7 Replies Latest reply on Aug 13, 2012 8:45 PM by lasvideo
    DNxHD playback & output
    Kale_elb
      Hi Guys,
      Hopefully someone can help me out with this problem. Pr CS6 is not playing back imported DNxHD clips correctly. Video displays in source & record monitors but does not output to external monitor. Audio bars display in audio meter but no sound is played through speakers. All other codecs i have tried have played correctly. Any thoughts?
      Regards,
      Kale.
        • 1. Re: DNxHD playback & output
          lasvideo Level 4
          Kate,  we need to know what hardware you are using to get external playback
          Also what created the DNxHD clips (camera, software,etc.), what computer are you using and any relevant details.
          • 2. Re: DNxHD playback & output
            Kale_elb Level 1
            Thanks for your responce Lastvideo, here's the info you asked for.
            Mac Lion 10.7.4,  2 x 2.4 GHz Quad Core Xeon, 24 gb DDR3
            Graphics card: ATI Radeon HD 5770 1024 MB
            Output with Blackmagic Decklink studio  v9.6.1
            Clips created by Adobe encoder with .mxf's from Canon C300.
            DNxHD clips play as they should in premiere. Now only problem im having is getting output to an external monitor.
            Any help would be greatly appreciated.
            Kale.
            • 3. Re: DNxHD playback & output
              lasvideo Level 4
              Thats Lasvideo as in Las Vegas
              You say the DNxHD clips play in Premiere but you are not seeing it on your external monitor.
              1. Can you get other kinds of clips to play in Premiere and also see them on the external monitor? Are the DNxHD clips the only ones that are problematic?
              2. I assume the external motniro is getting fed HD-SDI from your BM studio card.. Have you installed the most current drivers for that hardware?
              Thats a good start.
              • 4. Re: DNxHD playback & output
                Kale_elb Level 1
                Sorry for the name mix up Lasvideo. Its Kale not Kate btw.
                1. All other kinds of codecs (ProRes, h.264 ect.) play fine in premiere and output fine to external monitor. DNxHD are the only probematic ones.
                2. Yes, the most current drivers for the BM Studio card are installed.
                Ideas?
                • 5. Re: DNxHD playback & output
                  lasvideo Level 4
                  Sorry for the name mixup, Kale
                  I would call BMD tech support. For some codecs to work and DNxHD not to work is very strange.
                  Unless maybe there is something funky about the DNxHD file (it should be Quicktime wrapped not MXF). I personally would make the call to the experts.
                  • 6. Re: DNxHD playback & output
                    Kale_elb Level 1
                    No worries, names are easy to mix up it seems.
                    Looks like I have some calls to make.
                    Thanks for your help.
                    • 7. Re: DNxHD playback & output
                      lasvideo Level 4
                      Good luck!
