1 Reply Latest reply on Jul 24, 2012 7:29 AM by Dave Merchant
    Verifying that javascript does not allow access to a link’s actual link information?ac
    HJS2
      I would like to verify that it is true that acrobat java script does not allow access to a link’s actual link information?
      Thanks for the information so far under
      Re: how to hyperlink from a pdf file to a specific page in a second pdf file
      I have a harddisk with a set of acrobat files.
      Manually I can set up a set of documents with links with an “action” of “go to a page in another document” that will allow jumping from document1.pdf to another document2.pdf at a given page.
      I am trying to get that same action from a set of source files in word that are converted to pdfs and saved on a hardisk.
      I started with a smaller set of smaller files on a website and used http://folder/document.pdf#page=2 which would open in IE with the acrobat reader plugin. As the files increased in number and size the speed was too slow.
      I am trying to convert over to a set of files on a hardisk.
      At this point I have a hyperlink in the word file that has the format of file:///folder/document.pdf#page=2
      It will open on a PC in IE with acrobat reader to a page.
      I was unable to get opening to work on a mac.
      I was looking at an acrobat java script to convert the old hyperlinks to “go to a page in another document” links
      But have run in to two problems
      1. it seems acrobat java script does not allow access to a links actual link information in a pdf so I can get the document name an page number.
      1. there does not seem to be a direct way to insert a “go to a page in another document” link.
      (although it did seem to be possible to setup a link with a javascript that would do the trick if the destination had a java script with “this.disclosed = true;”
      // Open a new document
      var myDoc = app.openDoc("Test2.pdf", this);
      // Go to page in this new doc
                myDoc.pageNum = 2;
      // Close the old document
                this.closeDoc();
      Questions:
      If I can get the old link information in to javascript is there a way to set/add a link that implements the “go to a page in another document”?
      If there is not another way to get the old link information is there another way to get around to where I need to be?
      In the setup of the source/conversion process?
      With some other post pdf processing?
      I am trying to get that same action as “go to a page in another document” from a source files in word that are converted to pdfs and saved on a hardisk
      Thanks for any help
      John
      Current Systems in use:
      Windows XP pro SP3
      Acrobat 9 pro version 9.4.4
      Word 2003 version SP3
      And
      Mac OS 10 Lion version 10.7.4
      Acrobat 9 pro version 9.5.1
      (note I have limited understanding of Mac’s)
