3 Replies Latest reply on Jul 31, 2012 5:55 PM by pwillener
    Adobe Flash Installation Issues - Help?
    Spencer6544
      First it started with Skype. I restarted my computer (note that I was using Skype before the restart and it worked), then when I logged in all that, every time I would open up and the a few seconds after I logged in, Skype randomly closed. I tried everything on the forums except fresh installing flash. I removed flash from my computer and downloaded the installer. When I run the installer (I've tried running it in compatibility mode, admin, etc.) it get's to the second window of the installation, closes and the installer is deleted. I've tried running my computer in Safe Mode - still didn't work. Here's the error I'm getting with the flash installer from my Windows Event Viewer:
      Faulting application name: install_flashplayer11x32_mssd_aih_9.exe, version: 3.3.2.8, time stamp: 0x4ffb55f1
      Faulting module name: OLEAUT32.dll, version: 6.1.7601.17676, time stamp: 0x4e58702a
      Exception code: 0xc0000005
      Fault offset: 0x000100eb
      Faulting process id: 0xacc
      Faulting application start time: 0x01cd6eb8b287a9fe
      Faulting application path: C:\Users\Spencer\AppData\Local\Temp\install_flashplayer11x32_mssd_aih_9.exe
      Faulting module path: C:\Windows\syswow64\OLEAUT32.dll
      Report Id: f8d6e76c-daab-11e1-891b-002511ae88f0
      Can anybody help me?
      (I also did a full scan with MalwareBytes and got nothing, and repaired all registry errors with CCleaner Pro. )
      I'm on Windows 7 64-Bit
      Update: I just tried to run ooVoo - did the same thing as Skype.
      Update
