4 Replies Latest reply on Jul 25, 2012 7:31 AM by theEggplant
    InDesign CS5.5 - Update Error U44M1P7
    theEggplant
      Hello,
      I've been trying to install Adobe InDesign Update 7.5.3 and it reports error U44M1P7. I've reinstalled InDesign and receive the same error. I've noticed some other Adobe products with the same issue and I've tried all of the solutions to see if it would assist my InDesign problem. I am also getting an error that mentioned InDesign does not recognize InCopy.Bridge.InDesignPlugin.
      Upgrading to CS6 is not an option for me at this point.
      Any assistance with this would be great.
      Thank you!
        • 1. Re: InDesign CS5.5 - Update Error U44M1P7
          Carl Sun Level 4
          Please follow these steps to generate a log file so that we can tell the root cause.
          On Windows:
          1. Open Command Prompt window.
          2. Run command: cd %temp%
          3. Run command: echo > ribs3debug
          4. After that a new file named "ribs3debug" should have been created in temp folder.
          5. Update InDesign CS5.5, via Adobe Application Manager or running updater installer manually.
          6. The log file "C:\Program Files (x86)\Common Files\Adobe\Installers\Adobe InDesign CS5.5 7.5.3.333 07-25-2012.log.gz" will be created. (The version number and date may be slightly different)
          On Mac:
          1. Open a Terminal window.
          2. Run command: cd /tmp
          3. Run command: touch ribs3debug
          4. After that a new file named "ribs3debug" should have been created in /tmp folder.
          6. The new log file "/Library/Logs/Adobe/Installers/Adobe InDesign CS5.5 7.5.3.333 07-25-2012.log.gz" will be created.
          The actual plain text log file can be extracted from the generated gz file using 7-zip, winzip or other similar softwares. Please paste the log file here for the troubleshooting.
          • 2. Re: InDesign CS5.5 - Update Error U44M1P7
            theEggplant Level 1
            [   0] Tue Jul 24 11:38:19 2012  INFO
            Visit http://www.adobe.com/go/loganalyzer/ for more information
            START - Installer Session
            RIBS version: 5.0.65.0
            OSX version: 10.7.4
            ::START TIMER:: [Total Timer]
            CHECK: Single instance running
            CHECK : Credentials
            Load Deployment File
            deploymentFile option not given
            CHECK : Another Native OS installer already running
            Create Required Folders
            Assuming install mode
            Looking up install source path
            Sync Media DB ...
            ::START TIMER:: [Sync Media DB]
            Pre check media db sync
            End of Pre check media db sync. Exit code: 0
            :: END TIMER :: [Sync Media DB] took 737 milliseconds (0.737 seconds)
            Ready to initialize session to start with ...
            ::START TIMER:: [CreatePayloadSession]
            -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
            Updated source path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate
            Updating media info for: {07209C1E-7A2A-11E1-9EF9-5B5DF24106A5}
            Ignoring original data since install source is local
              Type: 0, Volume Order: 1, Media Name: InDesignCS5.5-AdobeUpdate
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-fi_FI-300312110445/AdobeInDesign7xAppLang-fi _FI-300312110445.dmg
            Updating media info for: {1075E20A-7A2B-11E1-A8F6-757EF24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-sv_SE-300312111210/AdobeInDesign7xAppLang-sv _SE-300312111210.dmg
            Updating media info for: {1D8C5DC6-7A2A-11E1-9CAC-1B60F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-fr_CA-300312110522/AdobeInDesign7xAppLang-fr _CA-300312110522.dmg
            Updating media info for: {27EE927E-7A2B-11E1-9945-3581F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-tr_TR-300312111254/AdobeInDesign7xAppLang-tr _TR-300312111254.dmg
            Updating media info for: {328612EE-7A2A-11E1-BE46-DE62F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-fr_FR-300312110557/AdobeInDesign7xAppLang-fr _FR-300312110557.dmg
            Updating media info for: {42184A0A-7A2B-11E1-B6C7-F583F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-uk_UA-300312111333/AdobeInDesign7xAppLang-uk _UA-300312111333.dmg
            Updating media info for: {49286448-7A2A-11E1-9A64-A065F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-hu_HU-300312110635/AdobeInDesign7xAppLang-hu _HU-300312110635.dmg
            Updating media info for: {57EF2FBA-7A2B-11E1-B268-BF86F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-zh_CN-300312111410/AdobeInDesign7xAppLang-zh _CN-300312111410.dmg
            Updating media info for: {5F534170-7A2A-11E1-A5B7-6068F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-it_IT-300312110713/AdobeInDesign7xAppLang-it _IT-300312110713.dmg
            Updating media info for: {6AFE0576-7A2C-11E1-88D2-74AAF24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xCommonBase-mul-300312112144/AdobeInDesign7xCommonBas e-mul-300312112144.dmg
            Updating media info for: {6C8284D8-7A29-11E1-944F-9BDFF14106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-cs_CZ-300312110028/AdobeInDesign7xAppLang-cs _CZ-300312110028.dmg
            Updating media info for: {6EB66524-7A2B-11E1-8309-7F89F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-zh_TW-300312111448/AdobeInDesign7xAppLang-zh _TW-300312111448.dmg
            Updating media info for: {7496AE28-7A2A-11E1-86EB-296BF24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-ja_JP-300312110748/AdobeInDesign7xAppLang-ja _JP-300312110748.dmg
            Updating media info for: {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppBase-mul-300312111735/AdobeInDesign7xAppBase-mul- 300312111735.dmg
            Updating media info for: {86126670-7A29-11E1-B3CB-BB4CF24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-da_DK-300312110108/AdobeInDesign7xAppLang-da _DK-300312110108.dmg
            Updating media info for: {89E6CEDE-7A2A-11E1-B5B6-E96DF24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-ko_KR-300312110824/AdobeInDesign7xAppLang-ko _KR-300312110824.dmg
            Updating media info for: {9B2A9424-7A29-11E1-83B9-854FF24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-de_DE-300312110143/AdobeInDesign7xAppLang-de _DE-300312110143.dmg
            Updating media info for: {A07F0922-7A2A-11E1-B9E2-A970F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-nb_NO-300312110902/AdobeInDesign7xAppLang-nb _NO-300312110902.dmg
            Updating media info for: {B1C55C46-7A29-11E1-B4DE-4752F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-en_GB-300312110221/AdobeInDesign7xAppLang-en _GB-300312110221.dmg
            Updating media info for: {B743B9A0-7A2A-11E1-81F1-6B73F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-nl_NL-300312110940/AdobeInDesign7xAppLang-nl _NL-300312110940.dmg
            Updating media info for: {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-en_US-300312110256/AdobeInDesign7xAppLang-en _US-300312110256.dmg
            Updating media info for: {CD2DADFC-7A2A-11E1-A3B6-2C76F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-pl_PL-300312111017/AdobeInDesign7xAppLang-pl _PL-300312111017.dmg
            Updating media info for: {DB6DB688-7A29-11E1-B049-D157F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-es_ES-300312110331/AdobeInDesign7xAppLang-es _ES-300312110331.dmg
            Updating media info for: {E33DD2F2-7A2A-11E1-AD8C-F578F24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-pt_BR-300312111054/AdobeInDesign7xAppLang-pt _BR-300312111054.dmg
            Updating media info for: {F03FF206-7A29-11E1-B3B5-935AF24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-es_MX-300312110406/AdobeInDesign7xAppLang-es _MX-300312110406.dmg
            Updating media info for: {F9D61092-7A2A-11E1-AA5F-B57BF24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-ru_RU-300312111132/AdobeInDesign7xAppLang-ru _RU-300312111132.dmg
            Updating media info for: {FE75A95E-7A2B-11E1-8037-B59BF24106A5}
              Path: /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppBase2-mul-300312112049/AdobeInDesign7xAppBase2-mu l-300312112049.dmg
            --------------------  END  - Updating Media Sources -  END  --------------------
            Supported RIBS version range: [0.0.66.0,5.0.65.0]
            ----------------- CreatePayloadSession: machine is x86 ---------------
            [   0] Tue Jul 24 11:38:20 2012  INFO
            ______ Verify Dependency Subscribers ______
            [   0] Tue Jul 24 11:38:20 2012 ERROR
            DW023: The extension payload: {07209C1E-7A2A-11E1-9EF9-5B5DF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-fi_FI 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-fi_FI
            MinVersion: 0.0.0.0
            This parent relationship is not satisfied, because this payload is not present in this session.
