12 Replies Latest reply on Aug 2, 2012 7:13 AM by graphicedge
    Is there a way to create "real" superscript in Dreamweaver?
    graphicedge Level 1
      I know how to use the <sup></sup> tags to superscript type, but the problem is that the type within those tags doesn't reduce in size.  I'm looking for a way to create a true superscript.  Can anyone give me a way to do this?
        • 1. Re: Is there a way to create "real" superscript in Dreamweaver?
          Jon Fritz II Adobe Community Professional & MVP
          Not without additional coding. You can change the font size as well within the <Sup> tags.
          I would create a class in CSS. Put the following between your <head> tags...
          <style>
          .super {
             font-size:.6em;
            vertical-align:super;
          </style>
          And then add that to the font you want to affect within a <span> tag
          Pi * r<span class="super">2</span> is the formula for the area of a circle.
          • 2. Re: Is there a way to create "real" superscript in Dreamweaver?
            Once the style is added to your <head> section, you would just highlight the text you want t affect in the Design View of DW, then select the "super" class in the Properties inspector and DW will add the span tags for you.
            • 3. Re: Is there a way to create "real" superscript in Dreamweaver?
              @Jon, why use a class when you can  style the <sup>?
              CSS:
              p {font size: 18px}
              sup {font-size: 11px}
              HTML:
              <p>E=MC<sup>2</sup></p>
              Nancy O.
              • 4. Re: Is there a way to create "real" superscript in Dreamweaver?
                MurraySummers MVP & Adobe Community Professional
                Here's the BEST way I have found - it doesn't make the line-height change!
                sup {
                  position: relative;
                  top: -1ex;
                  vertical-align:baseline;
                  font-size: 80%;
                • 5. Re: Is there a way to create "real" superscript in Dreamweaver?
                  @Nancy, sometimes I miss the obvious things like that, sometimes I miss the not so obvious things (like misplaced ' in JS).
                  @Murray, copied and pasted.
                  • 6. Re: Is there a way to create "real" superscript in Dreamweaver?
                    You may use it without attribution!
                    • 7. Re: Is there a way to create "real" superscript in Dreamweaver?
                      graphicedge Level 1
                      Murray,
                      I'm not the best at working with code, and I tried these but none of them really work exactly as I'd like.
                      The bigger problem I have is that I messed with the CSS doc and the code on this one page and somehow when I look at the site, it's a total mess.  I do not know what the hell happened.  It's an older site but it was created with divs.  I just do not know what happened and I'm hoping you might be able to help me diagnose what the problem is.
                      Thanks in advance
                      Guess it would help if I gave you the URL:  www.fulcrumcwi.com... doesn't matter what page you look at they are all messed up which leads me to think something got messed up in the template... but I didn't touch that.
                      graphicedge
                      • 8. Re: Is there a way to create "real" superscript in Dreamweaver?
                        Can you say more about how the pages are "all messed up"?  The pages look fine to me in Safari and Opera.
                        And where did you try the superscript and not get what you wanted?
                        • 9. Re: Is there a way to create "real" superscript in Dreamweaver?
                          You're missing a semi-colon after the text-decoration attribute in your .footer class in the CSS. That could be causing some wonkiness somewhere.
                          • 10. Re: Is there a way to create "real" superscript in Dreamweaver?
                            graphicedge Level 1
                            OK, the bottom half of the site, everything below where the navigation is would move to the right when youe made the browser window wider.  The only tow things that didn't move in that area where the 20 year graphic and the floating box on the right.
                            I asked my client, who does her own updating to content with Dreamweaver CS5 to re-upload the site files so you were probably looking at those files.  Here is a screen shot of what I got when I opened the site template in a browser:
                            I have not yet gotten the files that my client has put up.  I can paset the code for this page here so you can take a look.  It has to be coming from this file because this file runs how the site looks.  I'm just stumped.
                            Also the page that needed the superscript is the Events and Seminars page.  Last line of the October 15-19, 2012 listing.  No matter which of the scripting suggestions I used, I still ended up with the last line's leading being more than the rest of the paragraph and the smaller "SM" not rendering as smaller in Safari or Firefox??
