0 Replies Latest reply on Jul 24, 2012 5:58 PM by lsiunsuex
    Record from webcam to f4v on FMS
    lsiunsuex
      I'm trying to build / modify an application to record from webcam and microphone, in a web browser and save it to an FMS 5.4.2 server to stream via web and iOS
      recording as a flv file works fine and it plays back just fine in firefox / any browser
      I can steam f4v files over http as filename.f4v.m3u8 and that works fine with the samples that come with FMS from my record folder (/opt/adobe/fms/applications/record/streams/)
      My flash web application can record to the FMS server, the file it records has the .f4v file extension, has content (i see the file size), and has time in quicktime (4 or 5 seconds - just a test) but it doesn't play - the screen is black and never starts.
      I know i'm right on the edge of figuring this out, I just don't know what I'm missing or whats wrong (i'm a php programmer, not action script)
      any ideas ?
      here is the code i'm working with:
      package com
          import fl.controls.ProgressBar;
          import fl.controls.ProgressBarMode;
          import flash.display.MovieClip;
          import flash.events.Event;
          import com.NetConnector
          import flash.events.MouseEvent;
          import flash.events.TimerEvent;
          import flash.media.Camera;
          import flash.media.Microphone;
          import flash.media.Video;
          import flash.net.navigateToURL;
          import flash.net.NetConnection;
          import flash.net.NetStream;
          import flash.net.URLLoader;
          import flash.net.URLLoaderDataFormat;
          import flash.net.URLRequest;
          import flash.net.URLRequestMethod;
          import flash.net.URLVariables;
          import flash.text.TextField;
          import flash.utils.setTimeout;
          import flash.utils.Timer;
          import flash.media.H264Level;
          import flash.media.H264Profile;
          import flash.media.H264VideoStreamSettings;
          import flash.media.VideoCodec;
           * @author Alexander (flash2you) < >
          public class Recorder extends MovieClip
              private var dataHolder:DataHolder = DataHolder.getInstance()
              public var layer:MovieClip
              public var activityLevel_pb:ProgressBar
              public var aguja:MovieClip
              public var aguja2:MovieClip
              public var publishButton:MovieClip
              public var timer_txt:TextField
              public var recordStatus:MovieClip
              public var recordBtn:MovieClip
              private var netStream:NetStream
              private var microphone:Microphone = Microphone.getMicrophone()
              private var camera:Camera = Camera.getCamera()
              public var  video:Video
              private var timer:Timer = new Timer(100)
              private var clockTimer:Timer = new Timer(1000)
              public var published:Boolean = false
              private var isRecording:Boolean = false
              private var minutero = 0;
              private var crono = 0;
              private var records = 0;
              public var settings_mc:MovieClip
              public static var recorder:Recorder
              public var settings_icon:MovieClip
              private var limitTimer:Timer
              public function Recorder()
                  Recorder.recorder = this;
                  timer.addEventListener(TimerEvent.TIMER, on$timer)
                  clockTimer.addEventListener(TimerEvent.TIMER, on$clockTimer)
                  //visible = false
                  recordBtn.buttonMode = true
                  recordBtn.addEventListener(MouseEvent.CLICK , recordBtn$click)
                  recordBtn.addEventListener(MouseEvent.MOUSE_OVER, recordBtn$over)
                  recordBtn.addEventListener(MouseEvent.MOUSE_OUT, recordBtn$out)
                  addEventListener(Event.ADDED_TO_STAGE, onAddedToStage)
                  limitTimer = new Timer(dataHolder.timelimit * 1000);
                  limitTimer.addEventListener(TimerEvent.TIMER, onLimitTimerHandler)
              private function onLimitTimerHandler(e:TimerEvent):void
                   stopPublish()
               *  when we comes to second frame
              private function onAddedToStage(e:Event):void
                  removeEventListener(Event.ADDED_TO_STAGE, onAddedToStage);
                  init()
               *   function for set up camera from settings module
              public function setCamera(_camera:Camera) {
                  camera = _camera
                  addCameraSettings()
                  video.width = 1280;
                  video.height = 720;
                  video.attachCamera(camera)
                  if (netStream){