            This payload will be ignored in this session.
            DW023: The extension payload: {1075E20A-7A2B-11E1-A8F6-757EF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-sv_SE 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-sv_SE
            MinVersion: 0.0.0.0
            DW023: The extension payload: {1D8C5DC6-7A2A-11E1-9CAC-1B60F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-fr_CA 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-fr_CA
            MinVersion: 0.0.0.0
            DW023: The extension payload: {27EE927E-7A2B-11E1-9945-3581F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-tr_TR 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-tr_TR
            MinVersion: 0.0.0.0
            DW023: The extension payload: {328612EE-7A2A-11E1-BE46-DE62F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-fr_FR 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-fr_FR
            MinVersion: 0.0.0.0
            DW023: The extension payload: {42184A0A-7A2B-11E1-B6C7-F583F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-uk_UA 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-uk_UA
            MinVersion: 0.0.0.0
            DW023: The extension payload: {49286448-7A2A-11E1-9A64-A065F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-hu_HU 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-hu_HU
            MinVersion: 0.0.0.0
            DW023: The extension payload: {57EF2FBA-7A2B-11E1-B268-BF86F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-zh_CN 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-zh_CN
            MinVersion: 0.0.0.0
            DW023: The extension payload: {5F534170-7A2A-11E1-A5B7-6068F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-it_IT 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-it_IT
            MinVersion: 0.0.0.0
            DW023: The extension payload: {6C8284D8-7A29-11E1-944F-9BDFF14106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-cs_CZ 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-cs_CZ
            MinVersion: 0.0.0.0
            DW023: The extension payload: {6EB66524-7A2B-11E1-8309-7F89F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-zh_TW 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-zh_TW
            MinVersion: 0.0.0.0
            DW023: The extension payload: {7496AE28-7A2A-11E1-86EB-296BF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-ja_JP 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-ja_JP
            MinVersion: 0.0.0.0
            DW023: The extension payload: {86126670-7A29-11E1-B3CB-BB4CF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-da_DK 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-da_DK
            MinVersion: 0.0.0.0
            DW023: The extension payload: {89E6CEDE-7A2A-11E1-B5B6-E96DF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-ko_KR 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-ko_KR
            MinVersion: 0.0.0.0
            DW023: The extension payload: {9B2A9424-7A29-11E1-83B9-854FF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-de_DE 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-de_DE
            MinVersion: 0.0.0.0
            DW023: The extension payload: {A07F0922-7A2A-11E1-B9E2-A970F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-nb_NO 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-nb_NO
            MinVersion: 0.0.0.0
            DW023: The extension payload: {B1C55C46-7A29-11E1-B4DE-4752F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_GB 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_GB
            MinVersion: 0.0.0.0
            DW023: The extension payload: {B743B9A0-7A2A-11E1-81F1-6B73F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-nl_NL 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-nl_NL
            MinVersion: 0.0.0.0
            DW023: The extension payload: {CD2DADFC-7A2A-11E1-A3B6-2C76F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-pl_PL 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-pl_PL
            MinVersion: 0.0.0.0
            DW023: The extension payload: {DB6DB688-7A29-11E1-B049-D157F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-es_ES 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-es_ES
            MinVersion: 0.0.0.0
            DW023: The extension payload: {E33DD2F2-7A2A-11E1-AD8C-F578F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-pt_BR 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-pt_BR
            MinVersion: 0.0.0.0
            DW023: The extension payload: {F03FF206-7A29-11E1-B3B5-935AF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-es_MX 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-es_MX
            MinVersion: 0.0.0.0
            DW023: The extension payload: {F9D61092-7A2A-11E1-AA5F-B57BF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-ru_RU 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-ru_RU
            MinVersion: 0.0.0.0
            BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
              {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333: 0 (0,0)
              {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333: 0 (0,0)
              {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333: 0 (0,0)
              {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333: 0 (0,0)
            END Operation order for all session payloads: mediaGroup (requires,satisfies)
            Initializing the INSTALLDIR with PDB data for payload {0CCF0458-5171-11E0-BC45-DC59E3AB3DC5}
            File Exists: /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/Resources/AMT/application.xml
            Located the INSTALLDIR for payload '{0CCF0458-5171-11E0-BC45-DC59E3AB3DC5}' : '/Applications'
            [   0] Tue Jul 24 11:38:28 2012  INFO
            Overwrite property "extensionsOnly" to: 1
            Overwrite property "mode" to: silent
            Overwrite property "patchesOnly" to: 1
            Overwrite property "workflow" to: updater
            Found payload actions:
            Deciding what installer mode to use...
            BEGIN Setting requested payload actions
            Value returned on lookup of payload: {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333 is: true
            Action string for {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333  is install
            Value returned on lookup of payload: {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333 is: false
            Action string for {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333  is install
            Value returned on lookup of payload: {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333 is: false
            Action string for {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333  is install
            Value returned on lookup of payload: {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333 is: false
            Action string for {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333  is install
            END Setting requested payload actions
            Collected advanced path check information for INSTALLDIR
            INSTALLDIR is a well-formed path
            INSTALLDIR is not the root path
            INSTALLDIR is on a local volume
            INSTALLDIR is on a writable volume
            INSTALLDIR is not on a case sensitive volume
            INSTALLDIR passed path basic path validation: /Applications
            [   0] Tue Jul 24 11:44:43 2012  INFO
            Initializing the INSTALLDIR with PDB data for payload {F313167E-5172-11E0-ACE7-30C2E3AB3DC5}
            Located the INSTALLDIR for payload '{F313167E-5172-11E0-ACE7-30C2E3AB3DC5}' : '/Applications'
            Initializing the INSTALLDIR with PDB data for payload {ED9DC850-516E-11E0-9096-1FE5E2AB3DC5}
            [   0] Tue Jul 24 11:44:44 2012  INFO
            Located the INSTALLDIR for payload '{ED9DC850-516E-11E0-9096-1FE5E2AB3DC5}' : '/Applications'
            Initializing the INSTALLDIR with PDB data for payload {03FB981A-5170-11E0-A90E-3CEDE2AB3DC5}
            Located the INSTALLDIR for payload '{03FB981A-5170-11E0-A90E-3CEDE2AB3DC5}' : '/Applications'
            [   0] Tue Jul 24 11:44:45 2012  INFO
            BEGIN InstallOperationsQueue Unordered operations
              {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333:  with operation repair
              {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333:  with operation install
              {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333:  with operation install
              {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333:  with operation install
            END InstallOperationsQueue Unordered operations
            BEGIN InstallOperationsQueue Ordered operations
            END InstallOperationsQueue Ordered operations
            [   0] Tue Jul 24 11:44:45 2012  WARN
            DW035: Patcher: {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333 has already been applied. Patchers cannot be repaired/reinstalled, skipping this patcher
            Payloads passed preflight validation.