                            Here's the page code for the template page:
                            <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
                            <html xmlns="http://www.w3.org/1999/xhtml">
                            <head>
                            <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
                            <link rel="shortcut icon" href="../favicon.ico" />
                            <!-- TemplateBeginEditable name="doctitle" -->
                            <title>Untitled Document</title>
                            <!-- TemplateEndEditable -->
                            <link rel="stylesheet" href="../fulcrum.css" type="text/css" media="all" />
                            <script src="../jquery-1.3.2.min.js" type="text/javascript"></script>
                            <script>
                                $().ready(function() {
                                    var $scrollingDiv = $("#scrollingDiv");
                                    $(window).scroll(function(){
                                        $scrollingDiv
                                            .stop()
                                            .animate({"marginTop": ($(window).scrollTop() + 10) + "px"}, "slow" );
                            </script>
                            <script type="text/javascript" src="../p7pm/p7popmenu.js"></script>
                            <style type="text/css" media="screen">
                            @import url("../p7pm/p7pmv0.css");
                            </style>
                            a:link {
                                text-decoration: none;
                                color: #00F;
                            a:visited {
                                color: #00F;
                            a:hover {
                                text-decoration: underline;
                            a:active {
                                color: #00F;
                            .news_signup {
                                font-size: 9px;
                                font-weight: bold;
                                color: #FFFFFF;
                                font-family: Verdana, Geneva, sans-serif;
                                text-align: center;
                            .style2 {
                                font-family: Verdana, Arial, Helvetica, sans-serif;
                                font-size: 10px;
                            .style5 {font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 10px; color: #1946C6; }
                            </style>
                            <!-- TemplateBeginEditable name="head" -->
                            <meta name="Description" content="Fulcrum ConsultingWorks, Inc. works with manufacturing companies to find creative, practical, and strategic means of improving their operations." />
                            <link href="../p7pmm/p7PMMh03.css" rel="stylesheet" type="text/css" media="all" />
                            <script type="text/javascript" src="../p7pmm/p7PMMscripts.js"></script>
                            <style type="text/css">
                            #apDiv1 {
                                position:absolute;
                                left:776px;
                                top:195px;
                                width:176px;
                                height:26px;
                                z-index:9000;
                                visibility: visible;
                                text-align: left;
                            </style>
                            <!-- TemplateParam name="id" type="text" value="apDiv1" -->
                            var _gaq = _gaq || [];
                            _gaq.push(['_setAccount', 'UA-2505101-1']);
                            _gaq.push(['_trackPageview']);
                            (function() {
                               var ga = document.createElement('script'); ga.type = 'text/javascript';
                            ga.async = true;
                               ga.src = ('https:' == document.location.protocol ? 'https://ssl' :
                            'http://www') + '.google-analytics.com/ga.js';
                               var s = document.getElementsByTagName('script')[0];
                            s.parentNode.insertBefore(ga, s);
                            </script>
                            </head>
                            <body onload="P7_initPM(0,0,1,0,0)">
                            <div id="apDiv1">
                            <script language='javascript'>
                              function clearText(src)
                                if(src.value == "Search FulcrumCWI")
                                   src.value="";
                            </script>
                              <table width="175" border="0" align="center" cellpadding="0">
                                <tr>
                                  <td align="center" valign="top"><form method="GET" action="http://www.fulcrumcwi.com/search.asp" target="_blank">
