13 Replies Latest reply on Aug 8, 2012 2:14 AM by pwillener
    Can't uninstall update or install Flash Player
    Jack_Steel
      I use Windows 7 64bit, Internet Explorer and Firefox. I had Adobe Flash Player 10 installed but updating did not work anymore. So I tried to uninstall Flash Player with no success (I got the same error). I deleted the Flash folders in %appdata% and tried to delete C:\Windows\SysWOW64\Macromed\ but I can't delete Flash10l.ocx (I tried it in Windows safe mode too). I renamed C:\Windows\SysWOW64\Macromed to Macromed.old and did a restart. Firefox tells me there is no Flash plugin installed anymore. I downloaded the Adobe Flash Player 11 installer (DLM version and manual version) but I get the same errors again:
      The installation encountered errors:
      No error information is available.
      FlashInstall.log contains:
      =O====== M/11.2.202.235 2012-08-01+07-16-37.975 ========
      0000 [W] 00001113 C:\Windows\SysWOW64\Macromed\Flash\\* 3
      0001 [I] 00000010 "D:\Downloads\install_flash_player_32bit.exe"
      0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
      0003 [E] 00001039
      =X====== M/11.2.202.235 2012-08-01+07-16-41.782 ========
      =O====== M/11.2.202.235 2012-08-01+07-16-48.796 ========
      0000 [I] 00000010 "D:\Downloads\install_flash_player_32bit.exe"
      0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
      0002 [E] 00001039
      =X====== M/11.2.202.235 2012-08-01+07-16-50.434 ========
      =O====== M/11.3.300.268 2012-08-01+07-29-45.188 ========
      0000 [I] 00000010 "D:\Downloads\install_flash_player.exe"
      0002 [E] 00001039
      =X====== M/11.3.300.268 2012-08-01+07-30-04.447 ========
      =O====== M/10.3.183.20 2012-08-01+07-35-31.371 ========
      0000 [I] 00000010 "D:\Downloads\install_flash_player_10_active_x.exe"
      0001 [E] 00001039
      =X====== M/10.3.183.20 2012-08-01+07-35-34.086 ========
      I would be very happy if somebody can help me or give me some advises how to install Flash Player...
        • 1. Re: Can't uninstall update or install Flash Player
          pwillener Level 8
          Thank your for supplying complete information.
          Can you try the following:
          To delete that recalcitrant ocx file in the old folder, try using Unlocker.
          • 2. Re: Can't uninstall update or install Flash Player
            Jack_Steel Level 1
            Thank you for your fast response.
            - Unlocker helped, I could delete the ocx filie
            - Downloaded the uninstaller, closed all open applications and got
            - Tried the offline installer and got
            FlashInstall.log now contains:
            0003 [E] 00001039
            0002 [E] 00001039
            0002 [E] 00001039
            0001 [E] 00001039
            =O====== M/11.2.202.235 2012-08-01+07-38-21.058 ========
            0002 [E] 00001039
            =X====== M/11.2.202.235 2012-08-01+07-49-29.243 ========
            =O====== M/11.3.300.268 2012-08-01+09-06-38.707 ========
            0000 [I] 00000010 "D:\Downloads\uninstall_flash_player.exe" -force   -force
            0001 [E] 00001039
            =X====== M/11.3.300.268 2012-08-01+09-06-46.725 ========
            =O====== M/11.3.300.268 2012-08-01+09-06-53.862 ========
            0000 [I] 00000010 "D:\Downloads\uninstall_flash_player(1).exe" -force   -force
            =X====== M/11.3.300.268 2012-08-01+09-07-18.000 ========
            =O====== M/11.3.300.268 2012-08-01+09-07-26.739 ========
            0001 [E] 00001039
            =X====== M/11.3.300.268 2012-08-01+09-07-29.594 ========
            =O====== M/11.3.300.268 2012-08-01+09-07-49.502 ========
            0001 [E] 00001039
            =X====== M/11.3.300.268 2012-08-01+09-08-01.345 ========
            =O====== M/11.3.300.268 2012-08-01+09-07-56.789 ========
            0001 [E] 00001011
            =X====== M/11.3.300.268 2012-08-01+09-08-02.436 ========
            =O====== M/11.3.300.268 2012-08-01+09-08-05.450 ========
            0002 [E] 00001039
            =X====== M/11.3.300.268 2012-08-01+09-08-08.367 ========
            • 3. Re: Can't uninstall update or install Flash Player
              pwillener Level 8
              Just to confirm: you do run the installer as an Administrator user?
