9 Replies Latest reply on Aug 4, 2012 9:33 PM by kal192
    TrkMat luma colour change
    kal192
      I have a cartoon drawn in black on a white background. I have put a black layer infront of the cartoon and changed the trkmat to inv luma. So the white part becomes transparent. Unfortunately the black lines don't show because they turn black.
      If I change the layer solid colour to blue then the lines show as blue. What I want is for the lines to be white but the layer solid to be black. Any help appreciated
      Kal
        • 1. Re: TrkMat luma colour change
          Greg Baber Adobe Employee
          Sorry if I missed a part of what you were saying, but I think it's a situation where you need to use a white solid layer as the layer with the matte.  Then put a black solid behind those layers - then you will have white lines on a black background.
          • 2. Re: TrkMat luma colour change
            kal192 Level 1
            Hi Greg, thanks for your response. Doing what you suggested gives me a white foreground.
            Here is my cartoon in a black composition
            When I add a white solid it looks like this...
            (the blue is just me indicating where the comp ends.)
            Here is what the after effects panel is...
            Now what I wanted is like image 2 but instead of the surrounding being white. I want it black. Kind of like this...
            Hope that makes sense.
            Thanks again so much for your help
            Kal
            • 3. Re: TrkMat luma colour change
              Does Find Edges on the original drawing give you the look you want?  Try turning on Invert inside Find Edges.
              • 4. Re: TrkMat luma colour change
                kal192 Level 1
                Thank you again for your response Greg.
                Alas no, that just emphasised the edges.
                The inv luma is doing what it should in that it is turning the white part of the layer transparent and giving the black part the colour of the solid the inv luma is being applied to which is black. What I would like it to do is turn the black part of the image to white whilst having the solid so to speak be black.
                I wonder if turning the cartoon into a (photoshop) image where the white is transparent work?
                Thanks again for your help, all other suggestions appreciated. I am sure there is an answer?
                Kal
                • 5. Re: TrkMat luma colour change
                  Dave LaRonde Level 6
                  Use the Invert effect.  You get white lines on black.  If you don't need transparency in the black portions of the image you're done.  No track mattes needed.  Add a black solid to the comp if you want an opaque black background.
                  if you do need transparency you can add the Shift Channels effect and set the alpha to Luminance.  The black becomes transparent.  You can check it by clicking on the checkerboard setting at the bottom of the comp window.
                  • 6. Re: TrkMat luma colour change
                    There's a basic flaw in your concept. When you create a matte you loose the outlines of the drawing because you either have the background (black) visible and a hole where the white is or you have the foreground visible (white) and a hole where the black is. For your effect to work you need to create some lines between the black and white.
                    A more effective way to create a luma matte for a high contrast black and white drawing is to use set matte. Combine that with Refine Matte or Matte choker and you can create some outlines. Use Screen to make the black dissapear or Multiply to make the white dissapear and you end up with only the lines generated with the matte choker visible. You have to hope that you've got clean enough lines and enough detail to not end up with Jaggies....
                    This will give you kind of what you want. It's the closest you can get with the kind of artwork you've got. Take a close look at this screenshot and duplicate the settings. It should help.
                    • 7. Re: TrkMat luma colour change
                      kal192 Level 1
                      Firstly Rick, Can i say a big thank you for helping me out here. I did as you requested and have the following to show for it.
                      The pink solid should only appear inside the woman not outside the borders.
                      Again really appreciate the help you guys are giving. Thank you Thank You
                      Kal.
                      • 8. Re: TrkMat luma colour change
                        Use a copy of your woman with set matte applied as a track matte for the pink solid. Set the pink solid to Screen mode.
                        You could also just use luma matte on the top copy of the woman.
                        • 9. Re: TrkMat luma colour change
                          kal192 Level 1
                          Thank you so much Rick! That got it spot on. Learned quite a bit from your help.Much appreciated.
                          Thanks to Greg too mate!
                          Kal
