1 Reply Latest reply on Jul 26, 2012 11:38 PM by Willam van Weelden
    RH Automatically Changing HTML Code for Links
    LaKisha1 Level 1
      For some reason, RH is doing something to the links I create. In my stylesheet, I have the following code for links:
      a {
          color: #054abc;
          cursor: pointer;
      a:hover {
          color: #336699;
          text-decoration: none;
      a:active {
          color: #333333;
      When I create a link, the HTML code looks like this *at first*:
      <a href="Development_Plan.htm">Development Plan</a>
      But then, after I save the file and switch to HTML view, the code looks like this:
      <a href=" Development_Plan.htm" style="color: #0000ff; text-decoration: underline; ">Transcript</a>
      I am not doing anything other than saving the file, and that apparently causes RH to automatically add the style (color and text-decoration). Why is RH adding that? It's causing my links not to change color when you hover over them.
      How can I make RH stop doing that, so my links display as defined in the stylesheet?
        • 1. Re: RH Automatically Changing HTML Code for Links
          Willam van Weelden Adobe Community Professional & MVP
          This is strange behaviour. How exactly do you create a hyperlink? I have seen this behaviour only with links that are empty or contain a single space.
          As a workaround, in your css, add the !important declaration to your hover styles:
          a:hover
          Although this isn't an elegant solution, it will overwrite the inline styling of the link and thus change colour on hover.
          Greet,
          Willam
