4 Replies Latest reply on Aug 13, 2012 10:54 AM by raeben3
    Maintaining tags when revising document content
    Mexican Sage
      I created a 508 compliant tagged document in Adobe Acrobat Pro. (I couldn't find any tagging help in my authoring document, Word 7 for Mac).
      I now need to update my document with a revision. When I export it back to my authoring software, I loose all of my tags. How can I update my doc without loosing my tags?
        • 1. Re: Maintaining tags when revising document content
          CtDave Level 6
          An export of PDF is of the page content only. How it 'lands' in the file formate being exported to is facilitated by the structure tree of tags/element (if present) in the PDF.
          However, the structure tree exist independently from the PDF page content; so, it cannot/will not be exported.
          You'll have to make edits in the authoring file and output a new, tagged PDF. Then post-process with Acrobat Pro.
          No way around that.
          btw —
          For those who need to or desire to provide accessible PDF the ISO standard PDF/UA-1 is a "must have" reference.
          --| The ISO Standard for PDF/UA (ISO 14289-1:2012). Available at the ANSI web store.
          Other documents that are pending release are:
          --| PDF/UA-1 Technical Implementation Guide
          --| PDF/UA-1 Technical Implementation Guide: 32000-1
          (ISO 32000-1 is the current ISO Standard for PDF)
          --| Achieving WCAG 2.0 with PDF/UA (WCAG 2.0 for PDF is PDF/UA)
          The latter three documents are expected to be available on AIIM's web site.
          Be well...
          Message was edited by: CtDave
          • 2. Re: Maintaining tags when revising document content
            Mexican Sage Level 1
            Thank you CTDave!
            I was afraid that was the answer. Do you know whether Office 7 for the PC is sufficient to tag a document or should I invest in Office 10?
            Thanks!
            • 3. Re: Maintaining tags when revising document content
              CtDave Level 6
              Office 7 (2007) won't cut it.
              Office 10 (2010) has robust authoring support for mastering content intended to provide tagged output PDF.
              Be well...
              • 4. Re: Maintaining tags when revising document content
                raeben3 Level 3
                You can make minor text edits in a tagged PDF right in Acrobat Professional using the Edit Document Text tool. If your changes only affect a few pages, you could revise individual pages in Word and then insert those pages into the tagged PDF without losing the tags. I've used both methods numerous times with success.
