2 Replies Latest reply on Aug 1, 2012 12:39 PM by clytus
    Can't print from InDesign CS5 under Mountain Lion
    clytus
      After installing MacOS 10.8 InDesign crashes when I try to open the printer configuration in the printing menu. Acrobat crashes immediately when I want to open the print menu. Photoshop prints fine and PDF export in ID also works as well as printing without changing the former printing  settings.
      In an older discussion I found the hint to delete some language folders in the PPD ressources folder to solve the same problem in CS3 and 4 with Lion. I tried that to but it won't work.
      Any ideas? Thanks in advance
        • 1. Re: Can't print from InDesign CS5 under Mountain Lion
          If changing the print settings crashes ID I wonder if you need to delete and reinstall your printers? Testing CS3 I wasn't able to even open the Print dialog without crashing, so  deleteing the foriegn language PPDs worked
          By default Mountain Lion hides the user Library (you can't see user/Library/Printers). You can get to it via Go>Go to Folder and typing ~/Library
          • 2. Re: Can't print from InDesign CS5 under Mountain Lion
            clytus Level 1
            Thanks, but
            that happens on my MacPro first. Trying to print my jobs on my MacBook Pro I had to install the printer first. Although the printer is freshly installed and the foreign language PPDs has been deleted, it won't change a thing.
