I've had some issues with flash files opening up partially and then Flash CS5 crashing completely. After opening a different file, then trying to open the file I want, everything seems fine.
Today, however, after opening one of these files, I found my stage to be blank. The timeline was filled as I had created my movie and my code and if I put my mouse on the stage, the properties window showed that i had selected an item. I can also select a symbol in the libaray and have it display above. Publishing works as well, but then I get a long output message that I've googled with not much in the way of results. (Displayed below)
This is also occuring with totally unrelated filash files. I've also go to the extent of copying a timeline, pasted into a new flash file but have had the same result. I had a co-worker open the file on their machine and everything was fine.
I've also tried creating a new flash file, create new sybols and have had nothing show on the stage until I publish to test the file. then get something.
I've uninstalled and reinstalled Flash...no luck. I've also removed the prefs and rebooted as well...still no luck.
Any help would be great. I'm pretty sure it's related to my copy of Flash so if there's something else I can try with reinstalling or the prefs or something, please advise.
verify version::implements if()
stack:
scope: [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ flash.display::MovieClip$ version::implements if$] ~ ~ ~ ~ ~
locals: version::implements if * * * *
0:getlocal0
stack: version::implements if
1:pushstring ""
stack: version::implements if String
3:setslot 4
stack:
5:getlocal0
6:pushstring ""
8:setslot 5
stack:
10:getlocal0
11:pushstring ""
13:setslot 6
stack:
15:getlocal0
16:pushstring ""
18:setslot 8
stack:
20:abs_jump 1394217225 1145
exception[0] from=252 to=1123 target=1127 type=Error name=e
stack:
0:pushfalse
stack: Boolean
1:pushtrue
stack: Boolean Boolean
2:setlocal3
stack: Boolean
locals: version::implements if * * Boolean *
3:newfunction method_id=3465 Function/<anonymous>
stack: Boolean Function
6:pop
stack: Boolean
7:jump 23
stack: Boolean
- 11:pushwith
stack: Boolean
- 12:setlocal3
stack: Boolean
- 13:strictequals
stack: Boolean
- 14:getlocal2
stack: Boolean
- 15:convert_s
stack: Boolean
- 16:getlocal1
stack: Boolean
- 17:inclocal 3
stack: Boolean
- 19:kill 3
stack: Boolean
- 21:kill 2
B23:
stack: Boolean
23:setlocal 4
stack:
locals: version::implements if * * Boolean Boolean
25:getlocal0
26:pushscope
stack:
scope: [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ flash.display::MovieClip$ version::implements if$] version::implements if ~ ~ ~ ~
27:newactivation
28:dup
stack: version::implements if version::implements if
29:setlocal1
locals: version::implements if version::implements if * Boolean Boolean
30:pushscope
stack:
scope: [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ flash.display::MovieClip$ version::implements if$] version::implements if version::implements if ~ ~ ~
31:getlocal 4
stack: Boolean
33:not
stack: Boolean
34:iffalse 246
stack:
38:getscopeobject 1
40:pushnull
stack: version::implements if null
41:coerce flash.utils::ByteArray
stack: version::implements if flash.utils::ByteArray?
43:setslot 1
stack:
45:getlocal 4
stack: Boolean
47:iftrue 169
stack:
51:getlocal 4
stack: Boolean
53:iffalse 209
stack:
57:getlocal1
58:getlocal2
stack: version::implements if *
59:getlocal0
stack: version::implements if * version::implements if
60:kill 1
62:kill 2
64:kill 0
locals: * * * Boolean Boolean
66:setlocal0
67:setlocal2
68:setlocal1
B69:
stack:
locals: version::implements if? version::implements if? * Boolean Boolean
69:label
stack:
70:getlocal0
stack: version::implements if?
71:getlex 1765
stack: version::implements if? flash.system::Capabilities$?
74:getproperty isDebugger
stack: version::implements if? Boolean
77:initproperty *::try var
stack:
80:getlocal3
stack: Boolean
81:not
stack: Boolean
82:iftrue 246
stack:
86:getlocal 4
stack: Boolean
88:iffalse 187
stack:
92:getlocal 4
stack: Boolean
94:getlocal3
95:getlocal0
stack: Boolean Boolean version::implements if?
