1. Re: Dreamweaver 5.5 crashes with Mountain Lion
SnakEyez02 Jul 31, 2012 5:16 PM (in response to Edward Shephard)What support number did you call? I would call back and complain:
http://www.adobe.com/products/creativesuite/faq.html#lion-os
It's already in their FAQ that it's compatible. Have you tried the usual steps (#12 & 4)
http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html
2. Re: Dreamweaver 5.5 crashes with Mountain Lion
Pauls Sloss Aug 1, 2012 8:22 PM (in response to Edward Shephard)I have the same problem, it crashes every time. It worked initially when I had upgraded to ML, but started crashing on startup after a few days. I have tried everything, and got it to work for 1 day, but after I started up my computer the next day it started to cash again.
I have run disk repair, repaired permissions, updated Java, reset PRAM, uninstalled Dreamweaver, reinstalled it (set Gatekeeper to "Anywhere"), deleted prefs, deleted Dreamweaver folder from Application support/Adobe folder in library. Checked it wasn't a local account issue by trying to launch it for first time on a differnt account. None of this worked.
I downladed the Dreamweaver 11.5.3 patch from Adobe's website, and that's when it worked for a day. But now none of the above works. I tried the Javascript errors steps SnakEyez02 suggested, but most steps require a version of Dreamweaver that launches.
All my other CS5.5 apps work: Photoshop, Illustrator, Indesign, Flash, Fireworks, Acrobat.
I am now at a loss. Not sure if I should spend the weekend rolling back to Lion.
3. Re: Dreamweaver 5.5 crashes with Mountain Lion
Edward Shephard Aug 2, 2012 1:50 PM (in response to Pauls Sloss)Adboe support spent 3 hours in a remote session trying to get DW to run for me. We created a new profile on the Mac and it works fine there, but will not run on the old profile. No ampount of deleting, reinstalling, coping etc worked at all. Am now waiting for developers to call me back.
4. Re: Dreamweaver 5.5 crashes with Mountain Lion
TenManWater Aug 7, 2012 2:44 AM (in response to Edward Shephard)It works fine now after I deleted all about adobe files even those adobe air, installer, uninstaller, preferences, invisible files....etc. Then reinstall it.
5. Re: Dreamweaver 5.5 crashes with Mountain Lion
Edward Shephard Aug 7, 2012 8:33 AM (in response to Edward Shephard)Well I'm still waiting for my promised 48hr callback after 5 days. Adobe's customer support just sucks.
6. Re: Dreamweaver 5.5 crashes with Mountain Lion
TenManWater Sep 2, 2012 7:48 PM (in response to Edward Shephard)I found another way, you can try to remove all your preferences from your account library, or you can try a half of them, if you're lucky.
7. Re: Dreamweaver 5.5 crashes with Mountain Lion
Pablo Fernandez Olmos Jan 30, 2013 1:24 PM (in response to Edward Shephard)I've the same issue, Dreamweaver CS 5.5 in Mountain Lion Crashes all the time when I click in any window with a form to enter any date, for example when I select properties page in the menu modify (cmnd+j), when I click in any sector to enter any data, crashes and... good bye!!!
I read the file system info (menu apple/about mac/more info) and say this:
Jan 30 22:04:50 xxxxxxxxxx.local Dreamweaver[6145]: The function `CGSFlushWindow' is obsolete and will be removed in an upcoming update. Unfortunately, this application, or a library it uses, is using this obsolete function, and is thereby contributing to an overall degradation of system performance. Please use `CGSFlushWindowContentRegion' instead.
PLEASE, can you help me ADOBE????!!!!
8. Re: Dreamweaver 5.5 crashes with Mountain Lion
mizjanet Feb 27, 2013 1:50 PM (in response to Pablo Fernandez Olmos)I'm getting the same message, damn you adobe
9. Re: Dreamweaver 5.5 crashes with Mountain Lion
mizjanet Feb 27, 2013 2:03 PM (in response to TenManWater)how do I do that?
10. Re: Dreamweaver 5.5 crashes with Mountain Lion
Pablo Fernandez Olmos Feb 27, 2013 3:14 PM (in response to mizjanet)Hi mizjanet, I solve the problem when I do the post 6.TenManWate,
when I waste the preferences of Dreamweaver CS 5.5 and repair permissions in two faces: 1. DisckUtility and 2. ACL repair permissions
Good Luck!
TenManWate, THX!!!!
