Hello everyone
I used Rh html 9.
I created a new index in my project to have two independent and different index, but the two index are connected. When I deleted one word in the new index, the same word is deleted in the first index.
When I've created the second index, I didn't choose the option "from an existing index", because I wanted a new and empty index but RH created a copy of the existing index and linked with the existing index.
It is possible toc reate a lot of different table of content and glossary but not different index ?
If someone can explain me why it doesn't work for index.
Thank you.
Florence
Hi there
If you click File > Project Settings > General tab, is the index set to have keywords in Topics or the Index file (HHK)?
If it's set for Index file (HHK) that would likely explain it because the keywords are stored directly inside the topics themselves.
If the setting is already for Index file (HHK) I'm a bit stumped and can only fathom that maybe you have stumbled across a bit of a RoboHelp bug. I've not tried using multiple indexes before. Perhaps I should try and see.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
The index was set to have keywords in Topics.
I’ve changed to have keywords in the Index file (HHK), but the problem still remains in the project.
In another RH project, the creation of a second index works well.
Envoyé : jeudi 2 août 2012 15:26
À : BOURCIER Florence
Objet : how to create two independent index in the same RH project?
Re: how to create two independent index in the same RH project?
created by Captiv8r<http://forums.adobe.com/people/Captiv8r> in RoboHelp HTML - View the full discussion<http://forums.adobe.com/message/4593776#4593776
The keywords that are in the topics will appear in all indexes.
