I don't usually print my Photoshop documents, but when I scan something and need to make changes I do it with Photoshop.
In the past this worked fine. Since I upgraded to CS5.5 I have been having a problem. Even the background paper of the scanned item which is supposed to be white has green tint to it. The Photoshop originated type prints as slightly fuzzy black with a larger slightly fuzzy green behind it.
On the monitor everything looks fine and when I print from my word processing program everything comes out fine. However, I tried printing text from an Illustrator document, it was sharp but it too had what can be described as a sharp green shadow.
Even when I changed the PS document to a GreyScale image, it still printed out just like the RGB and CMYK settings, with a green background and black and green text.
Lastly, I took a screen shot of the PS document and a screen shot of some other text documents not created with PS and they also printed out with the green color cast.
At first I thought that I was a PS issue because my word processing documents print fine. But since the screen shots print incorrectly I don't know what it could be. The only thing that I do know is that it started after I installed CS5.5
On a MacPro Intel, using OX 10.6.8 and CS5.5, HP PhotoSmart C4480 Printer (I am not using HP ink cartridges, I've always used a cheaper web brand)
Thanks in Advance
