2 Replies Latest reply on Aug 3, 2012 7:25 AM by ymichel
    Compile OSMF with SWC
    ymichel
      Hello,
      I try to generate a SWC from modified osmf sources (for my own needs). When I compile my app with my custom osmf SWC and other SWCs (use official osmf SWC), I have some compilations errors :
      Application.as(51): col: 19 Error: Access of undefined property DRMState.
           trace(DRMState.INITIALIZE);
      Below the mxmlc instruction :
      mxmlc --strict -static-link-runtime-shared-libraries -debug  src/Application.as -o application.swf --library-path+=Custom_OSMF_2.0.swc --library-path+=Partner.swc.
      Yvan
      PS : DRMState.INITIALIZE does not exist in the official OSMF 2.0 release.
        • 1. Re: Compile OSMF with SWC
          Silviu Vergoti Adobe Employee
          Hi Yvan,
          There is no INITIALIZE(D) state in OSMF 2.0 - I can't help you with that.
          For token authentication, there are other posts in this forum that could help you.
          S.
          • 2. Re: Compile OSMF with SWC
            ymichel Level 1
            Hi Silviu,
            Thanks for you reply.
            Yes you're right. I've defined it myself and I've generated a SWC (from OSMF 2.0). Actually, is not a DRM issue but something that breaks the compilation:
            When I compile my app with my custom SWC and partners SWC (based on OSMF 2.0 without my patch), I have the following error :
            When I exclude the partner SWC fron the mxmlc instruction, everything is OK.
