4 Replies Latest reply on Jul 25, 2012 7:42 AM by Neil-Kentucky
    Calculate Months from Field Date
    Neil-Kentucky
      Using: Acrobat X Pro in windows.
      I have three fields:
      1) Today's Date:___________ [DateToday] -- Automatically filled-in with today's date using script.
      2) Date Last Payment Made:__________ [LastPaymentMade1] -- Filled-in by user in mm/dd/yyyy format.
      3) Months Since Last Payment:______________ [MoBehind] -- Need to calculate from field 1 - 2).
      For #3, how do I custom calculate how many MONTHS it has been (#3) since the date the last payment was made (#2)?
      There's a great discussion here on this topic but I cannot figure out how to modify the script for my purposes: http://forums.adobe.com/message/1907993#1907993
      This appears to be the closest thing to what I want:
      function Floor(fValue) {
      return Math.floor(fValue);
      function Date2Num(sDate, sFormat) {
      var fSecond =1000;
      var fMinute = 60 * fSecond;
      var fHour = 60 * fMinute;
      var fDay = 24 * fHour;
      var oDate = util.scand(sFormat, sDate);
      var fDate = oDate.valueOf();
      var fDate = fDate / fDay;
      var fDate = Floor(fDate);
      return fDate;
      var Start = this.getField("DateToday").value;
      var sFormat = "mm/dd/yyyy";
      var End = this.getField("LastPaymentMade1").value;
      var eFormat = sFormat;
      event.value = Date2Num(End, eFormat) - Date2Num(Start, sFormat);
      Here's another one that looks SIMILAR to what i want:
      (function () {
          // Get date from field
          var v = getField("DateToday").value;
          if (v) {
              // Convert string to date
              var d = util.scand('mm/dd/yyyy', v);
              // Add number of days in NUMDAYS field
              d.setDate(d.getDate() - +getField("NumDays").value);
              // Set value of this field to the new date
              event.value = util.printd("mm/dd/yyyy", d);
          } else {
              // Blank field if no date entered
              event.value = "";
        • 1. Re: Calculate Months from Field Date
          Since the number of days in a month are not constant across a year I do not think you can use the milliseconds in a day.
          I you use the 'getMonth()' and 'getFullYear()' methods for the calculation.
          // get the date values
          // convert to date object
          var oStart = util.scand(sForamt, Start);
          var oEnd = util.scand(eFormat, End);
          // get start month
          var StartMonth = oStrat.getMonth();
          // add start full year as months
          StartMonth = StartMonth + (oStart.getFullYear() * 12);
          // get end month
          var EndMonth = oEnd.getMonth();
          // add end full year as months
          EndMonth = EndMonth + (oEnd.getFullYear() * 12);
          // compute difference in months
          var diffMonths = EndMonth - StratMonth;
          • 2. Re: Calculate Months from Field Date
            Neil-Kentucky Level 1
            That looks good.  How do I associate the getFullYear() and other field to the field dates on my form?
            • 3. Re: Calculate Months from Field Date
              I found a typo in the code, just a minor one, but it still isn't working when I place the code in the custom calculation script in my form.  I've ensured that therer is data in the corresponding fields and yet the field is blank.
              • 4. Re: Calculate Months from Field Date
                PS, in the java console, the output is:
                ReferenceError: EndMonth is not defined
                1:Console:Exec
                undefined
