1. Re: 3d layer alignment
Rick Gerard Jul 23, 2012 2:09 PM (in response to francopolato)Just make the layer a 2D layer that's comp sized.
If you must have a 3D layer then you'll have to auto orient the layer to the camera (Layer>Transform>Auto Orient) and tie scale to the distance between the camera and the layer. From your description, all you have to do is turn off the 3D option for the layer.
2. Re: 3d layer alignment
Todd_KoprivaJul 23, 2012 4:45 PM (in response to Rick Gerard)
1 person found this helpfulRick is right, but I'll add a useful command for exactly centering a layer in a 3D view:
To move selected layers so that their anchor points are at the center in the current view, choose Layer > Transform > Center In View or press Ctrl+Home (Windows) or Command+Home (Mac OS).
3. Re: 3d layer alignment
francopolato Jul 24, 2012 4:58 AM (in response to Todd_Kopriva)yes I did both of them but they didn't work correctly because the camera is rotated and when I center in View it doesn't affect the rotation of the layer I wont to coincide with the camera. Morover centering in view change de Z axis ( distance) that I want it to be 0. (fig 2)
I neet the layer to be 3d and not 2d.
when I set the layer oriented toward camera when the view is trough the camera in question the solid place itself in a strange manner. (fig 1)
even if I set both of the command the layer won't be aligned properly.
here is two picture
4. Re: Complicated rig removal... running out of ideas...
Rick Gerard Jul 24, 2012 7:50 AM (in response to francopolato)1 person found this helpfulThanks for chiming in Mathias.
Painting out the deck chairs is going to require careful hand work if the shot has any significant movement. Automating a clone is going to be real tough. Offsetting in time (another neat trick with Mocha made easier with Mathias' nifty AE scripts) is going to be difficult because of the foreground objects.
This points out the great danger all VFX artists run into when we promise something before we see the shot or, worse yet, promise something without being part of the production planning. That's why the big boys hire VFX supervisors. It takes a lot of experience to know what can be done in a reasonable amount of time and on a reasonable budget.