                                                      <input name="zoom_query" type="text" class="style2" id="zoom_query2" value="Search fulcrumcwi" size="14" maxlength="35">
                                                      <input name="Submit" type="submit" class="style5" value="GO">
                                  </form></td>
                                </tr>
                              </table>
                            </div>
                            <div id="wrapper">
                            <div id="masthead">
                                                    <a name="top" id="top"></a><a href="../index.html" target="_self"><img src="../images/fulcrumLogo.png" alt="Fulcrum ConsultingWorks" style="float:left; border:none; font-family: Verdana, Geneva, sans-serif;" /></a>
                                                    <div id="signup">
                                                      <table width="150" border="0" align="left" cellpadding="2" cellspacing="2">
                                                        <tr>
                            <!-- BEGIN: Constant Contact Stylish Email Newsletter Form -->
                            <div align="left">
                            <div style="width:150px">
                            <form name="ccoptin" action="http://visitor.constantcontact.com/d.jsp" target="_blank" method="post" style="margin-bottom:3;" />
                            <font style="font-weight: bold; font-family:Arial; font-size:10px; color:#FFFFFF;">Finish Strong<sup>&reg;</sup> Newsletter</font>
                            <input name="ea" type="text" style="font-family:Verdana,Geneva,Arial,Helvetica,sans-serif; font-size:10px; border:1px solid #999999;" onfocus="if(this.defaultValue==this.value) this.value = '';" value="your e-mail" size="15" maxlength="35" />
                            <input type="submit" name="go" value="GO" class="submit"  style="font-family:Verdana,Arial,Helvetica,sans-serif; font-size:10px;" />
                            <a href="http://www.constantcontact.com/safesubscribe.jsp" target="_blank"><font style="font-weight: normal; font-family:Arial; font-size:9px; color:#FFFFFF;"><br />
                            Privacy by <img src="https://imgssl.constantcontact.com/ui/images1/visitor/email3_trans.gif" border="0"> SafeSubscribe<sup>&reg;</sup></font></a>
                            <input type="hidden" name="m" value="1101177344718" />
                            <input type="hidden" name="p" value="oi" />
                            </form>
                            </div>
                            </div>
                            <!-- END: Constant Contact Stylish Email Newsletter Form -->
                            </td>
                                                        </tr>
                                                      </table>
                                                    </div>
                                                    <div style="clear:both; font-family: Verdana, Geneva, sans-serif;"></div>
                              </div>
                                             <div id="skip-wrapper">
                            <h2>Main Menu</h2>
                            <p><a id="p7PMMshowall" href="#p7PMM_1a1">Jump to Main Menu and expand all of its hidden submenu items. Once expanded you can tab through all links or open your screen reader's link list.</a></p>
                            </div>
                            <div id="mainnav">
                                                    <div style="padding-left:192px;">
                                                         <div id="p7PMM_1" class="p7PMMh03 p7PMMnoscript">
                                                           <ul class="p7PMM">
                                                             <li><a href="../about.html" target="_self">About Fulcrum</a>
                                                               <div>
        <ul>
        <li><a href="../rebecca.html">About Rebecca</a></li>
        <li><a href="../wehelp.html">How We Help</a></li>
        <li><a href="../services.html">Services</a></li>
        <li><a href="../clients.html">Clients</a></li>
        <li><a href="../casestudies.html">Case Studies</a></li>
        <li><a href="../testimonials.html">Testimonials</a></li>
        </ul>
                                                               </div>
                                                             </li>
                                                             <li><a href="../operations_strategy.html" target="_self">Operations Strategy</a>
                                                               <div>
        <ul>
        <li><a href="../finish_strong_thinking.html">Finish Strong<sup>&reg;</sup> Thinking</a></li>
        <li><a href="../finish_strong_strategies.html">Finish Strong<sup>&reg;</sup> Strategies</a></li>
        <li><a href="../lean.html">All About Lean</a></li>