96:kill 4
locals: version::implements if? version::implements if? * Boolean *
98:kill 3
locals: version::implements if? version::implements if? * * *
100:kill 0
locals: * version::implements if? * * *
102:setlocal0
103:setlocal3
stack: Boolean
104:setlocal 4
B106:
stack:
106:label
stack:
107:getlex 1927
stack: flash.system::Security$?
110:pushstring "*"
stack: flash.system::Security$? String
112:callpropvoid allowDomain 1
stack:
116:getlocal 4
stack: Boolean
118:iftrue 246
stack:
122:getlocal 4
stack: Boolean
124:not
stack: Boolean
125:iffalse 190
stack:
129:getlocal3
stack: Boolean
130:iftrue 237
stack:
134:getlocal3
stack: Boolean
135:getlocal1
stack: Boolean version::implements if?
136:getlocal0
stack: Boolean version::implements if? version::implements if?
137:kill 3
locals: version::implements if? version::implements if? * * Boolean
139:kill 1
locals: version::implements if? * * * Boolean
141:kill 0
locals: * * * * Boolean
143:setlocal0
144:setlocal1
stack: Boolean
145:setlocal3
B146:
stack:
146:label
stack:
147:getscopeobject 1
149:pushnull
150:coerce com.hurlant.crypto.symmetric::IVMode
stack: version::implements if com.hurlant.crypto.symmetric::IVMode?
153:setslot 3
stack:
155:getlocal 4
stack: Boolean
157:not
stack: Boolean
158:iffalse 246
stack:
162:getlocal 4
stack: Boolean
164:not
stack: Boolean
165:iffalse 217
B169:
stack:
169:getlocal 4
stack: Boolean
171:iffalse 69
stack:
175:getlocal1
176:getlocal2
stack: version::implements if? *
177:getlocal0
stack: version::implements if? * version::implements if?
178:kill 1
locals: version::implements if? * * Boolean Boolean
180:kill 2
182:kill 0
184:setlocal0
185:setlocal2
186:setlocal1
B187:
stack:
187:getlocal0
188:constructsuper 0
B190:
stack:
190:getlocal3
stack: Boolean
191:iftrue 106
stack:
195:getlocal0
196:getlocal 4
198:getlocal1
stack: version::implements if? Boolean version::implements if?
199:kill 0
locals: * version::implements if? * Boolean Boolean
201:kill 4
locals: * version::implements if? * Boolean *
203:kill 1
locals: * * * Boolean *
205:setlocal1
206:setlocal 4
208:setlocal0
B209:
stack:
209:getscopeobject 1
211:pushnull
212:coerce com.hurlant.crypto.symmetric::IPad
stack: version::implements if com.hurlant.crypto.symmetric::IPad?
215:setslot 2
B217:
stack:
217:getlocal 4
stack: Boolean
219:iffalse 146
stack:
223:getlocal1
224:getlocal 4
226:getlocal0
227:kill 1
229:kill 4
locals: version::implements if? * * Boolean *
231:kill 0
233:setlocal0
234:setlocal 4
236:setlocal1
B237:
stack:
237:getlex 1927
240:pushstring "*"
242:callpropvoid allowInsecureDomain 1
B246:
stack:
246:getlocal 4
stack: Boolean
248:iffalse 252
B252:
stack:
252:getscopeobject 1
254:getlex 1114
stack: version::implements if com.hurlant.util::Hex$?
257:getlex 1114
stack: version::implements if com.hurlant.util::Hex$? com.hurlant.util::Hex$?
260:getlex 1872
stack: version::implements if com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$?
263:pushint -1549581749
stack: version::implements if com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$? int
266:getlocal3
stack: version::implements if com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$? int Boolean
267:iftrue 281
271:pushbyte 36
stack: version::implements if com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$? int int
273:multiply_i
274:pushbyte 102
276:subtract_i
277:pushbyte 28
279:add_i
280:increment_i
B281:
281:callproperty ___-O 1
stack: version::implements if com.hurlant.util::Hex$? com.hurlant.util::Hex$? String?
