Can I combine two methods of code to load various SWF files into the same location
nikolaig Jul 31, 2012 12:07 PMI presently have a set up where a large SWF file brought on the stage by clicking small icons from the scrollable thumbnail menu on the bottom of the stage. All of it happens at the same frame with .xml loading file.
Here is the code for constructing the ImageLoader(for thumbnails) and SWFLoader for (bigger SWF files)
[CODE]
function _xmlCompleteHandler(event:LoaderEvent):void {
_slides = [];
var xml:XML = event.target.content; //the XMLLoader's "content" is the XML that was loaded.
var imageList:XMLList = xml.image; //In the XML, we have <image /> nodes with all the info we need.
//loop through each <image /> node and create a Slide object for each.
for each (var image:XML in imageList) {
_slides.push( new Slide(image.@name,
image.@description,
new ImageLoader("loadingAssets/appThumbnails/slideshow_image scroller greenSock_mine/assets/thumbnails/appThmb_imgs/" + image.@name + ".jpg",
name:image.@name + "Thumb",
width:_THUMB_WIDTH,
height:_THUMB_HEIGHT,
//centerRegistration:true,//messes up the code as places SWFLoader in the upper left corner which is 0,0 coordinates
//x:260, y:320,//doesn't work here but works in line 69
scaleMode:"proportionalInside",
bgColor:0x000000,
estimatedBytes:13000,
onFail:_imageFailHandler}),
new SWFLoader("loadingAssets/appThumbnails/slideshow_image scroller greenSock_mine/assets/images/" + image.@name + ".swf",
name:image.@name + "Image",
width:_IMAGE_WIDTH,
height:_IMAGE_HEIGHT,
x:0, y:144,
bgColor:0x000000,
estimatedBytes:820000,
[/CODE]
Here is what I would like to resolve. I have another section on the site with an image collage. Every image is a button. I want to script this each image on click to go to the label with ImageLoader and SWFLoader AND TO OPEN A UNIQUE SWF (ASSOCIATED WITH AN IMAGE CLICKED) ON THAT PAGE
Previously this is what I did to achieve it. I would specify a String:
[CODE]
var sourceVar_ProductsPopUps:String;
[/CODE]
and then all my buttons will have their unique SWF assigned for them which opens at another labeled section ("prdctsPopUps" in this example):
[CODE]
function onClickSumix1PopUp(event:MouseEvent):void {
sourceVar_ProductsPopUps="prdcts_popups/sumix1-popup_tl.swf";
gotoAndPlay("prdctsPopUps");
[/CODE]
Then in the "prdctsPopUps" section I would specify that var string to bring up SWF files. The value of sourceVar_ProductsPopUps allows to load mulitple SWFs from the previous page.
[CODE]
loaderProductPopUps = new SWFLoader(sourceVar_ProductsPopUps,
[/CODE]
But I need both of them to be working at the same time. First there is a sectionA from where a user can navigate to specifically targeted SWF to section B's SWFLoader. Then in the section B a user has an option to bring up other SWF files into SWFLoader from the scrollable thumbs menu. Is there a way to combine these two lines into one:
[CODE]
[/CODE]
and
[CODE]
[/CODE]
