7 Replies Latest reply on Aug 1, 2012 4:41 PM by starbird parrot
    Can
    starbird parrot Level 1
      I have an empty file opened. Colors are set to black and white in the icon. Mode is RGB. When I try to use the brush tool to make a mark, it only comes out PALE PALE PALE gray. Opacity is set to 100% as is fill. Why can't I get a black line and what can I do about this? it's urgent as I need to sign a document. thanks
        • 1. Re: Can
          conroy Level 5
          Check your brush options
          as well as layer options
          • 2. Re: Can
            I have checked everything...
            Here is a suggested list and I checked all of them.... nothing is set incorrectly.
            Make sure you are on a pixel Layer and it is not locked (any of the locks)
            - Make sure the Blend mode of Layer is Normal
            - Make sure you have no Layer Styles turned on
            - Make sure Layer and Fill Opacity of Layer is set to 100%
            - Make sure you do not have a Layer Mask on that Layer
            - Make sure that Layer does not have a Vector Mask on that Laye
            - Make sure you don't have a hidden selection turned on by typing Cmd+D (Ctrl+D for PC)
            - Make sure the blending mode of the brush is set to Normal
            I tried the pencil tool and it was black, but when I went to save it, it turned pale gray.
            This is really baffling and I need to sign this document.  Also I am using CS4...
            • 3. Re: Can
              conroy Level 5
              Try resetting the Brush Tool. Right-click the icon at the left of its options bar to get the reset menu.
              • 4. Re: Can
                You're brilliant!!! That did it. The brush now brushes in black.  How did you know to do that?  What do you think was wrong. Boy, I will never forget that little tidbit.
                Thank you so much!!!
                • 5. Re: Can
                  conroy Level 5
                  A lucky guess! There are so many controls in the Brush Tool settings that it seemed easiest to do a complete reset of the tool.
                  • 6. Re: Can
                    Noel Carboni Level 8
                    Nah, you're brilliant.
                    -Noel
                    • 7. Re: Can
                      Not only brilliant, but very sweet... thank you.
