Expand my Community achievements bar.
Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
How to make items visible but inaccessible in a dropdown
Avatar
Level 2
I have dropdown1 with items1-3.  I have dropdown2 with items 1-10.  When item1 is selected in dropdown1 I want dropdown2 to display all 10 items but some items be inaccessible(faded out) and not selectable.
(example)
item1  =    [dropdown2] item 1 = selectable
                [dropdown2] item 2 = selectable
                [dropdown2] item 3 = selectable
                [dropdown2] item 4 = not selectable
                [dropdown2] item 5 = selectable
                [dropdown2] item 6 = not selectable
and so on.
I have coded dropdown2 to populate based on items selected from dropdown1 but the problem is the user needs to see options that are not available for selection?
I am very new to FormCalc & Java any help would be greatly appreciated!!  I am using LiveCycle Designer ES 8.2
1 Accepted Solution
Avatar
Correct answer by
Level 2
Thanks to your help I have got it working now.  I played around with your example here is your modified example of what I was trying to accomplish...https://dl.dropbox.com/u/12892158/Limit_DDL_Selection.pdf   Thank you for your help.
View solution in original post
Avatar
Level 10
you can do this with a script in the change event of the drop down box.
It will check the boundItem against the notUsed regular expression.
This example won't allow the selectio of item 1, 3, 4 and 8.
var notUsed = /1|3|4|8/;
if (this.boundItem(xfa.event.change).match(notUsed)) {
          xfa.event.change = "";
Avatar
Level 2
Ok this may help me but I have a few issues.  When I apply specfy item values then my dropdowns do not populate.  So I have my values spelled out.  So with that my code for dropdown1 goes as follows in the change event.
case "LS32CS - CSA Approved Switch":
    DropDownList3.addItem("FLD - Field Config.")
    DropDownList3.addItem("110 - 110VAC")
    DropDownList3.addItem("220 - 220VAC")
    DropDownList3.addItem("24D - 24VDC")
    DropDownList3.addItem("24A - 24VAC")
    break;
My question is can I empliment your code within this "case" like?
var notUsed = /DropDownList3.addItem("FLD - Field Config.")/;
    break;
Avatar
Level 2
Thanks for the example, but your form doesnt work?
Avatar
Level 2
Here is my entire code for DDL1.  In case "LS32CS - CSA Approved Switch": i do not want  DropDownList3.addItem("FLD - Field Config.") to be selectable??
DropDownList3.clearItems();
var sNewSel = this.boundItem(xfa.event.newText);
switch (sNewSel)
  case "VS5100 - Dual Channel VERSA-SWITCH":
    break;
  case "VS51NX - Dual Channel Non Explosion Proof":
    break;
  case "LS51SC - Single Channel Level Switch":
    break;
  case "LS51NX - Single Channel Level Non Explosion Proof":
    break;
    break;
  case "LS32CN - CENELEC Approved Switch":
    break;
  case "LS32NX - Non Explosion Proof Switch":
    break;
  default:
    break;
Avatar
Correct answer by
Level 2
Avatar
Level 2
Lets take this a step further.  once an item has been selected in DD1 I want to make the Items that are not selectable in DD2  "faded out" or "watermarked".  Where would we insert the font.attributes?