285:coerce_s
286:callproperty fromString 1
stack: version::implements if com.hurlant.util::Hex$? String?
290:callproperty toArray 1
294:coerce flash.utils::ByteArray
296:setslot 1
stack:
298:getlocal3
stack: Boolean
299:not
stack: Boolean
300:iftrue 660
stack:
304:getscopeobject 1
306:findpropstrict com.hurlant.crypto.symmetric::NullPad
stack: version::implements if global
309:constructprop 1169 0
stack: version::implements if com.hurlant.crypto.symmetric::NullPad
313:coerce com.hurlant.crypto.symmetric::IPad
316:setslot 2
stack:
318:getlocal 4
stack: Boolean
320:not
stack: Boolean
321:iffalse 660
stack:
325:getlocal3
stack: Boolean
326:iftrue 418
stack:
330:getlocal1
331:getlocal1
stack: version::implements if? version::implements if?
332:getlocal3
stack: version::implements if? version::implements if? Boolean
333:kill 1
335:kill 1
337:kill 3
339:setlocal3
340:setlocal1
341:setlocal1
B342:
stack:
342:label
stack:
343:getscopeobject 1
345:getslot 3
stack: com.hurlant.crypto.symmetric::IVMode?
347:getlex 1114
stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$?
350:getlex 1114
stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? com.hurlant.util::Hex$?
353:getlex 1872
stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$?
356:pushint -1549581748
stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$? int
359:getlocal3
stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$? int Boolean
360:iftrue 379
364:increment_i
365:pushbyte 48
stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$? int int
367:subtract_i
368:pushbyte 41
370:multiply_i
371:pushbyte 72
373:multiply_i
374:decrement_i
375:increment_i
376:pushbyte 65
378:add_i
B379:
379:callproperty ___-O 1
stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? com.hurlant.util::Hex$? String?
383:coerce_s
384:callproperty fromString 1
stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? String?
388:callproperty toArray 1
stack: com.hurlant.crypto.symmetric::IVMode? flash.utils::ByteArray?
392:setproperty IV
stack:
395:getlocal3
stack: Boolean
396:iffalse 600
stack:
400:getlocal 4
stack: Boolean
402:iffalse 545
stack:
406:getlocal2
stack: *
407:getlocal3
stack: * Boolean
408:getlocal0
stack: * Boolean version::implements if?
409:kill 2
411:kill 3
413:kill 0
locals: * version::implements if? * * Boolean
415:setlocal0
stack: * Boolean
416:setlocal3
stack: *
417:setlocal2
B418:
stack:
418:getlocal0
419:getlex 2404
stack: version::implements if? com.hurlant.crypto::Crypto$?
422:getlex 1872
stack: version::implements if? com.hurlant.crypto::Crypto$? ___-5$?
425:pushint -1549581745
stack: version::implements if? com.hurlant.crypto::Crypto$? ___-5$? int
428:getlocal 4
stack: version::implements if? com.hurlant.crypto::Crypto$? ___-5$? int Boolean
430:iffalse 444
434:pushbyte 24
stack: version::implements if? com.hurlant.crypto::Crypto$? ___-5$? int int
436:add_i
437:pushbyte 113
439:multiply_i
440:pushbyte 17
442:subtract_i
443:negate_i
B444:
444:callproperty ___-O 1
stack: version::implements if? com.hurlant.crypto::Crypto$? String?
448:coerce_s
449:getscopeobject 1
stack: version::implements if? com.hurlant.crypto::Crypto$? String? version::implements if
451:getslot 1
stack: version::implements if? com.hurlant.crypto::Crypto$? String? flash.utils::ByteArray?
453:getscopeobject 1
stack: version::implements if? com.hurlant.crypto::Crypto$? String? flash.utils::ByteArray? version::implements if
455:getslot 2
stack: version::implements if? com.hurlant.crypto::Crypto$? String? flash.utils::ByteArray? com.hurlant.crypto.symmetric::IPad?
457:callproperty getCipher 3
stack: version::implements if? com.hurlant.crypto.symmetric::ICipher?
