2 Replies Latest reply on Jul 25, 2012 2:43 PM by JJBBDD
    Showing/Hiding annotation with onFocus/onBlur
    JJBBDD
      Hi-
      I'm having trouble using the onBlur and onFocus events in the same form field.
      I have an annotation that has these props when the document loads: What hidden=true and popupOpen=false
      On a form field, I've attached the following script to the onFocus event:
      var annot = this.getAnnot(0,'phoneTip');
      annot.setProps({
          hidden:false,
          popupOpen:true
      This works fine when I don't have an onBlur event. (The annotation shows up when cursor enters field)...
      BUT, when I add the following script to the onBlur event, the annotation disappears and doesn't come back onFocus:
      annot.setProps({
          hidden:true,
          popupOpen:false
      What seems to be happening is the OnBlur event is firing right after the onFocus. When I dump the annot props above the set method in onBlur, I do see the correct values (hidden=false, popupOpen=true).. Maybe when I show the annotation, the annotation itself gets focus, and therefore the field loses focus and the onBlur event fires?)
      Does anyone know a workaround for this? Maybe a way to maintain focus on the form field?
