specific reason why using a BitmapImage would not work for your use case? If you are worried about the overhead, I would take a look at the source and copy out the bits you need. One thing I noticed after looking at the source is that they do not use any kind of encoder to perform that functionality. Is there a specific reason you need this?
          • 2. Re: How to resize original image that received from server
            grace-glory Level 1
            Thanks for your reply and happy to see you.
            No reason, I got above code When I google it and changed accordinaly to meet req. My requirement is, server will be giving 400*350 (Byte array) size image. That one what to resize into 75*100 and apply it to image component. I'm fine with any approarch, however if the image size is less than 75*100, then should not stretch the image. I have tried with fillMode (BitmapFillMode.CLIP), scaleMode(BitmapScaleMode.LETTERBOX). Please update your concern on same.
            Note: Plz ignore this maxWidth="59" property in BorderContainer property.
            • 3. Re: How to resize original image that received from server
              komal harkut
              Please try replacing the Image declaration line with the one as follows:
              <s:Image  id="imgResized" width="100%" height="100%" scaleMode="stretch" maintainProjectionCenter="false"/>
              It might be helpful to resize the original image. And let me know if it works or not!
              • 4. Re: How to resize original image that received from server
                grace-glory Level 1
                Thanks for reply. I dont want to stretch the image. if it's image size is less than specified, then it will be streching and no quality.