            Call PreSession Custom Hook
            Skipping payload {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333 as payload is not cached
            [   0] Tue Jul 24 11:44:46 2012  INFO
            Calling the custom action code for pre-install for payload {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5}
            ::START TIMER:: [Payload Operation :{848BF4CC-7A2B-11E1-8A90-3F8CF24106A5}]
            [   1] Tue Jul 24 11:44:46 2012  INFO
            Installer Operation: PayloadUninstaller
            Session {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} modify request for AdobeCode: {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5}
            Effective AdobeCode for: {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} is {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5}
            PDB install manipulation failed
            [   0] Tue Jul 24 11:44:47 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: -1 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{848BF4CC-7A2B-11E1-8A90-3F8CF24106A5}] took 1205 milliseconds (1.205 seconds) DTR = 3.3195 KBPS (0.0032417 MBPS)
            User specified overrideFile:
            The csu inventory was not updated for payload {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333, value of local var is -1
            Calling the ROLLBACK custom action code for pre-install for payload {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333
            Calling the custom action code for pre-install for payload {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5}
            ::START TIMER:: [Payload Operation :{C68C3E1A-7A29-11E1-A9D9-0F55F24106A5}]
            [   1] Tue Jul 24 11:44:47 2012  INFO
            Session {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} modify request for AdobeCode: {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5}
            Effective AdobeCode for: {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} is {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5}
            [   0] Tue Jul 24 11:44:48 2012  INFO
            :: END TIMER :: [Payload Operation :{C68C3E1A-7A29-11E1-A9D9-0F55F24106A5}] took 1058 milliseconds (1.058 seconds)
            The csu inventory was not updated for payload {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333, value of local var is -1
            Calling the ROLLBACK custom action code for pre-install for payload {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333
            [   0] Tue Jul 24 11:44:49 2012  INFO
            Calling the custom action code for pre-install for payload {FE75A95E-7A2B-11E1-8037-B59BF24106A5}
            ::START TIMER:: [Payload Operation :{FE75A95E-7A2B-11E1-8037-B59BF24106A5}]
            [   1] Tue Jul 24 11:44:49 2012  INFO
            Session {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} modify request for AdobeCode: {FE75A95E-7A2B-11E1-8037-B59BF24106A5}
            Effective AdobeCode for: {FE75A95E-7A2B-11E1-8037-B59BF24106A5} is {FE75A95E-7A2B-11E1-8037-B59BF24106A5}
            [   0] Tue Jul 24 11:44:50 2012  INFO
            :: END TIMER :: [Payload Operation :{FE75A95E-7A2B-11E1-8037-B59BF24106A5}] took 1074 milliseconds (1.074 seconds)
            The csu inventory was not updated for payload {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333, value of local var is -1
            Calling the ROLLBACK custom action code for pre-install for payload {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333
            No operation.  We're done:
            [   0] Tue Jul 24 11:44:52 2012  INFO
            Total components installed: 0
            Total components repaired: 0
            Total components removed: 0
            [   0] Tue Jul 24 11:44:52 2012 ERROR
            DW050: The following payload errors were found during install:
            DW050:  - Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul: Patch already installed
            DW050:  - Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul: Install failed
            DW050:  - Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US: Install failed
            DW050:  - Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul: Install failed
            Call PostSession Custom Hook
            :: END TIMER :: [Total Timer] took 399220 milliseconds (399.22 seconds) DTR = 6.20209 KBPS (0.00605673 MBPS)
            -------------------------------------- Summary --------------------------------------
            - 0 fatal error(s), 27 error(s), 2 warning(s)
            ERROR: DW023: The extension payload: {07209C1E-7A2A-11E1-9EF9-5B5DF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-fi_FI 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {1075E20A-7A2B-11E1-A8F6-757EF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-sv_SE 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {1D8C5DC6-7A2A-11E1-9CAC-1B60F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-fr_CA 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {27EE927E-7A2B-11E1-9945-3581F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-tr_TR 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {328612EE-7A2A-11E1-BE46-DE62F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-fr_FR 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {42184A0A-7A2B-11E1-B6C7-F583F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-uk_UA 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {49286448-7A2A-11E1-9A64-A065F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-hu_HU 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {57EF2FBA-7A2B-11E1-B268-BF86F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-zh_CN 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {5F534170-7A2A-11E1-A5B7-6068F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-it_IT 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {6C8284D8-7A29-11E1-944F-9BDFF14106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-cs_CZ 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {6EB66524-7A2B-11E1-8309-7F89F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-zh_TW 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {7496AE28-7A2A-11E1-86EB-296BF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-ja_JP 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {86126670-7A29-11E1-B3CB-BB4CF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-da_DK 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {89E6CEDE-7A2A-11E1-B5B6-E96DF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-ko_KR 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {9B2A9424-7A29-11E1-83B9-854FF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-de_DE 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {A07F0922-7A2A-11E1-B9E2-A970F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-nb_NO 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {B1C55C46-7A29-11E1-B4DE-4752F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_GB 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {B743B9A0-7A2A-11E1-81F1-6B73F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-nl_NL 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {CD2DADFC-7A2A-11E1-A3B6-2C76F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-pl_PL 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {DB6DB688-7A29-11E1-B049-D157F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-es_ES 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {E33DD2F2-7A2A-11E1-AD8C-F578F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-pt_BR 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {F03FF206-7A29-11E1-B3B5-935AF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-es_MX 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            ERROR: DW023: The extension payload: {F9D61092-7A2A-11E1-AA5F-B57BF24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-ru_RU 7.5.3.333 requires a parent with following specification:
            Family: InDesign
            MinVersion: 0.0.0.0
            WARNING: DW035: Patcher: {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333 has already been applied. Patchers cannot be repaired/reinstalled, skipping this patcher
            ERROR: DW050: The following payload errors were found during install:
            ERROR: DW050:  - Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul: Patch already installed
            ERROR: DW050:  - Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul: Install failed
            ERROR: DW050:  - Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US: Install failed
            ERROR: DW050:  - Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul: Install failed
            Please search the above error/warning string(s) to find when the error occurred.
            These errors resulted in installer Exit Code mentioned below.
            Exit Code: 7 - Unable to complete Silent workflow.
            Please see specific errors and warnings for troubleshooting. For example, ERROR: DW023, DW050 ... WARNING: DW035 ...
            END - Installer Session
            [   0] Tue Jul 24 20:30:09 2012  INFO
            OSX version: 10.7.4
            CHECK : Credentials
            Sync Media DB ...