461:initproperty *::cipher
stack:
464:getlocal3
stack: Boolean
465:not
stack: Boolean
466:iftrue 950
stack:
470:getlocal 4
stack: Boolean
472:iffalse 490
stack:
476:getlocal 4
stack: Boolean
478:getlocal1
479:getlocal2
stack: Boolean version::implements if? *
480:kill 4
482:kill 1
484:kill 2
486:setlocal2
487:setlocal1
stack: Boolean
488:setlocal 4
B490:
stack:
490:getscopeobject 1
492:getlocal0
stack: version::implements if version::implements if?
493:getproperty *::cipher
stack: version::implements if com.hurlant.crypto.symmetric::ICipher?
496:getlex 263
stack: version::implements if com.hurlant.crypto.symmetric::ICipher? com.hurlant.crypto.symmetric::IVMode$?
499:astypelate
500:coerce com.hurlant.crypto.symmetric::IVMode
503:setslot 3
stack:
505:getlocal3
stack: Boolean
506:not
stack: Boolean
507:iftrue 950
stack:
511:getlocal 4
stack: Boolean
513:iffalse 342
stack:
517:getlocal0
518:getlocal0
519:getlocal1
stack: version::implements if? version::implements if? version::implements if?
520:jump 536
- 524:declocal_i 3
- 526:declocal_i 3
- 528:getlocal3
- 529:multiply
- 530:divide
- 531:getlocal3
- 532:convert_s
- 533:convert_i
- 534:inclocal_i 3
B536:
536:kill 0
538:kill 0
540:kill 1
542:setlocal1
543:setlocal0
544:setlocal0
B545:
stack:
545:getlex 632
stack: flash.external::ExternalInterface$?
548:getproperty available
stack: Boolean
551:iffalse 1123
stack:
555:getlocal 4
stack: Boolean
557:iftrue 1104
stack:
561:getlocal 4
stack: Boolean
563:iffalse 567
B567:
stack:
567:getlex 50
stack: flash.display::Stage?
569:coerce_a
stack: *
570:convert_b
stack: Boolean
571:getlocal 4
573:iftrue 592
stack: Boolean
577:dup
578:getlocal3
stack: Boolean Boolean Boolean
579:iffalse 615
583:iffalse 614
stack: Boolean
587:getlocal3
588:iffalse 885
B592:
stack: Boolean
592:pop
stack:
593:getlocal 4
stack: Boolean
595:not
stack: Boolean
596:iffalse 1118
B600:
stack:
600:getlex 50
602:getproperty loaderInfo
stack: flash.display::LoaderInfo?
605:coerce_a
stack: *
606:convert_b
stack: Boolean
607:getlocal 4
609:not
610:iffalse 626
B614:
stack: Boolean
614:dup
B615:
615:iffalse 649
stack: Boolean
619:getlocal 4
621:not
622:iffalse 885
B626:
stack: Boolean
626:pop
stack:
627:getlocal 4
stack: Boolean
629:iftrue 774
stack:
633:getlex 50
635:getproperty loaderInfo
638:getproperty parameters
stack: Object?
641:convert_b
stack: Boolean
642:getlocal 4
644:not
645:iffalse 1108
B649:
stack: Boolean
649:iffalse 1123
stack:
653:getlocal 4
stack: Boolean
655:not
stack: Boolean
656:iffalse 894
B660:
stack:
660:getlex 50
662:getproperty loaderInfo
665:getproperty parameters
stack: Object?
668:getproperty {*,public,*,version,version,http://adobe.com/AS3/2006/builtin,version:implements if,version:implements if,flash.display:MovieClip,flash.display:Sprite,flash.display:DisplayObjectContainer,flas h.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher}::cal lFlashPlayerReady
stack: *
671:pushstring "true"
stack: * String
674:ifne 1123
stack:
678:getlocal 4
stack: Boolean
680:iftrue 1006
stack:
684:getlex 1927
687:pushstring "http://www.o-minds.com/payment-gateway/crossdomain.xml"
690:callpropvoid loadPolicyFile 1
stack:
694:getlocal3
stack: Boolean
695:iffalse 855
stack:
699:getlocal3
stack: Boolean
700:iftrue 718
stack:
704:getlocal 4
stack: Boolean
706:getlocal2
stack: Boolean *
707:getlocal2
stack: Boolean * *
708:kill 4
stack: Boolean * *
710:kill 2
stack: Boolean * *
712:kill 2
stack: Boolean * *
714:setlocal2
stack: Boolean *
715:setlocal2
stack: Boolean
716:setlocal 4
B718:
stack:
718:getlocal0
719:getlex 50
stack: version::implements if? flash.display::Stage?