              • 4. Re: Can't uninstall update or install Flash Player
                Jack_Steel Level 1
                Yes, I'm an Administrator user on this computer.
                • 5. Re: Can't uninstall update or install Flash Player
                  pwillener Level 8
                  I have asked someone from the Adobe installer team to have a look at your problem.
                  • 6. Re: Can't uninstall update or install Flash Player
                    Jack_Steel Level 1
                    Thank you Pat, I'm used to be able to solve almost every problem with my or my friends computer. At the moment I feel a little stranded with this problem... :-)
                    • 7. Re: Can't uninstall update or install Flash Player
                      chris.campbell Adobe Employee
                      We might be dealing with a permission issue here.  Can you try the steps in the following FAQ?
                      How do I fix Windows permission problems with Flash Player?
                      If you still encounter problems, please go through steps 1 - 5 in this post (see reply 15 by me) and either paste the log contents to a reply or email them to ccampbel@adobe.com?  We'd like to get a better idea what's going on with your folders and files.
                      Chris
                      • 8. Re: Can't uninstall update or install Flash Player
                        Jack_Steel Level 1
                        Chris,
                        the solution in the first link did not work, I'm not able to install flash player before and I was not able to install it after doing all the steps on the list.
                        This is the result of the post in your second link:
                        Windows Version: 6.1.7601 x64
                        Permissions: windows\system32\macromed
                        C:\Windows\system32\macromed\Flash
                          RW NT SERVICE\TrustedInstaller
                          RW NT AUTHORITY\SYSTEM
                          RW BUILTIN\Administrators
                          R  BUILTIN\Users
                        C:\Windows\system32\macromed\Flash\FlashInstall.log
                          R  BUILTIN\Users
                        Permissions: windows syswow64\macromed
                        C:\Windows\syswow64\macromed\Flash
                          R  BUILTIN\Users
                        C:\Windows\syswow64\macromed\Flash\FlashInstall.log
                          R  BUILTIN\Users
                        Directory Listing: syswow64\macromed\flash\
                        Volume in drive C is SYSTEM
                        Volume Serial Number is 1825-A40E
                        Directory of C:\Windows\syswow64\macromed\flash
                        01.08.2012  09:16    <DIR>          BUILTIN\Administrators .
                        01.08.2012  09:16    <DIR>          BUILTIN\Administrators ..
                        03.08.2012  08:57             5.856 BUILTIN\Administrators FlashInstall.log
                                       1 File(s)          5.856 bytes
                             Total Files Listed:
                                       2 Dir(s)   8.827.699.200 bytes free
                        Directory Listing: system32\macromed\flash\
                        Directory of C:\Windows\system32\macromed\flash
                        01.08.2012  09:28    <DIR>          BUILTIN\Administrators .
                        01.08.2012  09:28    <DIR>          BUILTIN\Administrators ..
                        01.08.2012  09:28               660 BUILTIN\Administrators FlashInstall.log
                                       1 File(s)            660 bytes
                             Total Files Listed:
                                       1 File(s)            660 bytes
                        HKLM\SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer
                        The system cannot find the file specified.