            :: END TIMER :: [Sync Media DB] took 239 milliseconds (0.239 seconds) DTR = 1958.16 KBPS (1.91226 MBPS)
            Updated source path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate
              Type: 1, Volume Order: 1, Media Name: InDesignCS5.5-AdobeUpdate
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-fi_FI-300312110445/AdobeInDes ign7xAppLang-fi_FI-300312110445.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-sv_SE-300312111210/AdobeInDes ign7xAppLang-sv_SE-300312111210.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-fr_CA-300312110522/AdobeInDes ign7xAppLang-fr_CA-300312110522.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-tr_TR-300312111254/AdobeInDes ign7xAppLang-tr_TR-300312111254.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-fr_FR-300312110557/AdobeInDes ign7xAppLang-fr_FR-300312110557.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-uk_UA-300312111333/AdobeInDes ign7xAppLang-uk_UA-300312111333.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-hu_HU-300312110635/AdobeInDes ign7xAppLang-hu_HU-300312110635.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-zh_CN-300312111410/AdobeInDes ign7xAppLang-zh_CN-300312111410.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-it_IT-300312110713/AdobeInDes ign7xAppLang-it_IT-300312110713.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xCommonBase-mul-300312112144/AdobeInDe sign7xCommonBase-mul-300312112144.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-cs_CZ-300312110028/AdobeInDes ign7xAppLang-cs_CZ-300312110028.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-zh_TW-300312111448/AdobeInDes ign7xAppLang-zh_TW-300312111448.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-ja_JP-300312110748/AdobeInDes ign7xAppLang-ja_JP-300312110748.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppBase-mul-300312111735/AdobeInDesig n7xAppBase-mul-300312111735.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-da_DK-300312110108/AdobeInDes ign7xAppLang-da_DK-300312110108.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-ko_KR-300312110824/AdobeInDes ign7xAppLang-ko_KR-300312110824.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-de_DE-300312110143/AdobeInDes ign7xAppLang-de_DE-300312110143.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-nb_NO-300312110902/AdobeInDes ign7xAppLang-nb_NO-300312110902.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-en_GB-300312110221/AdobeInDes ign7xAppLang-en_GB-300312110221.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-nl_NL-300312110940/AdobeInDes ign7xAppLang-nl_NL-300312110940.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-en_US-300312110256/AdobeInDes ign7xAppLang-en_US-300312110256.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-pl_PL-300312111017/AdobeInDes ign7xAppLang-pl_PL-300312111017.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-es_ES-300312110331/AdobeInDes ign7xAppLang-es_ES-300312110331.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-pt_BR-300312111054/AdobeInDes ign7xAppLang-pt_BR-300312111054.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-es_MX-300312110406/AdobeInDes ign7xAppLang-es_MX-300312110406.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-ru_RU-300312111132/AdobeInDes ign7xAppLang-ru_RU-300312111132.dmg
              Path: /Volumes/InDesignCS5.5-AdobeUpdate 1/InDesignCS5.5-AdobeUpdate/payloads/AdobeInDesign7xAppBase2-mul-300312112049/AdobeInDesi gn7xAppBase2-mul-300312112049.dmg
            [   0] Tue Jul 24 20:30:11 2012  INFO
            Setting ignore refcount for '{DABB76F0-8EAF-11E0-95E5-C686B319E507} Adobe InDesign CS5.5 Application Base Files_7.5.1.304_AdobeInDesign7xAppBase-mul 7.5.1.304' getting upgraded by '{848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333'
            Setting ignore refcount for '{BFC054DA-8EAD-11E0-A928-7926B319E507} Adobe InDesign CS5.5 Application Language Files_7.5.1.304_AdobeInDesign7xAppLang-en_US 7.5.1.304' getting upgraded by '{C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333'
            Setting ignore refcount for '{3EE38078-8EB0-11E0-9A75-C592B319E507} Adobe InDesign CS5.5 Application Base Files2_7.5.1.304_AdobeInDesign7xAppBase2-mul 7.5.1.304' getting upgraded by '{FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333'
            [   0] Tue Jul 24 20:30:11 2012 ERROR
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
              {DABB76F0-8EAF-11E0-95E5-C686B319E507} Adobe InDesign CS5.5 Application Base Files_7.5.1.304_AdobeInDesign7xAppBase-mul 7.5.1.304: 0 (0,0)
              {BFC054DA-8EAD-11E0-A928-7926B319E507} Adobe InDesign CS5.5 Application Language Files_7.5.1.304_AdobeInDesign7xAppLang-en_US 7.5.1.304: 0 (0,0)
              {3EE38078-8EB0-11E0-9A75-C592B319E507} Adobe InDesign CS5.5 Application Base Files2_7.5.1.304_AdobeInDesign7xAppBase2-mul 7.5.1.304: 0 (0,0)
            [   0] Tue Jul 24 20:30:13 2012  INFO
            Overwrite property "DEVersion" to: 5
            Value returned on lookup of payload: {DABB76F0-8EAF-11E0-95E5-C686B319E507} Adobe InDesign CS5.5 Application Base Files_7.5.1.304_AdobeInDesign7xAppBase-mul 7.5.1.304 is: true
            Action string for {DABB76F0-8EAF-11E0-95E5-C686B319E507} Adobe InDesign CS5.5 Application Base Files_7.5.1.304_AdobeInDesign7xAppBase-mul 7.5.1.304  is install
            Value returned on lookup of payload: {BFC054DA-8EAD-11E0-A928-7926B319E507} Adobe InDesign CS5.5 Application Language Files_7.5.1.304_AdobeInDesign7xAppLang-en_US 7.5.1.304 is: true
            Action string for {BFC054DA-8EAD-11E0-A928-7926B319E507} Adobe InDesign CS5.5 Application Language Files_7.5.1.304_AdobeInDesign7xAppLang-en_US 7.5.1.304  is install
            Value returned on lookup of payload: {3EE38078-8EB0-11E0-9A75-C592B319E507} Adobe InDesign CS5.5 Application Base Files2_7.5.1.304_AdobeInDesign7xAppBase2-mul 7.5.1.304 is: true
            Action string for {3EE38078-8EB0-11E0-9A75-C592B319E507} Adobe InDesign CS5.5 Application Base Files2_7.5.1.304_AdobeInDesign7xAppBase2-mul 7.5.1.304  is install
            Value returned on lookup of payload: {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333 is: false
            [   0] Tue Jul 24 20:30:14 2012  INFO
              {3EE38078-8EB0-11E0-9A75-C592B319E507} Adobe InDesign CS5.5 Application Base Files2_7.5.1.304_AdobeInDesign7xAppBase2-mul 7.5.1.304:  with operation remove
              {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333:  with operation install
              {BFC054DA-8EAD-11E0-A928-7926B319E507} Adobe InDesign CS5.5 Application Language Files_7.5.1.304_AdobeInDesign7xAppLang-en_US 7.5.1.304:  with operation remove
              {DABB76F0-8EAF-11E0-95E5-C686B319E507} Adobe InDesign CS5.5 Application Base Files_7.5.1.304_AdobeInDesign7xAppBase-mul 7.5.1.304:  with operation remove
            DW032: Payload:{3EE38078-8EB0-11E0-9A75-C592B319E507} Adobe InDesign CS5.5 Application Base Files2_7.5.1.304_AdobeInDesign7xAppBase2-mul 7.5.1.304 has newer update. The patch will be uninstalled now.
            DW032: Payload:{BFC054DA-8EAD-11E0-A928-7926B319E507} Adobe InDesign CS5.5 Application Language Files_7.5.1.304_AdobeInDesign7xAppLang-en_US 7.5.1.304 has newer update. The patch will be uninstalled now.
            DW032: Payload:{DABB76F0-8EAF-11E0-95E5-C686B319E507} Adobe InDesign CS5.5 Application Base Files_7.5.1.304_AdobeInDesign7xAppBase-mul 7.5.1.304 has newer update. The patch will be uninstalled now.
