10 Replies Latest reply on Jul 28, 2012 12:10 AM by pwillener
    Flash Player fails to register on 3 PCs!
    tonymuffin
      This is maddening... Here I am prompted in the past couple days to update Flash Player on my PCs however, the installation fails to register on 3 of them.
      I am running Windows 7 64bit on all 3, IE8 on 2 and IE9 on 1.  Same issue with all 3!
      I have followed the installation support instructions, downloaded the Flash Uninstalled, downloaded the latest Flash version, re-installed and the same thing continues to happen.
      How does one fix this?  This is crazy!
        • 1. Re: Flash Player fails to register on 3 PCs!
          pwillener Level 8
          "Failed to register" is a permission issue, usually in the Windows registry.
          Did you run the installation as an Administrator user?  Or did you allow the background update, which should not require an Admin user?
          The ultimate fix for permission issues is described in http://forums.adobe.com/thread/987370
          • 2. Re: Flash Player fails to register on 3 PCs!
            tonymuffin Level 1
            I did run it as Amin.  No love.....
            • 3. Re: Flash Player fails to register on 3 PCs!
              tonymuffin Level 1
              Also, I found the link you listed, http://forums.adobe.com/thread/987370 yesterday and have already tried that.  It doesn't work either!  Where can I get assistance with this extremely annoying problem?
              • 4. Re: Flash Player fails to register on 3 PCs!
                pwillener Level 8
                Can you post the contents of a FlashPlayer.log file in either C:\Windows\system32\Macromed\Flash or C:\Windows\syswow64\Macromed\Flash or both?
                • 5. Re: Flash Player fails to register on 3 PCs!
                  tonymuffin Level 1
                  As I needed to get my main computer running with Flash I restored it to a previous date when Flash was working and then configured Flash to NOT UPDATE.  I will send the log files from my other computers exhibiting the same issue shortly.
                  • 6. Re: Flash Player fails to register on 3 PCs!
                    tonymuffin Level 1
                    How do you propose to post the contents of the log file?  I can't attach anything here and it will not accept a cut and paste from the log files??
                    • 7. Re: Flash Player fails to register on 3 PCs!
                      pwillener Level 8
                      You can paste using the standard Windows keyboard shortcut Ctrl+V.
                      • 8. Re: Flash Player fails to register on 3 PCs!
                        tonymuffin Level 1
                        Um.....nope.. I can't.. Which is why I asked the question...
                        • 9. Re: Flash Player fails to register on 3 PCs!
                          pwillener Level 8
                          I don't understand; what happens when you try?
                          Here, I am just pasting the contents of my FlashInstall.log file...
                          =O====== M/11.3.300.268 2012-07-27+00-58-22.623 ========
                          0000 [I] 00000010 "C:\Users\PWILLE~1\AppData\Local\Temp\{1A5228D7-8420-41E2-95DF-7033EDDA351E}\InstallFlash Player.exe" -install -skipARPEntry -iv 1 -au 4294967295
                          0001 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                          0002 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                          0003 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_3_300_268.ocx
                          0004 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_ActiveX.exe
                          0005 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_ActiveX.dll
                          0006 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                          =X====== M/11.3.300.268 2012-07-27+00-58-26.587 ========
                          =O====== M/11.3.300.268 2012-07-27+00-58-47.927 ========
                          0000 [I] 00000010 "C:\Users\PWILLE~1\AppData\Local\Temp\{FE0E85F8-C5B5-4227-B233-B5D230F2C815}\InstallFlash Player.exe" -install -skipARPEntry -iv 1 -au 4294967295
                          0002 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                          0003 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
                          0004 [W] 00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
                          0005 [W] 00001036 Software\Mozilla\Waterfox\extensions/Plugins 2
                          0006 [W] 00001036 Software\Opera Software/Last CommandLine 2
                          0007 [W] 00001036 Software\Opera Software/Last CommandLine 2
                          0008 [W] 00001036 Software\Opera Software/Plugin Path 2
                          0009 [W] 00001036 Software\Opera Software/Plugin Path 2
                          0010 [I] 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_3_300_268.dll
                          0011 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_Plugin.exe
                          0012 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                          =X====== M/11.3.300.268 2012-07-27+00-58-51.389 ========
                          =O====== M/11.3.300.268 2012-07-27+00-58-13.664 ========
                          0000 [I] 00000010 "C:\Users\pwillener\Downloads\install_flash_player_11_active_x(1).exe"
                          0002 [I] 00000011 1
                          0003 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_3_300_268.ocx
                          0004 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.exe
                          0005 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.dll
                          0007 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                          0008 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                          0009 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                          0010 [W] 00001106
                          0011 [W] 00001106
                          0012 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                          =X====== M/11.3.300.268 2012-07-27+00-58-35.371 ========
                          =O====== M/11.3.300.268 2012-07-27+00-58-40.360 ========
                          0000 [I] 00000010 "C:\Users\pwillener\Downloads\install_flash_player_11_plugin(1).exe"
                          0002 [I] 00000011 1
                          0004 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
                          0005 [W] 00001036 Software\Opera Software/Last CommandLine 2
                          0007 [W] 00001036 Software\Opera Software/Plugin Path 2
                          0009 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_3_300_268.dll
                          0010 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_Plugin.exe
                          0011 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
                          0013 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
                          0014 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
                          0015 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_3_300_268.exe
                          0016 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                          0017 [W] 00001106
                          0018 [W] 00001106
                          0019 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
                          Message was edited by: Pat Willener - added the 32-bit log as well.
                          • 10. Re: Flash Player fails to register on 3 PCs!
                            pwillener Level 8
                            There is another topic open with a similar problem; see http://forums.adobe.com/message/4584448#4584448
                            Can you try what Chris Campbell suggested in his last post?
