1. Re: problems with the new motion tween
Suhas Yogin Jul 31, 2012 1:59 AM (in response to droidcub)Hi,
Could you please tell us more about the issues you are facing? What kind of issues are these? When exactly does the issue surface?
Please have a look at this FAQ and provide more details as outlined in this FAQ to help investigate your issue further.
Regards,
Suhas Yogin
2. Re: problems with the new motion tween
droidcub Jul 31, 2012 2:09 AM (in response to Suhas Yogin)I have a motion tween of an MC rectabgle rotating in 3D and resting in a particular area. Also, i have it under a mask layer because it is going to serve as a reflection. What i observe is that while the animation looks fine when playing in the timeline...The object shows a jerk when the animation tween ends while compiling. Hope it makes sense.
I would be grateful if you could provide me with a solution for the same.
thanks in advance
3. Re: problems with the new motion tween
Jose_Flash_ookken Jul 31, 2012 2:29 AM (in response to droidcub)I think its related to FPS settings in your application. Please change your FPS settings to 24 or 30 FPS and export the file swf.
This issue is not resolved then change the duration in timeline and export swf as same FPS.
Please let me know if its works fine.
4. Re: problems with the new motion tween
droidcub Jul 31, 2012 5:00 AM (in response to Jose_Flash_ookken)thanks for the quick reply but sadly id did not fix the issue. Is there maybe someway else to do it.
5. Re: problems with the new motion tween
Suhas Yogin Jul 31, 2012 5:01 AM (in response to droidcub)Hello,
Could you please tell us which version of Flash Professional you are using?
Also, how are you playing your animation on the timeline? As in, are you scrubbing the playhead (drag it left to right) or by clicking the Play button?
Also, did you try and test your SWF in a browser (Control > Test Movie > in Flash Professional) and/or within the Flash Professional SWF renderer? Do you observe the jerky behavior then?
Regards,
Suhas Yogin
6. Re: problems with the new motion tween
BladePoint Oct 16, 2012 4:19 AM (in response to Suhas Yogin)I have been able to reproduce this bug in Adobe Flash Professional CS5.5. If your mask is a shape tween that lasts 12 frames, and the masked layer contains a movie clip of a motion tween that lasts 48 frames, the movie clip will be cut off and repeat after only 12 frames instead of playing the 48 frames. Is there a workaround for this?