            Calling the custom action code for pre-remove for payload {DABB76F0-8EAF-11E0-95E5-C686B319E507}
            ::START TIMER:: [Payload Operation :{DABB76F0-8EAF-11E0-95E5-C686B319E507}]
            [   1] Tue Jul 24 20:30:14 2012  INFO
            Session {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} modify request for AdobeCode: {DABB76F0-8EAF-11E0-95E5-C686B319E507}
            Effective AdobeCode for: {DABB76F0-8EAF-11E0-95E5-C686B319E507} is {DABB76F0-8EAF-11E0-95E5-C686B319E507}
            [   1] Tue Jul 24 20:30:15 2012  INFO
            Payload {DABB76F0-8EAF-11E0-95E5-C686B319E507} Adobe InDesign CS5.5 Application Base Files_7.5.1.304_AdobeInDesign7xAppBase-mul 7.5.1.304: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE5/resources
            CustomizedPatch property not found in database
            Beginning un-installation for payload at /Library/Application Support/Adobe/Uninstall/{DABB76F0-8EAF-11E0-95E5-C686B319E507}.db
            Completing un-installation for payload at /Library/Application Support/Adobe/Uninstall/{DABB76F0-8EAF-11E0-95E5-C686B319E507}.db
            Physical payload uninstall result:0
            [   0] Tue Jul 24 20:30:15 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{DABB76F0-8EAF-11E0-95E5-C686B319E507}] took 1074 milliseconds (1.074 seconds) DTR = 15810.1 KBPS (15.4395 MBPS)
            Successfully updated the csu inventory for {DABB76F0-8EAF-11E0-95E5-C686B319E507} Adobe InDesign CS5.5 Application Base Files_7.5.1.304_AdobeInDesign7xAppBase-mul 7.5.1.304 return values 0:0
            [   0] Tue Jul 24 20:30:16 2012  INFO
            Calling the custom action code for post-remove for payload {DABB76F0-8EAF-11E0-95E5-C686B319E507} Adobe InDesign CS5.5 Application Base Files_7.5.1.304_AdobeInDesign7xAppBase-mul 7.5.1.304
            Calling the custom action code for pre-remove for payload {BFC054DA-8EAD-11E0-A928-7926B319E507}
            ::START TIMER:: [Payload Operation :{BFC054DA-8EAD-11E0-A928-7926B319E507}]
            [   1] Tue Jul 24 20:30:16 2012  INFO
            Session {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} modify request for AdobeCode: {BFC054DA-8EAD-11E0-A928-7926B319E507}
            Effective AdobeCode for: {BFC054DA-8EAD-11E0-A928-7926B319E507} is {BFC054DA-8EAD-11E0-A928-7926B319E507}
            Payload {BFC054DA-8EAD-11E0-A928-7926B319E507} Adobe InDesign CS5.5 Application Language Files_7.5.1.304_AdobeInDesign7xAppLang-en_US 7.5.1.304: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE5/resources
            Beginning un-installation for payload at /Library/Application Support/Adobe/Uninstall/{BFC054DA-8EAD-11E0-A928-7926B319E507}.db
            Completing un-installation for payload at /Library/Application Support/Adobe/Uninstall/{BFC054DA-8EAD-11E0-A928-7926B319E507}.db
            [   0] Tue Jul 24 20:30:17 2012  INFO
            :: END TIMER :: [Payload Operation :{BFC054DA-8EAD-11E0-A928-7926B319E507}] took 1059 milliseconds (1.059 seconds) DTR = 200.189 KBPS (0.195497 MBPS)
            Successfully updated the csu inventory for {BFC054DA-8EAD-11E0-A928-7926B319E507} Adobe InDesign CS5.5 Application Language Files_7.5.1.304_AdobeInDesign7xAppLang-en_US 7.5.1.304 return values 0:0
            Calling the custom action code for post-remove for payload {BFC054DA-8EAD-11E0-A928-7926B319E507} Adobe InDesign CS5.5 Application Language Files_7.5.1.304_AdobeInDesign7xAppLang-en_US 7.5.1.304
            [   0] Tue Jul 24 20:30:18 2012  INFO
            Calling the custom action code for pre-remove for payload {3EE38078-8EB0-11E0-9A75-C592B319E507}
            ::START TIMER:: [Payload Operation :{3EE38078-8EB0-11E0-9A75-C592B319E507}]
            [   1] Tue Jul 24 20:30:18 2012  INFO
            Session {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} modify request for AdobeCode: {3EE38078-8EB0-11E0-9A75-C592B319E507}
            Effective AdobeCode for: {3EE38078-8EB0-11E0-9A75-C592B319E507} is {3EE38078-8EB0-11E0-9A75-C592B319E507}
            Payload {3EE38078-8EB0-11E0-9A75-C592B319E507} Adobe InDesign CS5.5 Application Base Files2_7.5.1.304_AdobeInDesign7xAppBase2-mul 7.5.1.304: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE5/resources
            Beginning un-installation for payload at /Library/Application Support/Adobe/Uninstall/{3EE38078-8EB0-11E0-9A75-C592B319E507}.db
            Completing un-installation for payload at /Library/Application Support/Adobe/Uninstall/{3EE38078-8EB0-11E0-9A75-C592B319E507}.db
            [   0] Tue Jul 24 20:30:19 2012  INFO
            :: END TIMER :: [Payload Operation :{3EE38078-8EB0-11E0-9A75-C592B319E507}] took 1067 milliseconds (1.067 seconds) DTR = 3250.23 KBPS (3.17406 MBPS)
            Successfully updated the csu inventory for {3EE38078-8EB0-11E0-9A75-C592B319E507} Adobe InDesign CS5.5 Application Base Files2_7.5.1.304_AdobeInDesign7xAppBase2-mul 7.5.1.304 return values 0:0
            Calling the custom action code for post-remove for payload {3EE38078-8EB0-11E0-9A75-C592B319E507} Adobe InDesign CS5.5 Application Base Files2_7.5.1.304_AdobeInDesign7xAppBase2-mul 7.5.1.304
            Calling the custom action code for pre-install for payload {6AFE0576-7A2C-11E1-88D2-74AAF24106A5}
            ::START TIMER:: [Payload Operation :{6AFE0576-7A2C-11E1-88D2-74AAF24106A5}]
            [   1] Tue Jul 24 20:30:19 2012  INFO
            Installer Operation: PayloadInstaller
            Request to install payload
            Payload {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE5/resources
            [   1] Tue Jul 24 20:30:21 2012  INFO
            Beginning installation for payload at /private/tmp/.tempdiruZZKup3a/Install.db
            Completing installation for payload at /private/tmp/.tempdiruZZKup3a/Install.db
            UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{6AFE0576-7A2C-11E1-88D2-74AAF24106A5}.db
            [   0] Tue Jul 24 20:30:21 2012  INFO
            :: END TIMER :: [Payload Operation :{6AFE0576-7A2C-11E1-88D2-74AAF24106A5}] took 2124 milliseconds (2.124 seconds) DTR = 75.3296 KBPS (0.073564 MBPS)
            [   0] Tue Jul 24 20:30:22 2012  INFO
            Successfully updated the csu inventory for {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333 return values 0:0
            Calling the custom action code for post-install for payload {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333
            [   1] Tue Jul 24 20:30:23 2012  INFO
            [   0] Tue Jul 24 20:30:24 2012  INFO
            :: END TIMER :: [Payload Operation :{848BF4CC-7A2B-11E1-8A90-3F8CF24106A5}] took 1259 milliseconds (1.259 seconds)
            [   2] Tue Jul 24 20:30:24 2012  INFO
            [   0] Tue Jul 24 20:30:25 2012  INFO
            [   2] Tue Jul 24 20:30:25 2012  INFO
            [   0] Tue Jul 24 20:30:26 2012  INFO
            :: END TIMER :: [Payload Operation :{FE75A95E-7A2B-11E1-8037-B59BF24106A5}] took 1061 milliseconds (1.061 seconds)
            [   0] Tue Jul 24 20:30:29 2012  INFO
            Successfully installed 1 component:
            Successfully removed 3 components:
            - Adobe InDesign CS5.5 Application Base Files2_7.5.1.304_AdobeInDesign7xAppBase2-mul
            - Adobe InDesign CS5.5 Application Language Files_7.5.1.304_AdobeInDesign7xAppLang-en_US
            - Adobe InDesign CS5.5 Application Base Files_7.5.1.304_AdobeInDesign7xAppBase-mul
            [   0] Tue Jul 24 20:30:29 2012 ERROR
            :: END TIMER :: [Total Timer] took 23776 milliseconds (23.776 seconds) DTR = 841.016 KBPS (0.821305 MBPS)
            - 0 fatal error(s), 26 error(s), 0 warning(s)
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            [   0] Tue Jul 24 20:35:09 2012  INFO
            OSX version: 10.7.4
            CHECK : Credentials
            Sync Media DB ...
