1. Re: Formatting a budget with tabs
RodneyA Jul 24, 2012 5:39 AM (in response to Michael_OSP)You want to set a decimal tab (or right-aligning tab) at the right margin, using a dot leader. Set a left indent, a first-line indent (the same number but negative), and tab stop at the left, to get the hanging indent with the parenthetical numbers. Set a large indent at the right, long enough to accomodate your longest number, so that long description texts will wrap before they get to the number area. When typing, put a tab after the parenthetical number, and another before the budget number. Any more than two tabs in a line can cause buggy behavior. In the example, the right margin isn't constant, but is larger for very large numbers, so if you've got a siutation like that, create several paragraph styles with varying right margins.
If the gap between the dot leader and the number is important, you could try putting in em-spaces after the tab but before the number -- I can't remember if the dot tab leaders honor spaces before numbers in this kind of situation. Try it out. If nothing else works, a couple of Xs filled with the "paper" color would be an awkward kludge.
Note that in fairly recent versions of Indesign these tabs outside the right margin didn't work properly. It was a pain. But versions 5 and 6 do support this, IIRC.
2. Re: Formatting a budget with tabs
P Spier Jul 24, 2012 7:22 AM (in response to RodneyA)You may need to add a negative last line indent to get the number to move beyond the text.
4. Re: Formatting a budget with tabs
P Spier Jul 24, 2012 8:04 AM (in response to rob day)You cheated, though, to get the line break. You added a forced line break after blaboratus.
Setting a right indent value in the paragraph style and a negative last line indent allows the number to hang automatically.
5. Re: Formatting a budget with tabs
RodneyA Jul 24, 2012 8:06 AM (in response to rob day)Looks like you've got it, though Peter's solution is much more elegant than forced line breaks. The advantage to using tabs for those left numbers is that once you get to number 10, they'll still align on the wrap. Then I usually do yet one more decimal tab at the beginning of each line, because I like list numbers 9 and 10 to align at the right, which is not only typographically correct, but keeps a consistent space between the list numbers and their text.
6. Re: Formatting a budget with tabs
rob day Jul 24, 2012 10:22 AM (in response to RodneyA)a negative last line indent allows the number to hang automatically
Very cool. It never occurred to me that you can offset from the right as well as the left.
An Indent to Here mark would align the text, this is still tabless
7. Re: Formatting a budget with tabs
As far as I can tell, that's about all the last line indent is good for.
9. Re: Formatting a budget with tabs
Michael_OSP Jul 25, 2012 2:10 AM (in response to rob day)Thanks to everybody but I think I must not have been describing what I am trying to get (maybe my brain isn't working at 4:25 am). What I want is the text including wrapping text and leaders under schedule to all end a specific spot (the red line in the screen shot included below) and the budget dollar amounts to be at the right margin. By the way, I agree that the parenthetical numbers should align on the right as Rob shows in his screen shot.
10. Re: Formatting a budget with tabs
Michael Gianino Jul 25, 2012 2:58 AM (in response to Michael_OSP)Although I'm not a big fan of double tab stops, you could have a right-aligned stop at the red line with a leader, then another one at the right edge of the text frame without. There could be a case to make that a table without stroked cells would be an option.
11. Re: Formatting a budget with tabs
rob day Jul 25, 2012 4:58 AM (in response to Michael_OSP)In my example I added another tab before the Right Indent Tab:
Note that the text has to be justified and if you were to change the column width the tab for the leader would have to be adjusted. The text also has a lot of white space characters to track—tab>number>tab>indent to here>text>en space>tab>right indent tab>number—so if your not used to that a table might be easier to control.
12. Re: Formatting a budget with tabs
As suggested before, set a right indent on the paraph style (at the position of the red line) and a negative last line indent equal to the right indent. To make the leader stop there as well, also set a right aligned tab with leader at the red line (to which the leader is applied) and another tab, without a leader, anywhere after that (to turn the leader off again, bu tthis tab will never be used). Insert both a regular tab (the right aligned one with the leader) and a right indent tab just before the number:
You can eliminate the second tab that's used to turn off the leader if you don't use a leader at all, but instead create a custom underline to use as the leader, which I think is more elegant, and apply it as a nested character style in the paragraph style definition. Your nested styles would then be [none] up to 1 tab, [custom underline style] through 1 tab.
19. Re: Formatting a budget with tabs
P Spier Jul 26, 2012 6:30 AM (in response to rob day)Looks to me like maybe you forgot to add the last line negative indent to allow the number to hang.
21. Re: Formatting a budget with tabs
Michael_OSP Jul 26, 2012 4:00 PM (in response to rob day)Rob, thanks for the file. I look at it and your tab at the right indent does not have a leader dot so how are you getting that? I looked in nested styles but it is not doing it that way.
23. Re: Formatting a budget with tabs
rob day Jul 26, 2012 5:54 PM (in response to Michael_OSP)My third tab has an underline applied, I got the dots via underline options and it could be saved as a character style.
Don't drop the third tab marker exactly on the right indent marker—if you do it doesn't get applied. In your last capture you only have 2 tab markers. In my file you can see the third tab marker slightly to the right of the right indent marker.
24. Re: Formatting a budget with tabs
Michael_OSP Jul 26, 2012 6:57 PM (in response to rob day)I got it! Thank you. Why does the period extend to the dollar amount and not stop at the third tab if I apply it to the third tab?
26. Re: Formatting a budget with tabs
P Spier Jul 27, 2012 5:02 AM (in response to rob day)I've sort of left the two of you alone to deal with this, but if I'm understanding the last question (and I didn't download Rob's file so I'm shooting in the dark), if you use a right-indent tab rahter than a right aligned tab (and I think you should), the right Indent tab picks up the leader from the last tab set in the paragraph style. You can't, in fact, actually apply a leader directly to a right-indent tab because it never appears in the tabs panel to select. An old trick to make a leader was to set a tab beyond the right edge of the text frame in the paragraph style and apply the leader to that (I learned that from Dave Saunders).
27. Re: Formatting a budget with tabs
rob day Jul 27, 2012 5:24 AM (in response to P Spier)An old trick to make a leader was to set a tab beyond the right edge of the text frame in the paragraph style and apply the leader to that (I learned that from Dave Saunders).
Doesn't seem to work in this case
28. Re: Formatting a budget with tabs
P Spier Jul 27, 2012 5:31 AM (in response to rob day)Applies the leader to a right indent tab, in case I wasn't clear. If that isn't happening, I'd have to see the file...
31. Re: Formatting a budget with tabs
rob day Jul 27, 2012 8:57 AM (in response to P Spier)2, 3... are using the underline method, and the right tab does have the leader
32. Re: Formatting a budget with tabs
rob day Jul 27, 2012 9:02 AM (in response to P Spier)Try it with one line of text. Also my text is justified.
33. Re: Formatting a budget with tabs
P Spier Jul 27, 2012 9:37 AM (in response to rob day)Rob, if you look, you'll see the first and fourth paragraphs in my sample above are only one line. I've just checked again and it works just the same here whther the te text is justified or left aligned. I've tested in CS3 (which happened to be open) and in CS5.5 just to see if something has changed.