721:getproperty loaderInfo
stack: version::implements if? flash.display::LoaderInfo?
724:getproperty parameters
stack: version::implements if? Object?
727:getproperty {*,public,*,version,version,http://adobe.com/AS3/2006/builtin,version:implements if,version:implements if,flash.display:MovieClip,flash.display:Sprite,flash.display:DisplayObjectContainer,flas h.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher}::ema il
730:initproperty *::email
stack:
733:getlocal3
stack: Boolean
734:iffalse 950
stack:
738:getlocal 4
stack: Boolean
740:iffalse 840
stack:
744:getlocal 4
stack: Boolean
746:getlocal1
747:getlocal1
748:kill 4
750:kill 1
752:kill 1
754:setlocal1
755:setlocal1
stack: Boolean
756:setlocal 4
B758:
stack:
758:label
stack:
759:getlocal0
760:getlocal0
761:callproperty if const 0
765:initproperty *::const finally
stack:
768:getlocal 4
stack: Boolean
770:iftrue 1118
B774:
stack:
774:getlocal3
stack: Boolean
775:iftrue 874
stack:
779:getlocal2
stack: *
780:getlocal 4
stack: * Boolean
782:getlocal1
783:kill 2
785:kill 4
787:kill 1
789:setlocal1
stack: * Boolean
790:setlocal 4
stack: *
792:setlocal2
B793:
stack:
793:label
stack:
794:getlocal0
795:getlex 50
797:getproperty loaderInfo
800:getproperty parameters
803:getproperty {*,public,*,version,version,http://adobe.com/AS3/2006/builtin,version:implements if,version:implements if,flash.display:MovieClip,flash.display:Sprite,flash.display:DisplayObjectContainer,flas h.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher}::sen der
806:initproperty *::sender
stack:
809:getlocal 4
stack: Boolean
811:iftrue 911
stack:
815:getlocal 4
stack: Boolean
817:not
stack: Boolean
818:iffalse 855
stack:
822:getlocal 4
stack: Boolean
824:iffalse 758
stack:
828:getlocal3
stack: Boolean
829:getlocal2
stack: Boolean *
830:getlocal0
stack: Boolean * version::implements if?
831:kill 3
833:kill 2
835:kill 0
837:setlocal0
stack: Boolean *
838:setlocal2
stack: Boolean
839:setlocal3
B840:
stack:
840:getlocal0
841:getlex 50
843:getproperty loaderInfo
846:getproperty parameters
849:getproperty {*,public,*,version,version,http://adobe.com/AS3/2006/builtin,version:implements if,version:implements if,flash.display:MovieClip,flash.display:Sprite,flash.display:DisplayObjectContainer,flas h.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher}::key
852:initproperty *::key
B855:
stack:
855:getlocal3
stack: Boolean
856:iftrue 793
stack:
860:getlocal3
stack: Boolean
861:getlocal 4
863:getlocal3
864:kill 3
866:kill 4
868:kill 3
870:setlocal3
871:setlocal 4
stack: Boolean
873:setlocal3
B874:
stack:
874:getlocal0
875:getproperty *::const finally
stack: Boolean
878:getlocal 4
880:not
881:iffalse 940
B885:
stack: Boolean
885:iffalse 915
stack:
889:getlocal3
stack: Boolean
890:iffalse 911
B894:
stack:
894:getlocal 4
stack: Boolean
896:iffalse 900
B900:
stack:
900:getlocal0
901:pushfalse
902:initproperty *::isPro
stack:
905:getlocal 4
stack: Boolean
907:iftrue 930
B911:
stack:
911:jump 930
B915:
stack:
915:getlocal0
916:getlocal0
917:callproperty version::----___ 0
921:initproperty *::isPro
stack:
924:getlocal 4
stack: Boolean
926:iftrue 1024
B930:
stack:
930:getlocal0
931:getproperty *::isPro
stack: Boolean
934:getlocal3
935:not
936:iftrue 1108
B940:
stack: Boolean
940:iftrue 1010
stack:
944:getlocal3
stack: Boolean
945:not
stack: Boolean
946:iftrue 1118
B950:
stack:
950:getlex 632
953:pushstring "activatePro"
stack: flash.external::ExternalInterface$? String
956:getlocal0
stack: flash.external::ExternalInterface$? String version::implements if?