                      netStream.attachCamera(camera)
              public function setMicrophone(mic:Microphone) {
                  microphone = mic;
                  if (netStream){
                      netStream.attachAudio(microphone)
                  addMicSettings()
              private function addMicSettings() {
                  microphone.setUseEchoSuppression(true);
                  microphone.setSilenceLevel(1)
              private function addCameraSettings():void
                  camera.setMode(1280, 720, 25);
                     camera.setLoopback(true);
                     camera.setQuality(0, 100);
              public function init() {
                  startConnect()
               *  main function for connection
              private function startConnect() {
                  visible = true
                  timer_txt.htmlText = "<b>00:00</b>";
                  initCamera()
                  initMicropone()
                  var nc:NetConnection = new NetConnection()
                  nc.connect(null)
                  netStream = new NetStream(nc)
                  layer.visible = false
                  publishButton.gotoAndStop(1);
                  activityLevel_pb.mode = ProgressBarMode.MANUAL;
                  recordStatus.gotoAndStop("noRecord")
                  timer.start()
                  connection.addEventListener(NetConnector.CONNECTED, connectionComplete)
                  connection.startConnection()
              public function get connection():NetConnector {
                  return dataHolder.connection
              private function on$timer(e:TimerEvent) {
                  activityLevel_pb.setProgress(microphone.activityLevel, 100)
               *  when connection to your stream server done
              private function connectionComplete(e:Event = null) {
                  netStream = new NetStream(connection)
               *   add 0 if less then 10secs
              private function addLeading(nbr) {
                  if (nbr<10) {
                      return ("0"+Math.floor(nbr));
                  } else {
                      return (Math.floor(nbr).toString());
               *   update visible clock, rotate arrows
              private function updateTimer() {
                  timer_txt.htmlText = "<b>"+addLeading(crono/60)+":"+addLeading(crono%60)+"</b>";
                  aguja.rotation = aguja.rotation+6;
                  if (addLeading(crono/60)>minutero) {
                      aguja2.rotation = aguja2.rotation+6;
                      ++minutero;
                  // end if
                  ++crono;
              private function on$clockTimer(e:TimerEvent):void
                  updateTimer()
              private function startClockTimer() {
                  clockTimer.start()
               *  update graphics and start recording
              private function recordBtn$click(e:MouseEvent):void
                  if (!isRecording) {
                      startRecording()
                      recordStatus.gotoAndStop("record")
                      recordBtn.visible = false
              private function recordBtn$over(e:MouseEvent):void
                  if (!isRecording) {
                      this.gotoAndPlay(65);
              private function recordBtn$out(e:MouseEvent):void
                  if (!isRecording) {
                      this.gotoAndPlay(61);
              private function startRecording() {
                  if (connection.connected){
                      netStream.publish("mp4:" + dataHolder.filename + ".f4v", "record");
                  isRecording = true
                  startClockTimer()
                  publishButton.gotoAndPlay(2)
                  publishButton.buttonMode = true
                  publishButton.addEventListener(MouseEvent.CLICK, publishButton$click);
                  limitTimer.start()
               *  redirect to finishURL that was passed via flashvars
              private function publishButton$click(e:MouseEvent):void
                  stopPublish()
                  var request:URLRequest = new URLRequest(dataHolder.finishURL)
                  navigateToURL(request, "_self")
              private function stopPublish():void
                  netStream.close();
                  connection.close();
                  limitTimer.stop();
                  clockTimer.stop();
                  isRecording = false
                  recordStatus.gotoAndStop("recordEnd")
                  updateTimer();
               *  init microphone
              private function initMicropone():void
                  microphone = Microphone.getMicrophone()
                  addMicSettings()
               *  init camera
              private function initCamera():void
                  camera = Camera.getCamera()
                  addCameraSettings()