        <li><a href="../faq.html">Operation Faqs</a></li>
        </ul>
                                                               </div>
                                                             </li>
                                                             <li><a href="../free_resources.html" target="_self">FREE Resources</a>
                                                               <div>
        <ul>
        <li><a href="../articles_by_rebecca.html">Articles by Rebecca</a>
        <div>
        <ul>
        <li><a href="../inc_articles.html">INC.com Articles</a></li>
        <li><a href="../other_publications.html">Other Publications</a></li>
        </ul>
        </div>
        </li>
        <li><a href="../newsletters.html">Newsletters</a>
        <div>
        <ul>
        <li><a href="../current_newsletter.html">Current Newsletter</a></li>
        <li><a href="../archive_newsletters.html">Archived Newsletters</a></li>
        </ul>
        </div>
        </li>
        <li><a href="../special_reports.html">Special Reports</a></li>
        </ul>
                                                               </div>
                                                             </li>
                                                             <li><a href="../media.html" target="_self">Media</a>
                                                               <div>
        <ul>
        <li><a href="../sample_interview.html">Sample Interview Questions</a></li>
        <li><a href="../speech_topics.html">Speech Topics</a></li>
        <li><a href="../bio_and_photos.html">Bio & Photos</a></li>
        <li><a href="../in_the_news.html">Rebecca in the News</a></li>
        <li><a href="../press_releases.html">Press Releases</a></li>
        <li><a href="../dwnldble_articles.html">Downloadable Articles</a></li>
        </ul>
                                                               </div>
                                                             </li>
                                                             <li><a href="../events_main.html" target="_self">Coming Events</a>
                                                               <div>
        <ul>
        <li><a href="../events_and_seminars.html">Events & Seminars</a></li>
        <li><a href="../speaking_calendar.html">Speaking Calendar</a></li>
        <li><a href="../ev_calendar_testimonials.html">Audience Testimonials</a></li>
        </ul>
                                                               </div>
                                                             </li>
                                                             <li><a href="../contact.html" target="_self">Contact Us</a></li>
                                                             <li><a href="../index.html" target="_self">Home</a></li>
                                                           </ul>
                                                        <div class="p7pmmclearfloat"> </div>
                                                        <!--[if lte IE 6]>
                            <style>.p7PMMh03 ul ul li {float:left; clear: both; width: 100%;}.p7PMMh03 {text-align: left;}.p7PMMh03, .p7PMMh03 ul ul a {zoom: 1;}</style>
                            <![endif]-->
                                                        <!--[if IE 5]>
                            <style>.p7PMMh03, .p7PMMh03 ul ul a {height: 1%; overflow: visible !important;} .p7PMMh03 {width: 100%;}</style>
                            <![endif]-->
                                                        <!--[if IE 7]>
                            <style>.p7PMMh03, .p7PMMh03 a{zoom:1;}.p7PMMh03 ul ul li{float:left;clear:both;width:100%;}</style>
                            <![endif]-->
                            P7_PMMop('p7PMM_1',1,2,0,0,0,0,0,1,0,3,1,1,0,1,0);
                                                        </script>
                                                      </div>
                            <div style="padding-top: 4px;">
                            <tr><script language='javascript'>
                                   src.value="";
                            </script>
                                                  <td align="left" valign="top" class="style2"> </td>
                                    </tr>
                            </div>
                                              <div style="clear:both;"></div>
                                              </div>
                                              </div>
                                            <div id="contentwrapper">
                                                    <div id="sidenav">
                                                            <!-- TemplateBeginEditable name="anniversary" -->
                                                            <div id="anniversary">
        <img src="../images/20thAnniversary.png" />
                                                            </div>