957:getproperty *::try var
stack: flash.external::ExternalInterface$? String Boolean
960:getlocal0
stack: flash.external::ExternalInterface$? String Boolean version::implements if?
961:getproperty *::isPro
stack: flash.external::ExternalInterface$? String Boolean Boolean
964:getlocal0
stack: flash.external::ExternalInterface$? String Boolean Boolean version::implements if?
965:getproperty *::email
stack: flash.external::ExternalInterface$? String Boolean Boolean String?
968:getlocal0
stack: flash.external::ExternalInterface$? String Boolean Boolean String? version::implements if?
969:getproperty *::key
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String?
972:getlocal0
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? version::implements if?
973:getproperty *::sender
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String?
976:getlocal0
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? version::implements if?
977:getproperty *::const finally
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean
980:pushbyte -1
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean int
982:getlocal 4
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean int Boolean
984:iffalse 993
988:increment_i
989:pushbyte 96
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean int int
991:multiply_i
992:increment_i
B993:
993:pushbyte 0
995:callpropvoid call 9
stack:
999:getlocal 4
stack: Boolean
1001:not
stack: Boolean
1002:iffalse 1104
B1006:
stack:
1006:jump 1123
B1010:
stack:
1010:getlocal0
1011:getlocal0
1012:callproperty *::default finally 0
1016:initproperty *::isPro
stack:
1019:getlocal3
stack: Boolean
1020:iffalse 1104
B1024:
stack:
1024:getlex 632
1027:pushstring "activatePro"
1030:getlocal0
1031:getproperty *::try var
1034:getlocal0
1035:getproperty *::isPro
1038:getlocal0
1039:getproperty *::email
1042:getlocal0
1043:getproperty *::key
1046:getlocal0
1047:getproperty *::sender
1050:getlocal0
1051:getproperty *::const finally
1054:findpropstrict Number
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean global
1056:getlocal0
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean global version::implements if?
1057:getproperty *::---__-
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean global String?
1060:callproperty Number 1
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean Number
1063:pushbyte 0
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean Number int
1065:getlocal 4
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean Number int Boolean
1067:iffalse 1095
1071:decrement_i
1072:decrement_i
1073:increment_i
1074:jump 1090
- 1078:astypelate
- 1079:setlocal3
- 1080:pushscope
- 1081:kill 3
- 1083:declocal_i 3
- 1085:setlocal2
- 1086:getlocal3
- 1087:declocal_i 3
- 1089:coerce_a
B1090:
1090:pushbyte 109
stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean Number int int
1092:add_i
1093:increment_i
1094:increment_i
B1095:
1095:callpropvoid call 9
stack:
1099:getlocal3
stack: Boolean
1100:iffalse 1118
B1104:
stack:
1104:getlocal0
1105:getproperty *::isPro
B1108:
stack: Boolean
1108:iffalse 1123
stack:
1112:getlocal 4
stack: Boolean
1114:iftrue 1123
B1118:
stack:
1118:getlocal0
1119:callpropvoid *::finally finally 0
B1123:
stack:
1123:jump 1143
B1127:
stack: Error?
locals: * * * * *
1127:getlocal0
stack: Error? *
locals: * * * * *
1128:pushscope
VerifyError: Error #1058: Illegal operand type: * must be version.implements if.
at dynamic::Firebug()
at flashfirebug()
