2 Replies Latest reply on Aug 1, 2012 5:58 AM by OzSanta2
    Requesting help regarding 'Batch' script
    OzSanta2 Level 1
      G'day
      Elsewhere in this forum I posted a script using the Photoshop 'Batch' command.
      Trouble is, it won't work  under PS CS5 or CS6 extended trial. and gives the following error for both...
      My script is...
      on adding folder items to this_folder after receiving PhotoshopFiles
                try
                          set ptd to path to desktop as text
        --set ptdpp to ptd & "Photoshop Processing" as text
                          set ptdpp to this_folder as text
                          set ptdpif to ptd & "Processed Images Folder" as text
                          set ptdpsf to ptd & "Processed Stored Folder" as text
                          set fileToLog to (ptdpif) & ":Photoshop_Batch_Errors_Log.txt" as text
                          tell application "Finder"
                                    if not (exists folder ptdpsf) then
                                              make new folder at folder ptd with properties {name:"Processed Stored Folder"}
                                    end if
                                    if not (exists folder ptdpif) then
                                              make new folder at folder ptd with properties {name:"Processed Images Folder"}
                                    end if
                                    if not (exists file fileToLog) then
                                              make new file at folder ptdpif with properties {name:"Photoshop_Batch_Errors_Log.txt"}
                                    end if
                                    set PhotoshopFiles to files of folder ptdpp as alias list
                          end tell
        say (count of PhotoshopFiles)
                          tell application "Adobe Photoshop CS5"
        activate
                                    set display dialogs to never
        batch "Wood Frame - 50 pixel" from "Default Actions" from files PhotoshopFiles with options {destination:folder, destination folder:alias ptdpif, error file:alias fileToLog, macintosh compatible:true, file naming:{document name mixed, extension lower}, suppress open:true, override save:true}
                          end tell
        move PhotoshopFiles to folder ptdpsf
                          end tell
                on error errmsg
        display dialog errmsg
                end try
      end adding folder items to
      Am I coding the Batch command correctly please?
      Regards
      Santa
        • 1. Re: Requesting help regarding 'Batch' script
          OzSanta2 wrote:
          G'day
          My script is...
          The Automate Batch Command batches an actiom which I assume you created and it in turn uses your script. You get that message during the batch command. However you give us no clue as to when you get that message  have images file been open or saved or how you setup the batch dialog to run your action that uses your apple script.  I myself use a pc.  You may want to try putting some alerts in you script to see if you can narrow the problen down to some section in your script.
          • 2. Re: Requesting help regarding 'Batch' script
            OzSanta2 Level 1
            Thanks JJMack
            Turns out, from Apples Applescript Users Group, that Adobe document everything to use the Batch command, but don't actually use or support it, nor have they for several iterations of Photoshop.
            Instead, I had to resort to other means to do the job, namely a do action. Here's the script. Note that in some actions, the command to turn off 'display dialogs' doesn't always work. Another Adobe slipup.
            -- Photoshop Action Script
            -- by Brian Christmas
            -- August 2012
            global ptdpp
            global ptdpif
            global ptdpsf
            global fileToLog
            global file_to_save
            global file_Name2
            global file_Extension
            property PhotoshopFiles : {}
            on adding folder items to this_folder after receiving tempPhotoshopFiles -- we don't really want these, in case  there's more in the folder that did not trigger the Folder Action, a common occurrance
                      try
                                my makeNewFolders()
                                set SayThis to " files"
                                if (count of PhotoshopFiles) = 1 then set SayThis to " file"
              say (count of PhotoshopFiles) & SayThis as text
                                tell application "Adobe Photoshop CS6"
                                          repeat with this_File in PhotoshopFiles
                                                    my resetFirstFolder(this_File)
              open this_File
                                                    try
              do action "Wood Frame - 50 pixel" from "Default Actions" without notifiers enabled and display dialogs -- < this particular action brings up a dialog box which can't be addressed with Applescript
              save current document in file file_to_save with copying -- < set to 'without copying' if original files not required
                                                    on error errmsg
              display dialog errmsg -- < write to ":Photoshop_Batch_Errors_Log.txt" here
                                                    end try
                                                    try
              close document 1 saving no
                                                    end try
                                                    my resetSecondFolder(this_File)
                                          end repeat
                                end tell
                      on error errmsg
                      end try
            on makeNewFolders()
                                end if
                                end if
                                end if
                                set PhotoshopFiles to every file of folder ptdpp as alias list -- These are the files we want, every one in the folder
                      end tell
            end makeNewFolders
            on resetFirstFolder(this_File) -- ALL saved as default .psd files
                                set file_Name to name of this_File
                                set file_Extension to "psd" --default Save name extension of this_File, will require altering if default is reset eg to jpeg
                                set file_Name2 to characters 1 through -((count of file_Extension) + 2) of file_Name as text
                                set file_to_save to (ptdpif & ":" & file_Name2 & "." & file_Extension as text)
                                set x to 1
                                repeat
                                          if not (exists file file_to_save) then exit repeat
                                          set file_to_save to (ptdpif & ":" & file_Name2 & " " & x & "." & file_Extension as text)
                                          set x to x + 1
                                end repeat
                      end tell
            end resetFirstFolder
            on resetSecondFolder(this_File) -- ALL saved in original name extensions
                                set file_to_store to (ptdpsf & ":" & file_Name2 & "." & file_Extension as text)
                                set file_Extension to name extension of this_File
                                set x to 1
                                repeat
                                          if not (exists file file_to_store) then exit repeat
                                          set file_to_rename to (ptdpsf & ":" & file_Name2 & " " & x & "." & file_Extension as text)
                                          if not (exists file file_to_rename) then
                                                    set name of file file_to_store to (file_Name2 & " " & x & "." & file_Extension as text)
                                                    exit repeat
                                          end if
                                          set x to x + 1
                                end repeat
                                try
              move this_File to folder ptdpsf
                                on error
                                          try
              move this_File to folder ptdpsf with replacing
                                          on error errmsg
                                          end try
                                end try
                      end tell
            end resetSecondFolder