            :: END TIMER :: [Sync Media DB] took 502 milliseconds (0.502 seconds)
            [   0] Tue Jul 24 20:35:09 2012 DEBUG
            InstallerSession.CreatePayloadSession: Checking for unsupported payloads
            ______ InstallerSession.CreatePayloadSession: Checking session payloads ______
            InstallerSession.CreatePayloadSession: Load PDB
            [   0] Tue Jul 24 20:35:10 2012 DEBUG
            ______ InstallerSession.CreatePayloadSession: Checking incompatible payloads ______
            ______ GetIncompatiblePayloadBuildsInstalled ______
            ______ InstallerSession.CreatePayloadSession: Checking already installed payloads ______
            {007A2A28-D6A8-4D91-9A2B-568FF8052215} Adobe WinSoft Linguistics Plugin CS5
            {0175676F-8C92-49F2-9131-D0D6AD654B41} AdobeHelp
            {0377892E-FCAC-46EC-AA70-C6AC8A86A81F} Dynamic Link Media Server
            {03FB981A-5170-11E0-A90E-3CEDE2AB3DC5} Adobe InDesign CS5.5 Application Base Files2
            {04ADB20D-99A3-4F83-8176-F07787237EBA} Creative Suite 5.5 Design Premium
            {08EF22BC-43B2-4B4E-BA12-52B18F418F38} Adobe Photoshop CS5.1 Core
            {0AA9D11A-227D-45AB-A5D5-6F5F6E81D5E3} Adobe Player for Embedding 3.1
            {0CCF0458-5171-11E0-BC45-DC59E3AB3DC5} Adobe InDesign CS5.5 Application Base Files
            {0D96CFE6-376D-44B8-808A-16F3BEB73263} Adobe Media Encoder CS5.5
            {11E1188F-E576-47BC-B215-600C02C7EABF} AdobeColorNA CS5.5
            {128cd5a7-6018-4360-b4c0-b0258b1a5a34} Adobe Story
            {145F0B3B-2643-43A0-9BBC-ADAA51223F5F} Adobe Encore CS6_AdobeEncore6en_USLanguagePack
            {148542D8-49CA-482A-A334-1D54C5A9D53B} Adobe XMP Panels
            {1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4} DynamiclinkSupport
            {22C26C10-5C22-4674-A52C-100112664305} Adobe Device Central CS5.5_DeviceCentral3.5LP-en_US
            {2373AB3E-A20E-4E37-BDA6-53562CE2171F} Adobe Extension Manager CS5.5_5.5.1_AdobeExtensionManager5.5All
            {237410EB-78A3-4797-95D0-F41DA1697D7D} Adobe Extension Manager CS5.5_5.5.2_AdobeExtensionManager5.5All
            {2591B843-8028-4395-9DEE-03AF8D631539} Adobe Player for Embedding 3.3
            {270C312D-7EC7-474C-BEB2-79CD398E02A3} HIL Help Search
            {2EA9B52E-8613-41A0-9EEF-FF54AD4CC810} Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-en_US
            {311CDC89-AC18-4344-9EC9-0225328C73D3} Required Common Fonts Installation
            {3450d4c5-a82b-4428-a512-842ee1555a14} CSXS Story Extension
            {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6
            {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw
            {3FA63389-0091-497A-8522-998E43648AEF} Adobe Player for Embedding 3.2
            {4058E728-84D8-45CE-8E2D-5F35BD6659A1} Adobe Extension Manager CS5.5
            {419B81A0-6282-456C-9B1E-8DBABA0DE2DC} Adobe WinSoft Linguistics Plugin CS5.5
            {41BFF2C7-9F45-4CF3-A257-E80E14802157} Adobe Media Encoder CS5.5_5.5.1_AMECore5.5All
            {42CED1DA-1C36-45D2-88C0-C32DB6B82B49} Adobe Premiere Pro CS6
            {45063C56-A2A2-4FD1-A56A-A964723EEE1E} AdobeColorCommonSetRGB
            {4603E0C5-6880-4A4F-BCF8-DF1F6AE0E317} AdobeColorPhotoshop CS5.5
            {46251F95-B2F8-484A-9B5B-8C0E5A43A202} Adobe Encore CS6
            {49E6D00F-3456-11E0-AE83-842B2B67A8CC} Adobe Device Central CS5.5
            {4A8546D0-CEDF-48C1-9BA1-DD5B4ADFC154} Adobe Mini Bridge CS5.1
            {4B204697-D302-42D9-94B4-8BDDE6DD359C} Adobe ReviewPanel CS5.5
            {4B4C871D-9C8A-4C8A-B92A-C37273D6CE7D} Adobe Fireworks CS5.1
            {4B51E596-6BB0-4244-9AB9-344AD5FA6726} AdobeMotionPicture CS5.5
            {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5
            {4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE} Photoshop Camera Raw_6.7_AdobeCameraRaw6.0All
            {4F427880-01EA-4E0F-AAE2-9ADE97563A21} Adobe Utilities CS6
            {4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF} Adobe SwitchBoard 2.0
            {50491591-A44F-429E-B7C8-87E03FECFD78} Adobe Flash Catalyst CS5.5
            {50F5A7C9-1E43-4860-AED8-7F8722691F17} Adobe ExtendScript Toolkit CS6
            {539AEF15-3A2B-4A31-A587-7E90F7D9C700} Camera Profiles Installer
            {54D89F03-8EED-4FF9-BCDF-3B2E11D448A6} AdobeColorCommonSetCMYK
            {557F9FD3-EED8-43D7-AF29-0F19CA832728} AdobePDFL CS6
            {5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll
            {606A0AC5-5F90-4379-81AE-11B44707E094} Adobe After Effects CS5.5 Third Party Content
            {61D7BE95-B5C3-4257-A773-64596D72E848} Adobe After Effects CS5.5 Template Projects & Footage
            {62ED7AE1-01FA-4066-97B7-1CD93A68DD0D} Adobe Hunspell Linguistics Plugin CS5.5
            {6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5
            {6BC81374-1E33-4495-93E2-DD2B10D358EE} AIR for APPLE IOS Support (FP)
            {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5
            {71BC8278-815D-4F8C-8FA5-C6F782C73892} Adobe CSXS Infrastructure CS5.5
            {75CD59C0-516F-11E0-892C-26ECE2AB3DC5} Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_US
            {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1
            {7CAD45EF-24AD-4281-9236-7F8DDB0B9538} Adobe After Effects CS5.5 Support
            {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6
            {83478D6E-4AA8-11E0-A479-24B1F9D7AC32} Adobe Content Viewer
            {8AB04F7C-8AEF-4023-9CDB-F761E4ECF9CC} Adobe Fireworks CS5.1_AdobeFireworks11.1.0en_USLanguagePack
            {970C9F3A-39C5-480B-BE51-7C70AB9F84DB} Adobe Flash CS5.5_AdobeFlash11.5-en_USLanguagePack
