1. Re: What is the situation with Encore-Multi Movie Timelines and Stop Marker equivalents?
Stan Jones Jul 28, 2012 2:51 PM (in response to A.T. Romano)The main methods are:
Export movies from the editing program (e.g. Premiere or PE) in chapter length. An Encore timline is made for each movie. Each Chapter button links to one of those movies.
You create a playlist (with this chapter timelines in it), and the "play all" button links to that play all playlist.
Or, you export one video from PR/PE with chapter markers. You create a chapter playlist (not a playlist) that contains one chapter per playlist. The chapter button links to one of those chpater play lists. The play all button links to the main timeline.
As of CS6, Encore can do a Bluray chapter playlist.
2. Re: What is the situation with Encore-Multi Movie Timelines and Stop Marker equivalents?
Bill Hunt Jul 28, 2012 5:46 PM (in response to A.T. Romano)ATR,
Welcome over here!
Not sure about the term, "Stop Action" in Encore. However, and as Stanley points out, all that you wish to do can be done in Encore, and easily.
Depending on the navigation that you will ultimately desire, you might want to use multiple Timelines, which can BE "chapters" themselves, or can HAVE Chapters in them. With the use of Playlists (working on the Timeline level), you can set the navigation as needed, and if you need finer control, then can use Chapter Playlists (similar, but different), also.
To get from PrElements, you would want to use one of two workflows:
- Export/Share your PrE Timeline(s) as DV-AVI, to be Imported into Encore as Timelines.
- Export/Share your PrE Timeline(s) as MPEG-2 DVD, with a Bit-Rate, that will allow for the total Duration of your Timeline(s), allowance for Menus and navigation vs the size of disc chosen, DVD-5, or DVD-9. A Bit-Rate calculator would be useful for this purpose.
While one can gang Assets, like DV-AVI's onto a single Timeline, there can be issues with that, and I prefer to create separate Timelines for each.
Good luck, and nice seeing you around this forum.
3. Re: What is the situation with Encore-Multi Movie Timelines and Stop Marker equivalents?
A.T. Romano Aug 4, 2012 2:32 PM (in response to Stan Jones)Stan Jones and Bill Hunt
Sorry for the delayed response.
Thanks for your replies. The information provided will be very helpful in trying to reconcile my experiences with Premiere Elements disc menus with the disc menus opportunities in Encore.
Thanks for the welcome.
ATR