                                                            <!-- TemplateBeginEditable name="nav2" -->
                                                            <div id="sidenav2">
                                                              <ul id="p7PMnav">
        <li><a href="#">Section 1</a></li>
        <li><a href="#" class="p7PMtrg">Section 2</a>
        <ul>
        <li><a href="#">Link 2.1</a></li>
        <li><a href="#" class="p7PMtrg">Link 2.2</a>
        <ul>
        <li><a href="#">Link 2.2.1</a></li>
        <li><a href="#">Link 2.2.2</a></li>
        <li><a href="#">Link 2.2.3</a></li>
        </ul>
        </li>
        <li><a href="#">Link 2.3</a></li>
        </ul>
        </li>
        <li><a href="#" class="p7PMtrg">Section 3</a>
        <ul>
        <li><a href="#">Link 3.1</a></li>
        <li><a href="#">Link 3.2</a></li>
        <li><a href="#">Link 3.3</a></li>
        </ul>
        </li>
        <li><a href="#">Section 4</a></li>
        <!--[if lte IE 6]><style>#p7PMnav a{height:1em;}#p7PMnav li{height:1em;float:left;clear:both;width:100%}</style><![endif]-->
        <!--[if IE 6]><style>#p7PMnav li{clear:none;}</style><![endif]-->
        <!--[if IE 7]><style>#p7PMnav a{zoom:100%;}#p7PMnav li{float:left;clear:both;width:100%;}</style><![endif]-->
                                                              </ul>
                            <ul>
                                      <!--[if lte IE 6]><style>#p7PMnav2 a{height:1em;}#p7PMnav2 li{height:1em;}#p7PMnav2 ul li{float:left;clear:both;width:100%}</style><![endif]-->
                                      <!--[if IE 6]><style>#p7PMnav2 ul li{clear:none;}</style><![endif]-->
                                      <!--[if IE 7]><style>#p7PMnav2 a{zoom:100%;}#p7PMnav2 ul li{float:left;clear:both;width:100%;}</style><![endif]-->
                                      </ul>
                                                              </div>
                                                 </div>
                                                    <div id="content">
                                                            <div id="leftcolumn">
        <!-- TemplateBeginEditable name="content" -->
        <p>Operations As Competitive Advantage</p>
                            <p>Position your company’s operations to reliably and profitably create and deliver competitive advantage to your marketplace</p>
                            <p>When your operations provide excellence, reliability, repeatability and predictability, the market will take notice and be willing to pay for the advantages of doing business with you.</p>
                            <p>If you are committed to the operational excellence that profitably develops and delivers the competitive advantage touted by your business and marketing strategies, leverage Fulcrum’s expertise to accelerate your journey.</p>
                            <p>According to renowned operations strategist Rebecca Morgan, the difference between excellence and mediocrity is about how you finish, not how you start. When working to improve operations, too many organizations start fast, but fail to finish.</p>
                            <p>Want to get there? Fulcrum will help you start wisely <br />
                            and Finish Strong&reg;!</p>
                            <p>Creative, Practical, Strategic — Thinking To Help Your Company</p>
        <div id="footer">
        <span><a href="../about.html" target="_self">About Fulcrum</a> | <a href="../operations_strategy.html" target="_self">Operations Strategy</a> | <a href="../free_resources.html" target="_self">Free Resources</a> | <a href="../media.html" target="_self">Media</a> <br />
        <a href="../events_and_seminars.html" target="_self">Coming Events</a> | <a href="../contact.html" target="_self">Contact Us</a> | <a href="../index.html" target="_self">Home</a></span>
        <img src="../images/footerline.jpg" style="padding-top:10px; padding-bottom:5px;" />
        <strong>FULCRUM ConsultingWorks, Inc.</strong><br />
                            <strong>Phone:</strong> (216) 486-9570 &#8226;<strong> E-mail:</strong> <script type="text/javascript">
                            //<![CDATA[
                            var x="function f(x){var i,o=\"\",ol=x.length,l=ol;while(x.charCodeAt(l/13)!" +
                            "=37){try{x+=x;l+=l;}catch(e){}}for(i=l-1;i>=0;i--){o+=x.charAt(i);}return o" +
                            ".substr(0,ol);}f(\")45,\\\"ZPdw771\\\\b:ue585{=$1<%=-!9-n\\\\') 4*)}`530\\\\"+
                            "%R630\\\\QUZW|030\\\\XB520\\\\_P[]sr\\\\r020\\\\IG^@\\\\\\\\700\\\\400\\\\y" +
                            "IL010\\\\D000\\\\730\\\\400\\\\310\\\\020\\\\620\\\\000\\\\610\\\\420\\\\60" +
                            "0\\\\730\\\\0<;)54b8\\\"\\\\9=2?s410\\\\r((>#j(ten+(&6(2H020\\\\IR^WL[XR\\\""+
                            "(f};o nruter};))++y(^)i(tAedoCrahc.x(edoCrahCmorf.gnirtS=+o;721=%y;i=+y)45=" +
                            "=i(fi{)++i;l<i;0=i(rof;htgnel.x=l,\\\"\\\"=o,i rav{)y,x(f noitcnuf\")"       ;