            {97BA0109-F6BE-4F50-8904-C19442D7216E} Adobe Bridge CS6
            {99BDA97A-4AA8-11E0-9E8D-32B2F9D7AC32} Digital Publishing
            {9B4F8AA7-DDFA-4A0F-A36C-D0F66CCD66F7} Adobe Dreamweaver CS5.5
            {9BA136BE-0077-41E1-AD56-56AB5D4A1A67} Adobe ExtendScript Toolkit CS5.5
            {9F747BEC-FB4E-4830-8C58-363B8DCC26EB} Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack
            {9FBC5BF9-5019-49D6-A1B3-6BB0E2A1FA54} Pixel Bender Toolkit
            {9FC6805B-9FD9-410A-A620-51D58644999D} Camera Profiles Installer_7.1_AdobeCameraRawProfile7.0All
            {9FE2BFB0-1DBE-4269-AEBA-A870C5990BEA} Adobe Dreamweaver Widget Browser
            {A0F72081-99FB-4FFA-AE1A-62B5A656CAC1} AdobeTypeSupport CS6
            {A1181890-9FA4-11DF-A25D-A35DF04EC7B1} Adobe Toolhints CS5.5
            {A2502D10-2D75-4620-8A8B-73F39D5C1243} PDF Settings CS5
            {A44863BF-8DB8-4D22-88DB-5A02BE319840} Adobe Linguistics CS5
            {A516708E-EC03-40F5-B82E-0851A44B3780} Adobe Illustrator CS5.1
            {A80C015C-1939-42A5-AD2F-E76C7F194505} AdobeColorJA CS5.5
            {AA0D312F-1570-4E7E-9A7D-E191E0090FEC} AdobeHelp
            {AACC8FA2-3823-4E4E-BB99-A96902E8AB71} Adobe Dreamweaver CS5.5_11.5.3_AdobeDreamweaver11.5en_USLanguagePack
            {AC003BC0-704F-4F02-A72E-AC8B7044DE24} AdobeOutputModule
            {AC76BA86-1033-F400-7760-000000000005} Acrobat X Pro
            {ADC78ABC-AF09-47D2-977F-E27850E3CC1C} Adobe Dreamweaver CS5.5_AdobeDreamweaver11.5en_USLanguagePack
            {B62DD919-22B1-4AB8-A930-BC4540A1E8B6} Adobe Premiere Pro CS6 Family
            {B98E0DCB-1A75-4394-9813-3A114AA3891D} Adobe Mini Bridge CS6
            {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5
            {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5
            {BD85DFD4-005F-4219-8E27-C922CC4D8A61} Adobe CSXS Extensions CS5.5
            {C0329E33-DEB4-48D9-B7B6-19493A6F062E} Adobe After Effects CS5.5
            {C1302004-7A3C-467A-80AC-4D0C9F6982C1} Adobe After Effects CS5.5 Presets
            {C1646326-4AA6-11E0-AE8E-4C9CF9D7AC32} Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_US
            {C2F8BD34-1692-40F9-BA1B-1CFB2B5FED3A} Adobe After Effects CS5.5 Third Party Content Wrapper
            {C346BBCF-A687-4500-BB19-EE9C2D6FF284} Suite Shared Configuration CS6
            {C5CA53A2-E722-4D76-B5AC-71522CC48AB3} AmericanEnglishSpeechAnalysisModels
            {C61B093E-259E-45D8-B9B6-24630A700398} Adobe After Effects CS5.5_AdobeAfterEffects10.5en_USLanguagePack
            {CC006FD6-00EF-46FC-ACA0-7A28EFF44D20} Adobe Media Encoder CS6
            {CC35904A-0197-4F06-BD70-9CE3DB24DBFD} AdobeColorVideoProfilesAE CS5.5
            {CDAC14AB-1424-4E9C-8515-EA89D7F37243} Adobe Premiere Pro CS6 Support
            {CE6E1448-516F-11E0-B3C0-13EDE2AB3DC5} Adobe InDesign CS5.5 Application Feature Set Files
            {CFC3110A-491C-4DBF-A97D-66C567600A2F} Photoshop Camera Raw 7
            {D094CE41-D4F5-473E-8915-B1D026CB193E} Adobe Premiere Pro CS6_AdobePremierePro6.0en_USLanguagePack
            {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1} Adobe After Effects CS5 Template Projects & Footage
            {D682C558-6F3F-4800-885C-4C5EB1B7338C} Adobe Buzzword CS5.5
            {D8B9B5FB-D388-4D79-AA4B-6C09641189F6} Adobe Utilities CS5.5
            {D97AF04B-B70A-4862-BC25-31E6D9C4A529} Adobe Flash CS5.5
            {D9F625C8-FD5B-4C13-9B3C-5B9F09BA0DC0} Adobe Flash CS5.5_11.5.1_AdobeFlash11.5-mul
            {DBCFA16A-59EC-4DAF-98D1-B4E2C2A9E7B4} Adobe Encore CS6 Support
            {DD18D60C-87B1-47D9-8312-67508B402FB9} SiteCatalyst NetAverages CS5.5
            {DE7C6FA1-AF75-48A8-B495-CFAD529BCC3D} Recommended Common Fonts Installation
            {DE88AA40-6766-43D3-A755-8FC374B3D2C3} DynamiclinkSupport
            {DEA79551-23E3-430A-9B15-B544479B7DB2} Flash Player
            {E348E466-429A-4FB0-AFCF-8306C16BBFF1} Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-mul
            {E8B1DAAA-0B6B-44E6-A2D3-8E418EA0EA85} AdobeCMaps CS6
            {EB186BF2-0A84-40A2-B794-0326D3DF9973} AdobeColorVideoProfilesCS CS5.5
            {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6
            {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5
            {ED9DC850-516E-11E0-9096-1FE5E2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_US
            {EDE888ED-3BD7-4D8C-AB35-7E4C661A94D9} Adobe Photoshop CS5.1 English Language Pack_AdobePhotoshop12-en_US
            {EE85C227-0148-4825-B659-6A1E142571EE} Adobe Bridge CS5.1
            {EF45880C-DD84-46C3-A054-0BC5F76A6BBE} Adobe Photoshop CS5.1 Support
            {F220AB5F-D84D-483F-8D47-7E4C8A027DBF} Adobe Dreamweaver CS5.5_11.5.3_AdobeDreamweaver11.5-mul
            {F313167E-5172-11E0-ACE7-30C2E3AB3DC5} Adobe InDesign CS5.5 Common Base Files
            {F8ABD584-A99C-4304-AC4B-CCFD0914D871} Adobe Linguistics CS5.5
            {FA148573-E0E5-400F-8978-D95410035F18} Photoshop Camera Raw 7_7.1_AdobeCameraRaw7.0All
            {FECCB1BF-038D-41C2-861B-4560E7667005} AdobeColorEU CS5.5
            [   0] Tue Jul 24 20:35:10 2012  INFO
            [   0] Tue Jul 24 20:35:10 2012 ERROR
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            ______ Verifying payload integrity ______
            Checking for payloads having same family and product names but different adobe codes
            ______ Verifying payload integrity : Passed ______
            Operation order summary:
            When distributing payloads across media, the following order must be preserved, except that
            adjacent payloads with the same mediaGroup can be re-ordered across media boundaries without introducing
            extraneous media swaps for the user.