                        HKCR\MIME\Database\Content Type
                        HKCR\MIME\Database\Content Type\application/atom+xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/fractals
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/futuresplash
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/hta
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/mac-binhex40
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/ms-infopath.xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/ms-vsi
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/msaccess
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/msaccess.addin
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/msaccess.cab
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/msaccess.exec
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/msaccess.ftemplate
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/msaccess.runtime
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/msaccess.template
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/msaccess.webapplication
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/msonenote
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/msword
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/opensearchdescription+xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/pdf
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/pkcs10
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/pkcs7-mime
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/pkcs7-signature
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/pkix-cert
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/pkix-crl
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/postscript
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/rss+xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.fdf
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.google-earth.kml+xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.google-earth.kmz
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.groove-injector
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.groove-space-archive
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.groove-tool-archive
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.groove-vcard
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-excel
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-excel.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-excel.addin.macroEnabled.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-excel.sheet.binary.macroEnabled.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-excel.sheet.macroEnabled.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-excel.template.macroEnabled.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-mediapackage
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-officetheme
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-package.relationships+xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-pki.certstore
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-pki.pko
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-pki.seccat
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-pki.stl
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint.addin.macroEnabled.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint.presentation.macroEnabled.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint.slide.macroEnabled.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint.slideshow.macroEnabled.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint.template.macroEnabled.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-publisher
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-visio.viewer
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-word.document.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-word.document.macroEnabled.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-word.template.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-word.template.macroEnabled.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-wpl
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ms-xpsdocument
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.oasis.opendocument.formula
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.oasis.opendocument.graphics
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.oasis.opendocument.presentation
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.oasis.opendocument.spreadsheet
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.oasis.opendocument.text
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.oasis.opendocument.text-master
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.oasis.opendocument.text-web
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.openofficeorg.extension
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.presentationml.presentation
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.presentationml.slide
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.presentationml.slideshow
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.presentationml.template
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.spreadsheetml.template
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.wordprocessingml.document
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.wordprocessingml.template
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.ovi-suite
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.stardivision.writer
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.sun.xml.base
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.sun.xml.calc
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.sun.xml.draw
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.sun.xml.impress
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.sun.xml.math
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.sun.xml.writer
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.sun.xml.writer.global
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/vnd.visio
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\Application/vnd.visio.webdrawing
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-bittorrent
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-bittorrentsearchdescription+xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-complus
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-compress
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-compressed
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-gotomeeting
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-gotomeeting970
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-gzip
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-informationCard
                          R  NT AUTHORITY\SYSTEM
                          R  BUILTIN\Administrators
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-java-applet
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-java-jnlp-file
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-jtx+xps
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-latex
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-mix-transfer
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-mplayer2
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-ms-application
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-ms-license
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-ms-vsto
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-ms-wmd
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-ms-wmz
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-ms-xbap
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-msexcel
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-mspowerpoint
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-mspowerpoint.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-mspowerpoint.macroEnabled.12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-mswebsite
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-pkcs12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-pkcs7-certificates
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-pkcs7-certreqresp
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-shockwave-flash
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-silverlight
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-silverlight-2
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-stuffit
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-tar
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-troff-man
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-vnd.google.oneclickctrl.9
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-vnd.google.update3webcontrol.3
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-wmplayer
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-x509-ca-cert
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/x-zip-compressed
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/xaml+xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/xej+xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/xel+xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/xhtml+xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\application/zip
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/3gpp
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/3gpp2
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/aiff
