5 Replies Latest reply on Jul 25, 2012 11:50 PM by Shadowfax
    Index of array based on value
    Shadowfax Level 1
      Is there any inbuilt method to get the index of a \n array by its value (in JSX). It seems that indexOf doesn't work here as in javascript..
        • 1. Re: Index of array based on value
          Vamitul Level 4
          nope!
          i use this:
          Array.prototype.findIndex = function (value)
                    var ctr = "";
                    for (var i = 0; i < this.length; i++)
                              // use === to check for Matches. ie., identical (===), ;
                              if (this[i] == value)
                                        return i;
                    return ctr;
          don't know from who i got this snippet, but lots and lots of thanks
          • 2. Re: Index of array based on value
            Harbs. Level 6
            JSX is based on an older version of ECMAScript. indexOf did not used to exist for Arrays.
            Here's an implementation that's equivalent to the javascript version:
            Array.prototype.indexOf = function (elem, fromIndex){
                fromIndex = fromIndex || 0;
                for(var i = fromIndex; i < this.length; i++){
                    if(this[i] == elem){
                        return i;
                return -1;
            There's a problem with Vamitul's version in that it returns a blank string if the index is not found, but it returns a number if it is. That makes it difficult to determine if the index is found or not. With the standard implementation you test for index < 0 to determine if the element is not found.
            Harbs
            • 3. Re: Index of array based on value
              Harbs. Level 6
              Here's a more robust version which supports negative indices as well:
                  fromIndex = Number(fromIndex) || 0;
                  var len = this.length;
                  if (fromIndex < 0){
                      fromIndex += len;
                  for(var i=fromIndex;i<this.length;i++){
                          return i;
                  return -1;
              • 4. Re: Index of array based on value
                Harbs. Level 6
                FWIW, here's the implementation recommended by Mozilla (which has more robust error checking) :
                if (!Array.prototype.indexOf) {
                    Array.prototype.indexOf = function (searchElement /*, fromIndex */ ) {
                        "use strict";
                        if (this == null) {
                            throw new TypeError();
                        var t = Object(this);
                        var len = t.length >>> 0;
                        if (len === 0) {
                            return -1;
                        var n = 0;
                        if (arguments.length > 0) {
                            n = Number(arguments[1]);
                            if (n != n) { // shortcut for verifying if it's NaN
                                n = 0;
                            } else if (n != 0 && n != Infinity && n != -Infinity) {
                                n = (n > 0 || -1) * Math.floor(Math.abs(n));
                        if (n >= len) {
                            return -1;
                        var k = n >= 0 ? n : Math.max(len - Math.abs(n), 0);
                        for (; k < len; k++) {
                            if (k in t && t[k] === searchElement) {
                                return k;
                        return -1;
                • 5. Re: Index of array based on value
                  Shadowfax Level 1
                  thnx a lt for wonderful guide
