7 Replies Latest reply on Jul 27, 2012 7:50 AM by Harm Millaard
    AVCHD files in PrPro 5 (playback- & editingproblems)
    mo tucker
      Hi
      I have to edit a project in PrPro CS 5 with AVCHD files:
      (MediaInfo:)
      General
      Complete name               D:\(...)\STREAM\00002.MTS
      Format                            BDAV
      Format/Info                     Blu-ray Video
      Overall bit rate mode      Variable
      Overall bit rate               16.2 Mbps
      Max. Overall bit rate      18.0 Mbps
      Video
      Format                                    AVC
      Format/Info                             Advanced Video Codec
      Format profile                         Main@L4.0
      Format settings, CABAC        Yes
      Format settings, ReFrames    2 frames
      Format settings, GOP             M=2, N=13
      Codec ID                                 27
      Bit rate mode                         Variable
      Bit rate                                   15.1 Mbps
      Maximum bit rate                    16.0 Mbps
      Width                                     1 440 pixels
      Height                                    1 080 pixels
      Display aspect ratio              16:9
      Frame rate                            25.000 fps
      Color space                          YUV
      Chroma subsampling            4:2:0
      Bit depth                               8 bits
      Scan type                             Interlaced
      Scan order                           Top Field First
      Bits/(Pixel*Frame)                 0.389
      Stream size                          23.3 MiB (93%)
      My problem:
      The playback of the files is very very bad - even in low resolution.
      Reverse playback starts after a delay of maybe 3 sec.
      There are about 300+ clips in this project.
      Everytime I open the project PrPro links (loads) all these files AGAIN - which takes apout 1 or 2 minutes.
      Computer
      Win7 64bit / PrPro CS 5 / nVidia Quadro 4000 / 24gb RAM / 2xQuadCore
      Optimized for best performance etc.
      Solution?
      AVCHAD is Interfame - I think this causes the problems.
      I tried to encode to DNxHD 120 but this is slow, too.
      So, what should I do?
      Best regards
      jo