            :: END TIMER :: [CreatePayloadSession] took 2566 milliseconds (2.566 seconds) DTR = 14.0296 KBPS (0.0137008 MBPS)
            *** Checking patch payload : {6AFE0576-7A2C-11E1-88D2-74AAF24106A5}
            installDBPath : /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xCommonBase-mul-300312112144/Install.db
            Successfully Opened installDB
            Payload is not customized
            Parent AdobeCode : {F313167E-5172-11E0-ACE7-30C2E3AB3DC5}
            Parent Installation directory : /Applications
            *** Checking patch payload : {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5}
            installDBPath : /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppBase-mul-300312111735/Install.db
            Parent AdobeCode : {0CCF0458-5171-11E0-BC45-DC59E3AB3DC5}
            [   0] Tue Jul 24 20:35:14 2012 DEBUG
            *** Checking patch payload : {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5}
            installDBPath : /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppLang-en_US-300312110256/Install.db
            Parent AdobeCode : {ED9DC850-516E-11E0-9096-1FE5E2AB3DC5}
            *** Checking patch payload : {FE75A95E-7A2B-11E1-8037-B59BF24106A5}
            installDBPath : /Users/DASK/Library/Caches/Adobe/AAMUpdater/AdobeInDesignCS5.5-7.5/7.5.3.333/InDesignCS5. 5-AdobeUpdate/payloads/AdobeInDesign7xAppBase2-mul-300312112049/Install.db
            [   0] Tue Jul 24 20:35:15 2012 DEBUG
            Parent AdobeCode : {03FB981A-5170-11E0-A90E-3CEDE2AB3DC5}
            [   0] Tue Jul 24 20:35:16 2012  INFO
            [   0] Tue Jul 24 20:35:16 2012 DEBUG
            Requested action "install" for {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333
            Requested action "install" for {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333
            Requested action "install" for {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333
            Requested action "install" for {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333
            Using installer mode 0
            ::START TIMER:: [Setting Payload Actions]
            PayloadPolicyInit: BEGIN Updating installstate for payloads
            PayloadPolicyInit: END Updating installstate for payloads
            PayloadPolicyInit: BEGIN Creating policyNodes
            PayloadPolicyInit: END Creating policyNodes
            PayloadPolicyInit: BEGIN Calculating initial graph
            PayloadPolicyNode._SetPayloadAction: repair for {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333
            PayloadPolicyNode.SetAction: FN->FY for {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333
            PayloadPolicyNode.ComputeConstraint: Static installMode 1 mode constraint is 0 0, N for {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333
            PayloadPolicyNode.ComputeConstraint: Static installMode 0 mode constraint is 2 12, Y for {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333
            PayloadPolicyNode._SetPayloadAction: install for {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333
            PayloadPolicyNode.SetAction: IY->IY for {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333
            PayloadPolicyNode.ComputeConstraint: Static installMode 0 mode constraint is 0 0, N for {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333
            PayloadPolicyNode._SetPayloadAction: install for {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333
            PayloadPolicyNode.SetAction: FN->FY for {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333
            PayloadPolicyNode.ComputeConstraint: Static installMode 0 mode constraint is 0 0, N for {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333
            PayloadPolicyNode._SetPayloadAction: install for {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333
            PayloadPolicyNode.SetAction: FN->FY for {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333
            PayloadPolicyInit: END Calculating initial graph
            Setting action for {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333 per deployment file.
            Setting action for {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333 per deployment file.
            Setting action for {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333 per deployment file.
            Setting action for {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333 per deployment file.
            :: END TIMER :: [Setting Payload Actions] took 54 milliseconds (0.054 seconds) DTR = 74.0741 KBPS (0.072338 MBPS)
            [   0] Tue Jul 24 20:35:17 2012  INFO
            [   0] Tue Jul 24 20:35:17 2012 DEBUG
            ::START TIMER:: [SimulatePayloadOperations]
            [   0] Tue Jul 24 20:35:18 2012  INFO
            [   0] Tue Jul 24 20:35:18 2012 DEBUG
            Creating instruction for payload {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333
            [   0] Tue Jul 24 20:35:18 2012  WARN
            Creating instruction for payload {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333
            EMPTY SET Dependent operations for DRIVER {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333
            Operation can be attempted
            Creating instruction for payload {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333
            Creating instruction for payload {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333
            :: END TIMER :: [SimulatePayloadOperations] took 203 milliseconds (0.203 seconds)
            Opened installation queue
            Custom action code for pre- install for payload {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333 returned : 0
            [   1] Tue Jul 24 20:35:19 2012  INFO
            [   0] Tue Jul 24 20:35:20 2012  INFO
            :: END TIMER :: [Payload Operation :{848BF4CC-7A2B-11E1-8A90-3F8CF24106A5}] took 1175 milliseconds (1.175 seconds)
            [   0] Tue Jul 24 20:35:20 2012 DEBUG
            Custom action code for pre- install for payload {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333 returned : 0
            [   1] Tue Jul 24 20:35:20 2012  INFO
            [   0] Tue Jul 24 20:35:21 2012  INFO
            :: END TIMER :: [Payload Operation :{C68C3E1A-7A29-11E1-A9D9-0F55F24106A5}] took 1126 milliseconds (1.126 seconds)
            [   0] Tue Jul 24 20:35:21 2012 DEBUG
            Custom action code for pre- install for payload {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333 returned : 0
            [   1] Tue Jul 24 20:35:21 2012  INFO
            [   0] Tue Jul 24 20:35:22 2012  INFO
            :: END TIMER :: [Payload Operation :{FE75A95E-7A2B-11E1-8037-B59BF24106A5}] took 1058 milliseconds (1.058 seconds) DTR = 3.78072 KBPS (0.00369211 MBPS)
            [   0] Tue Jul 24 20:35:24 2012  INFO
            [   0] Tue Jul 24 20:35:24 2012 ERROR
            :: END TIMER :: [Total Timer] took 20004 milliseconds (20.004 seconds) DTR = 2.79944 KBPS (0.00273383 MBPS)
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-fi_FI
            MinVersion: 0.0.0.0
            This parent relationship is not satisfied, because this payload is not present in this session.
            This payload will be ignored in this session.
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-sv_SE
            MinVersion: 0.0.0.0
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-fr_CA
            MinVersion: 0.0.0.0
            Family: InDesign
            ProductName: Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-tr_TR
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            Family: InDesign
            MinVersion: 0.0.0.0
            • 3. Re: InDesign CS5.5 - Update Error U44M1P7
              Carl Sun Level 4
              You must have deleted all non-English resource files in InDesign. Did you delete them after you had reinstalled InDesign? The following error message appeared for more than 20 languages:
                  Family: InDesign
                  MinVersion: 0.0.0.0
              Besides fi_FI (Finnish), there are fr_CA (Canadian French), de_DE (German), ja_JP (Japanese), etc.
              You can copy back all files you have deleted from other machine then retry update, or you have to reinstall InDesign then update.
              • 4. Re: InDesign CS5.5 - Update Error U44M1P7
                theEggplant Level 1
                In one of the posts I read to assist with this, it was recommended to uninstall cs5.5 completely, run the adobe cs5.5 cleanup tool and then reinstall.
                I guess that must have done it but after reinstalling wouldn't it have put them back in?
                I didn't manually remove them.
                Warm regards,
                Sacha Kiefer