                            while(x=eval(x));
                            </script><br />
                            //<![CDATA[
                            "=92){try{x+=x;l+=l;}catch(e){}}for(i=l-1;i>=0;i--){o+=x.charAt(i);}return o" +
                            ".substr(0,ol);}f(\")49,\\\"OCIXRMF300\\\\000\\\\610\\\\630\\\\000\\\\230\\\\"+
                            "020\\\\H120\\\\n\\\\600\\\\710\\\\420\\\\300\\\\0:\\\"(f};o nruter};))++y(^" +
                            ")i(tAedoCrahc.x(edoCrahCmorf.gnirtS=+o;721=%y;2=*y))y+49(>i(fi{)++i;l<i;0=i" +
                            "(rof;htgnel.x=l,\\\"\\\"=o,i rav{)y,x(f noitcnuf\")"                         ;
                            while(x=eval(x));
                            </script>
                            17204 Dorchester Drive Cleveland, OH 44119-1302
        <p>&copy; 2003 - 2012 FULCRUM ConsultingWorks, Inc. All Rights Reserved</p>
        </div>
                                                         </div>
                                                            <div id="rightcolumn">
        <p class="b2"><br />
        <br />
        <a href="../current_newsletter.html" target="_self"><strong>Read the July</strong><br />
        <strong>Finish Strong<sup>&reg;</sup><br />
                            Newsletter</strong></a><br />
        <br />
                                                              </p>
        <p class="b2"><strong><a href="http://fulcrumcwiblog.com/blog/" target="_blank">Check Out the<br />
                                                        FulcrumCWI Blog</a></strong><br />
                                                        <br />
        </p>
                                                              <p class="b2"><strong><a href="http://www.inc.com/resources/office/columns/morgan.html" target="_blank">Fulcrum Articles <br />
                                                        Published by INC.com</a></strong><br /><br /><br />
                                                              </p>
                                                              <div id="scrollingDiv">
        <img src="../images/slidingDivTop.gif" />
        <!-- TemplateBeginEditable name="scrollingdiv" -->
        <br />
        <p>See What<br />
        Our Clients Say<br />
        About Us </p>
                            <p><a href="testimonials.html" target="_self"><strong>Testimonials</strong></a></p>
        <img src="../images/slidingDivBottom.gif" />
        </div>
                                                              </div>
                                                    </div>
                                            </div>
                            </div>
                            </script>
                            <!--webbot bot="HTMLMarkup" endspan i-checksum="29191" -->
                            <map name="Map">
                              <area shape="rect" coords="-253,0,8,138" href="../index.html" target="_self">
                            </map>
                            <map name="Map2">
                              <area shape="rect" coords="-173,0,62,137" href="../index.html" target="_self">
                              <area shape="rect" coords="-187,0,2,135" href="#">
                              <area shape="rect" coords="-75,29,1,134" href="#">
                            </map>
                            <map name="Map3">
                              <area shape="rect" coords="-2,2,79,136" href="../index.html" target="_self">
                            </map>
                            <map name="Map4">
                              <area shape="rect" coords="-11,0,119,135" href="../index.html" target="_self">
                            </map>
                            <script src="http://www.google-analytics.com/urchin.js"
                            </script>
                            <map name="Map5"><area shape="rect" coords="2,1,173,81" href="../res_newsletters.htm" target="_self" alt="Newsletter Sign-Up">
                            </map>
                            </body>
                            </html>
                            Any help to understand where this went wrong would help.
                            graphicedge
                            • 11. Re: Is there a way to create "real" superscript in Dreamweaver?
                              It's much easier to troubleshoot if you could post a temporary page online somewhere, perhaps within a folder named "test" that you could then delete once the issue is resolved.
                              If you're worried about being indexed by a search engine, you can add <meta name="robots" content="noindex,nofollow" /> to the head section of the page (also to be deleted before uploading to the actual site).
                              • 12. Re: Is there a way to create "real" superscript in Dreamweaver?
                                graphicedge Level 1
                                OK, I'll see if I can make something available.