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/basic
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/mid
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/midi
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/mp3
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/mp4
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/mpeg
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/mpegurl
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/mpg
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/vnd.dlna.adts
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/wav
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/x-aiff
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/x-mid
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/x-midi
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/x-mp3
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/x-mpeg
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/x-mpegurl
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/x-mpg
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/x-ms-wax
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/x-ms-wma
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\audio/x-wav
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/bmp
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/bmp\Bits
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/gif
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/gif\Bits
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/jpeg
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/jpeg\Bits
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/pjpeg
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/pjpeg\Bits
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/png
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/png\Bits
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/svg+xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/tiff
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/vnd.ms-photo
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/x-emf
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/x-icon
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/x-jg
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/x-png
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/x-png\Bits
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/x-wmf
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\image/x-wmf\Bits
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\message/rfc822
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\midi/mid
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\model/vnd.dwfx+xps
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\model/vnd.easmx+xps
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\model/vnd.edrwx+xps
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\model/vnd.eprtx+xps
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\pkcs10
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\pkcs7-mime
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\pkcs7-signature
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\pkix-cert
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\pkix-crl
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\text/calendar
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\text/css
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\text/html
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\text/plain
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\text/scriptlet
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\text/x-component
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\text/x-ms-contact
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\text/x-ms-iqy
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\text/x-ms-odc
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\text/x-ms-rqy
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\text/x-scriptlet
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\text/x-vcard
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\text/xml
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/3gpp
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/3gpp2
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/avi
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/ismv
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/mp4
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/mpeg
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/mpg
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/msvideo
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/quicktime
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/vnd.dlna.mpeg-tts
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/x-mpeg
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/x-mpeg2a
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/x-ms-asf
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/x-ms-asf-plugin
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/x-ms-wm
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/x-ms-wmv
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/x-ms-wmx
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/x-ms-wvx
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/x-msvideo
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\video/xesc
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\vnd.ms-pki.certstore
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\vnd.ms-pki.pko
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\vnd.ms-pki.seccat
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\vnd.ms-pki.stl
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\x-pkcs12
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\x-pkcs7-certificates
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\x-pkcs7-certreqresp
                          R  BUILTIN\Users
                        HKCR\MIME\Database\Content Type\x-x509-ca-cert
                          R  BUILTIN\Users
                        syswow64\macromed\flash\flashinstall.log
                        0003 [E] 00001039
                        ?=O====== M/11.2.202.235 2012-08-01+07-16-48.796 ========
                        0002 [E] 00001039
                        ?=O====== M/11.3.300.268 2012-08-01+07-29-45.188 ========
                        0002 [E] 00001039
                        ?=O====== M/10.3.183.20 2012-08-01+07-35-31.371 ========
                        0001 [E] 00001039
                        ?=O====== M/11.2.202.235 2012-08-01+07-38-21.058 ========
                        0002 [E] 00001039
                        ?=O====== M/11.3.300.268 2012-08-01+09-06-38.707 ========
                        0001 [E] 00001039
                        ?=O====== M/11.3.300.268 2012-08-01+09-06-53.862 ========
                        ?=O====== M/11.3.300.268 2012-08-01+09-07-26.739 ========
                        0001 [E] 00001039
                        ?=O====== M/11.3.300.268 2012-08-01+09-07-49.502 ========
                        0001 [E] 00001039
                        ?=O====== M/11.3.300.268 2012-08-01+09-07-56.789 ========
                        0001 [E] 00001011
                        ?=O====== M/11.3.300.268 2012-08-01+09-08-05.450 ========
                        0002 [E] 00001039
                        ?=O====== M/11.3.300.268 2012-08-03+06-57-48.208 ========
                        0000 [I] 00000010 "D:\Downloads\install_flash_player(1).exe"
                        0002 [E] 00001039
                        =X====== M/11.3.300.268 2012-08-03+06-57-50.611 ========
                        system32\macromed\flash\flashinstall.log
                        =O====== M/11.2.202.235 2012-08-01+07-28-08.453 ========
                        0000 [W] 00001113 C:\Windows\system32\Macromed\Flash\\* 3
                        0001 [I] 00000010 "D:\Downloads\install_flash_player_64bit.exe"
                        0003 [E] 00001039
                        =X====== M/11.2.202.235 2012-08-01+07-28-14.864 ========
                        • 9. Re: Can't uninstall update or install Flash Player
                          Could you try manually deleting the following folders, then trying again.
                          I'll ask on my end if our installer folks can tell if we're having issues writing registry entries given your install log.
                          Chris
                          • 10. Re: Can't uninstall update or install Flash Player
                            Jack_Steel Level 1
                            Unfortunately deleting the 2 folders didn't change anything. Thank you for further investigations.
                            • 11. Re: Can't uninstall update or install Flash Player
                              pwillener Level 8
                              One more thing to try; run the uninstaller again, then download and run the MSI installers from http://www.adobe.com/products/flashplayer/distribution3.html
                              • 12. Re: Can't uninstall update or install Flash Player
                                Jack_Steel Level 1
                                The MSI installer worked! Flash is working in FF and IE now
                                • 13. Re: Can't uninstall update or install Flash Player
                                  pwillener Level 8
                                  Wow - great!  Sorry it took me so long to think about that...
